the bigger ones can be used as 1S or with a LDO for more cells
of course other sizes like 26 or 30mm are possible like in TA thread
as you pay for board surface 3 30mm cost 7$, if I only build one I got 2 boards that want to be payed
for SRK each PCB costs 5.5$, so if I make only one 11$ of boards unused
its not the problem to make other sizes as they are done by hand,
just Oshpark send minimum of 3 PCBs, so its a cost factor if I only make one and pay for 3 boards
Ill ask Tom E,
but as its Narsil triple v1.3 likely fixed
a lot features like temperature stepdown added to the original Fet+1*7135
and those boards come with pad for a LDO
The 30mm 2S Narsil works with Eswitch and fits the L6
It can be used with Zener Mod, but you need to lock out the light because that has a quite high parasitic drain, the LDO reduces the parasitic drain so no lockout needed
Narsil can be modified so the light gets on at Turbo if you want to use the forward switch tactical, similar to Klarus XT series lights
