Ok, great thanks.
Have you measured the result and of course, was it worth it?
Ok, great thanks.
Sukoi: KawiBoy1428:What about a 30mm size like these in a 1S with Narsil?
Could that it be used in utorch ut2?
Made one , 30mm LDO is the right driver .
You don’t need LDO for 1S…… 2-3-4S e-switch of course Zener for mechanical button switch.
I would be in for 5x17mm Bistro at least
Hi Lexel, I would like to buy one 15mm and one 17mm Narsil.
Thanks for offering this for us folks in Europe
I’d be in for 2 x 17mm bistro.
Edit with a long spring.
Awesome!! Thank you for doing this!
I would like:
3 x 17mm Bistro
1 x 30mm, 2S, Narsil (is this what I would use for a L6 mod?)
The 30mm 2S Narsil works with Eswitch and fits the L6
It can be used with Zener Mod, but you need to lock out the light because that has a quite high parasitic drain, the LDO reduces the parasitic drain so no lockout needed
Narsil can be modified so the light gets on at Turbo if you want to use the forward switch tactical, similar to Klarus XT series lights
Please choose which spring you prefer the short or long
Short spring on both 15 and 17mm requested above please
I’ll take (3) 1S 30mm Narsil drivers please!!
And (3) 2S 30mm Narsil LDO drivers too if possible!
No springs or wires needed, thanks Lexel!
Ill take one 30mm configured for 2S with narsil firmware. No springs needed.
Hi I will take 1x 17mm Bistro long spring.
Forgive my ignorance… I’m not sure what the pros/cons are of the various options. Basically I would like minimal parasitic drain, most efficient low and mid modes, Narsil ramping, and of course FET turbo.
What is your recommendation?
Also, can the tail switch be used for lockout?
Thank you for providing this service.
I’ll be in for two 17mm (short spring) with latest Narsil Triple, looks like Tom E just uploaded v1.4 tonight.
I think the standard mode groups should be fine and 55C sound like a good stepdown.
I plan on putting one in a skilhunt h03 headlight. Would it be possible to operate the indicator led inside the e-switch with this driver?
I did put a 21mm inside my Skilhunt H03
If the driver is configured to enable indicator LED it works adding a 4.7kOhms resistor to pin 7 like this
I can add that resistor already
If you want that I configure the driver add 1$ and instructions
I will take one 30mm LDO 2s with Narsil then
No spring needed
I’d like one Narsil 20mm with short spring (okay for e-switch, right ? )
I plan to put it in my fried HC30, maybe with a triple 219C.
electricjelly:Thank you for providing this service.
If the driver is configured to enable indicator LED it works adding a 4.7kOhms resistor to pin 7 like thisI can add that resistor already
Your right, looks like I’ll need 21mm boards. The second driver is for an older skilhunt H02, looks like 21mm board also.
So I’ll take two 21mm boards and yes, please configure one of them with the resistor and instructions.
Are you using the default mode groups in you headlight? If you have any changes in the mode groups that work better for headlight usage please let me know.
Thank you very much.
I did modify the modegroups a bit so they fit better to the 7135*5+1 I did put in my skilhunt H03
For a fully equipped 7135*7+1 the standard mode groups will be OK
You can look in the Narsil code and tell me changes if you want
As the light has a DTP star you could also get a higher temperature value when the stepdown kicks in, as it dont get too warm holding in your hands
Hi Lexel I did requested for 1x 17mm bistro with long spring but i don’t see my name in the list.
