You have taken my post to literally by no resistance i meant there is no FET/springs to reduce the current thus its a low resistance as it possibly could be.
It also means that with a regulated driver(either boost, buck, or linear) the more efficient lower Vf led will stay in regulation longer and half a volt means something there.
Boost or buck? yes and and no. Without enough voltage difference between source and load you just shouldn't be using a buck. With too much, you shouldn't be using linear. Once you get to where a buck (or boost) works well, further marginal differences in voltage won't matter, and it becomes a big advantage of a buck. In the transition though I'd turn this around as a disadvantage. Lower Vf led's are bad because they require a buck, and because without one the setup on the whole becomes more and more inefficient.
If you sliced the dome off your xhp70 you would also get a little less lumen’s, but more throw.
Then I wonder if the new xhp50.2 is an upgrade or pretty much the same?
One advantage the xhp50.2 may have over a sliced dome xhp70 is less of a donut hole. Then again, I think the K60 has an OP reflector so it’s not likely to ever get a donut hole. On a SMO like my L6, the xhp50.2 may have a slight advantage.
Do you guys know off hand if a sliced dome xhp70 has a smaller or larger hot spot compared to a dome-on xhp50?
The XHP-50 and 50.2 fit on the XM-L footprint and can use the XM-L reflector. The XHP-70 is a much larger emitter physically, albeit not as large as the MT-G2. So comparing the 50 to the 70 is not an equal comparison. The 50.2 version has less gap between emitters but not as tight as the XHP-35 so there are still some issues. The 50.2 utilizes a phosphor covering much like the XP-G2 and as such it would be difficult to do a clean de-dome. Slicing the dome may well yield better throw but the center of the hot spot would still suffer from the gap between dies.
Well, it’s maybe not as straightforward as that. Depends on several factors. And for the record, whether or not the XHP-50.2 shows a donut hole is reflector dependant, it can still show that just maybe not as bad.
I got the new Eagle Eye X9 today and there was visible donut hole from the XHP-70 beam. I was about to put in an 50.2 and thought about slicing the dome off the 70. That made all the difference in the world in this particular light and it’s still making just over 3000 lumens at 4.84A so I’m thinking I might leave it just like this. Since djozz showed that the 50.2 maxes out around 5000 lumens and some 10A, it’s doubtful that it will best the 70 in this light without more extensive modification.
So there are always mitigating factors that make it more complicated than simply the emitter.
Edit: Maybe some expansion on my reasoning would help. The XHP-50.2 is similar in structure to the XP-G3. I don’t like the G3 for it’s beam profile and am finding a large similarity to this G3 in the 50.2. Sometimes it’s not all about power, given an ugly beam profile with odd color shifts the power levels aren’t winning it over for me. That’s just me though, and just my singular experience with my triple in a single triple reflector. I might find I love it in a different light or different reflector. Won’t know that until I try and I have a single 50.2 to play with…
Dang dunno offhand, but check the CREE datasheet and usually there's a mark on the underside to indicate anode or cathode side - I always forget which is + and - and always looked it up. Finally wrote it down, but my notes are @home . I sanity check all the new LED's now - used to be easier.
Put the two dots on the bottom, plus is on the right.
This is on the XHP-50.2 ONLY! Most modern Cree emitters have the plus on the side of the bond wires. The XHP series makes it more difficult to tell but of course you can always check the data sheet, way at the bottom end.
I have a question. I have a TN31 modded with a K40M driver (resistor mod) and a dedomed MT-G2 Copper added to the LED side and driver cavity + spring baypass. Would a XHP50.2 be an upgrade (throw or total output)?
The more amps those 2 see the more the 50.2 pulls away. At 5 amps for instance, the MG-T2 does about 2800 lumen and the 50.2 does 3500. So I’m sure you would gain brightness.
Since the 50.2 is a smaller die, you would probably gain throw as well.
In the areas of tint, my 5700k 50.2 has a pretty noticable yellow corona (looks square shaped as well). I just installed it though, so I’ll need to try it out at night and see how it looks. In my Convoy L6 with lowered smooth reflector I do see a slightly dark center. No where near as bad as my sliced dome xhp70, though. Reflector height plays a large factor here.
So yeah, I would think it is a good upgrade to the MG-T2.
The jury is still out whether it’s better or not than my sliced dome xhp70. I’ll post up hot spot size comparisons tonight.
Here is my light. A Convoy L6 with an SMO reflector that has the bottom removed. This drops the reflector down just under a millimeter (roughly). I use very thin copper shims to raise the emitter to fine tune the focus. Right now I’m using 2 shims. I reduced the camera ISO to better see the beam shape.
Here are the shots all from the same distance.
Now here is the same with me raising the reflector slightly. This would be closer to a stock SMO.
You can see that the first pic has a less defined edge on the hot spot, a smaller corona and a slight donut hole shape.
The second pic has a more defined edge, larger corona and less donut shape. This looks better in real life, but does not deliver the highest lux. If your chasing lux then the first picture will give you the highest readings.
Here are the same basic pictures as above taken with a more realistic ISO setting.
In real life the donut hole in the first pic is quite subdued, but you kind of notice it a little as you move the light around. The second pic it’s less noticable and a nicer looking beam in general.
I will compare this xhp50.2 to my sliced dome xhp70 in just a little while. One interesting thing is that the corona on the xhp50.2 is noticably square shaped at close range. It’s kinda odd. Lol
