making a small batch of Texas Avenger "TA" Drivers fully tested running Bistro or Narsil, Clicky or E-switch, SIR800
249 posts / 0 new
Lexel
Lexel's picture
Last seen: 13 hours 37 min ago
If you want fully assembled and tested drivers reply here
Flashed and thermal calibrated MCUs are included.
This batch will be reflow soldered
Today 200 AMC7135 arrived and from last drivers I had 2 boards over
so i could fit the rest of parts to them, 21mm fully reflow soldered, 17mm resistors and Attiny25 hand soldered
need to use less paste especially on the FET, and add solder with iron to fets pad, as its not easy to push it down and hold still till the solder gets solid
you can choose soldering paste
recommended
with lead 62% tin, 36% lead, and 2% silver
*or *
lead free 96.5 % tin, 3% silver, and 0.5% copper
Oshpark has all boards from first order shipped, so it wont be long till first drivers go into production
Check the Excel screenshot if the information to your order is right, I keep it up to date dayly
Availiable options:
there are different sizes availiable 15, 17, 20, 21 and 22mm
those are cheap on the PCBs from Oshpark so I may end up with some unused boards
30mm and bigger are possible as well, but add costs depending on size
Information about this driver here
http://budgetlightforum.com/node/48447
There will be a very good SIR800 FET used
You can choose a custom number of 7135 less than the maximum
can be equipped with Attiny 25 or 85
running Bistro
or Narsil Triple v1.4 latest version with fixed bugs
Tom E wrote:
For Lexel or anyone interested, I’m figuring out the support for adding R1/R2 LVP (2S cells) to NarsilTriple, but it will mean losing the Indicator LED support, so must be a compile switch then.
Drivers will be fully tested before shipped
Narsil v1.4 driver will be thermal calibrated as well
you can choose the temperature for stepdown,
the time for stepdowns depends on the lights size/heat, a Pocket rocket off a 14500 high drain will need a shorter time than a Convoy L6
standard will be 55°C
standard time between steps will be 45s
temp calibration with hairdryer
custom mode groups can be programmed for a small price depending how much to modify
ATM there are 2 main options for 2S Narsil for lights like Convoy L6
Narsil v1.2 utilising low voltage protection on pin7
Narsil v1.4 utilizing indicator LED on Pin 7, has some bugfixes and temperature protection
but Tom E is working on v1.5 where it is possible to choose between indicator pin and LVP
For 2S lights that use only a sideswitch or you dont lock out the light all the time a LDO is needed,
the zener mod has a very high parasitic drain
2S LDO is availiable for 17, 21, 22, 26, 30 and 46mm
2S Zener Mod is availiable on all sizes
efficiency advantage over Fet+7135*1
this is just an example, keep in mind that triple hotrods get more gain than a single emitter light
Springs for 15 and 17mm Board will be phosphor bronze
long
http://www.kaidomain.com/p/S025268.Silver-Coated-Phosphor-Bronze-Spring-...
OR
short
http://www.kaidomain.com/p/S020404.Silver-Coated-Phosphor-Bronze-Spring-...PCS
For larger boards I recommend those springs
http://www.kaidomain.com/p/S024318.DIY-Gold-Plated-Battery-Driver-Contac...
for 20mm and bigger a larger diameter spring can be used
Prices:
15-22mm
the Bistro Attiny25 12.5$
the Narsil Attiny85 14.5$
spring 0.3$
30mm add 1.5$
Zener mod add 0.7$
LDO 1.5$ 21mm and bigger only
LDO 17mm add 3$ more expensive part
Bigger diameter than 30mm I will build only if more than 3 drivers are requested
SRK size add 4.5$ if full 3 get ordered, if only 2 add 7.25$
SRK Size with more than 7 AMC7135 add 1$
2$ envelope shipping worldwide below 50g
tracking adds 3$
Insurance and tracking adds 6$
1€ Germany below 50g
Orders:
1 staticx57: 5× 17mm Bistro 1S
2 KawiBoy1428: 2 30mm 2S LDO E-Switch only with Narsil SD75, 2 30mm 1S Narsil for UT02, 2 30mm Narsil LDO E-Switch/Push button, no springs 70°C, LVP disabled on all drivers
3 giorgoskok: 5x FETs and 3x Attiny 85
4 Caleb: 3× 17mm Bistro 1S, one 30mm LDO Narsil
5 lampyris: one 15mm Narsil short spring, one 17mm Narsil short spring, 60dC 60s turbo
7 electricjelly: 1 Bistro 1S short spring, 1 Narsil 1S 21mm short spring 1 with indicator 60°C 40s turbo 1min, one Narsil 1S 21mm without resistor 60°C 30s 30s Tturbo, one 30mm Narsil 1S with indicator resistor 65°C 60s stepdowns
8 Vinte77: two 17mm Bistro 1S long spring
9 Tjhosan: 30mm LDO Narsil no spring 70°C, 17mm Bistro LDO piggyback
10 MrJohnny: one 17mm Bistro 1S long spring
11 JasonWW: one 30mm LDO Narsil short spring with indicator and power LED resistors
12 tekwyzrd: Narsil 38.5mm 60°C 1 min with LDO seperate
13 BobbyMK: one 30mm LDO Narsil, 1 Narsil 38.5mm 1S 90°C 1 min 90sec turbo
14 Sukoi: 2 30mm Narsil LDO large springs tactical 65°C, 1 30mm Narsil 1s large spring 65°C, 1 22mm Bistro 1S long spring, 1 17mm bistro 2s zener mod long spring, 1 17mm Narsil 1S short spring, 1 17mm 1S Bistro short spring
15 ×3: Narsil 1S 20mm with short spring
16 khas: two Narsil 1S 21mm short spring, 20mm 1S Bistro
17 Lipfit2000: two Narsil 1S 17mm or 21mm SRK Piggyback
18 mattlward: one 2S Zener 17mm Bistro, one 17mm Bistro 1S, 2S 22mm Bistro Z-diode
19 lostheplot: one 1S 22mm Narsil large long spring, one 1S 21mm Bistro large long spring
20 driver repair: two Klarus XT11GT 17mm Narsil
21 TheOnlyDocc: 3 FETs and one Attiny 25
22 Kaizer: 1S 17m Bistro, 1 30mm Narsil 2S LDO tactical 65°C L6
23 Sledgestone: 2 17mm 1S Bistro Infineon FET
according to this list there are 54 drivers taken and 3 reserved
originally ordered parts for 50 drivers,
but I got some more parts ordered so up to 59 can be build so its not to late to join in
I can do some more drivers but I have limited parts and boards sizes
Edited by: Lexel on 04/26/2017 - 19:09
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 hours 21 min ago
What about a 30mm size like these in a 1S with Narsil?
