The reflector is 46.8mm in diameter at the opening and 47.4mm deep including the centering ring! Well made, heavy construction. The mcpcb is copper but I don’t know if it’s DTP at this point. The driver is one of those that has the vertical board coming off the 20mm contact board, haven’t taken it out yet but I can see the inset feet from the board on the contact board. Not glued.
The SS bezel is 59 grams naked, not even an o-ring on it!
25mm very thick copper mcpcb, it’s about a mm larger diameter than a 26mm MaxToch mcpcb but about 50% again thicker, so I decided to slice the dome off and try it before putting an XHP-50.2 in it. And this slice removed the dark center in the hot spot while tightening the hot spot noticeably. I lost some lumens, with the two LG MJ-1’s at 75% charge it is making 2711.7 now.
I still didn’t remove the driver. It seemed snug in there with the retaining ring removed and I was going to remove the switch retaining ring but it’s blackened and I didn’t want to take a chance on scarring it up just yet. The wires are too thin, I know that much, and spring bypasses would of course assist. I’ll get the driver out, just taking it slow as I really like my Eagle Eye lights and I don’t want to mess anything up in haste on this one.
I took it outside to check out the beam profile and slicing the dome made all the difference… no dark spot in the center at all. I can see black cows out at about 200-225 yds laying in the dark grass. Not bad at all.
Why exactly should I have to wait around and time my presses so precisely? I turn my L6 on, it’s on low, I want it to be on turbo, three presses is all it should take. Inevitably, however, I’m treated to amateur discotheque hour.
The copper mcpcb is among the thickest I’ve seen, looks to be about half again thicker than an MaxToch. So that is good. The small finned section where the switch is just so happens to be exactly where the heat is going. Also good. I didn’t get a read on how thick the emitter shelf is, but when I took it outside it was warming up but didn’t get hot in the few minutes I had it on before the bugs discovered the light. (It’s June Bug season here, big fat whoppers slamming into everything. Lousy flyers.)
I’ll get a better idea how it takes the power this weekend.
My beam shot alley is totally screwed. My Dad’s brother bought a 5th wheel trailer and decided it’s too big for him, so Dad let him park it out here while he tries to sell it. Dang thing is 34’ long and 13’ high! Of course, he parked it right smack in the middle of my side yard where I shoot beam shots. UGH! I need to look and see if I can shoot a hot spot past it, the big white trailer will sure show up in the night though. lol
Edit: Beamshot alley is clear, the trailer is North of where I need to shine by enough of a margin. Lightning tells me to wait til tomorrow night…
Tom, the X9 will surprise you… it’s got good power but it’s silly lightweight, like it makes you think it doesn’t have cells in it when you pick it up. About to use mine to walk the trash can down to the road for morning pick-up. Even my wife asked me if it had batteries in it the first time she used it.
When this X9 will be lower in price iit will be a real concern for the L6/S70S.
Lightweight, classy design and same lumens (but less throw, but neither L6 and S70S are thrower so…)
The X9 just so happened to show up today! Wow, it feels so small in a way. Thermally it's an odd design - no fins, thin body where mass and fins are needed the most. Also some sharp edges on the SS bezel, but the thin design makes it an easy carry for a 2 cell bigger style light.
The box is very well padded,light seems in exc. condition
It's very comfortable in the hand because you are not holding a massive head light where the switch is. It's somewhat wasteful in length but comfortable to hold. I gotta get it setup with cells and play some.
Guys, you mind sharing some pics with us ?
I’m interested with this one and would want to put things in perspective with, say, some other known models maybe ?
I find flashlights in hand pictures really useful too
Sorry no pics yet. I ordered the N4 3C, but it's hard to believe it's an N4 bin, but the tint looks to be a great NW - milky white consistent tint through all zones of the beam.
Tail amps on LK 5000 cells: 4.7A, lumens: 2,850 @start, 2,770 @30 secs, 36 kcd (380m) measured at 5 m
This is well under the 3,800 lumens rating. I'm not familiar enough with what 4.7A should get you with an N4 bin, but for it to be 73% in my testing of what it's rated is pretty far off. For example, last night, along with the X9 I measured Lumintop SD26 and SDMini lights and both measured higher than their ratings: ~1,060 lumens on each with both rated at 1,000 lumens.