http://www.mtnelectronics.com/index.php?route=product/product&product_id...
KB1428 “Live Life WOT
Lexel
Lexel's picture
the bigger ones can be used as 1S or with a LDO for more cells
of course other sizes like 26 or 30mm are possible like in TA thread
as you pay for board surface 3 30mm cost 7$, if I only build one I got 2 boards that want to be payed
for SRK each PCB costs 5.5$, so if I make only one 11$ of boards unused
its not the problem to make other sizes as they are done by hand,
just Oshpark send minimum of 3 PCBs, so its a cost factor if I only make one and pay for 3 boards
Tjhosan
Tjhosan's picture
Last seen: 1 year 2 days ago
Is narsil “fixed” for 2s now? like low voltage warning.
If yes i could be interested in a 30mm one with a LDO
Lexel
Lexel's picture
Ill ask Tom E,
but as its Narsil triple v1.3 likely fixed
a lot features like temperature stepdown added to the original Fet+1*7135
and those boards come with pad for a LDO
KawiBoy1428
I’ll take (3) 1S 30mm Narsil drivers please!!
And (3) 2S 30mm Narsil LDO drivers too if possible!
Sukoi
Last seen: 7 months 1 week ago
Could that it be used in utorch ut2?
giorgoskok
giorgoskok's picture
Last seen: 1 week 6 days ago
Made one , 30mm LDO is the right driver .
Lexel
Lexel's picture
Tom E has fixed the LDO low voltage not yet in Narsil triple
in Narsil 2 channel its already implemented
Tom E wrote:
Hhhmmm. Fixed? Depends on the board/usage. I’m using a fully configured “Narsil” 2 channel version (not 3) with a properly configured LVP support for a 360K r1, 47K R2 for 2S, LDO of course, and it’s working great.
It’s in a v1.3 not yet posted though.
No, sorry, no R1/R2 support yet in the triple version.
Tom
I am sure it will be in triple soon
I will give this batch some time to get enough people in to get enough to get free shipping from Digikey
Sukoi
Ok, great thanks.
Have you measured the result and of course, was it worth it?
KawiBoy1428
You don’t need LDO for 1S…… 2-3-4S e-switch of course Zener for mechanical button switch.
staticx57
Last seen: 1 hour 40 min ago
I would be in for 5×17mm Bistro at least
lampyris
lampyris's picture
Last seen: 2 years 5 months ago
Hi Lexel, I would like to buy one 15mm and one 17mm Narsil.
Thanks for offering this for us folks in Europe Smile
vinte77
Last seen: 1 month 2 days ago
I’d be in for 2 × 17mm bistro.
Edit with a long spring.
Caleb
Caleb's picture
Last seen: 2 hours 49 min ago
Awesome!! Thank you for doing this!
I would like:
3 × 17mm Bistro
1 × 30mm, 2S, Narsil (is this what I would use for a L6 mod?)
Lexel
Lexel's picture
The 30mm 2S Narsil works with Eswitch and fits the L6
It can be used with Zener Mod, but you need to lock out the light because that has a quite high parasitic drain, the LDO reduces the parasitic drain so no lockout needed
Narsil can be modified so the light gets on at Turbo if you want to use the forward switch tactical, similar to Klarus XT series lights
Lexel
Lexel's picture
Please choose which spring you prefer the short or long
lampyris
lampyris's picture
Short spring on both 15 and 17mm requested above please Beer
KawiBoy1428
No springs or wires needed, thanks Lexel!
BobbyMK
BobbyMK's picture
Last seen: 3 days 8 hours ago
Ill take one 30mm configured for 2S with narsil firmware. No springs needed.
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
MrJohnny
Last seen: 2 years 4 months ago
Hi I will take 1× 17mm Bistro long spring.
Caleb
Caleb's picture
Forgive my ignorance… I’m not sure what the pros/cons are of the various options. Basically I would like minimal parasitic drain, most efficient low and mid modes, Narsil ramping, and of course FET turbo.
What is your recommendation?
Also, can the tail switch be used for lockout?
electricjelly
electricjelly's picture
Last seen: 2 days 20 hours ago
Thank you for providing this service.
I’ll be in for two 17mm (short spring) with latest Narsil Triple, looks like Tom E just uploaded v1.4 tonight.
I think the standard mode groups should be fine and 55C sound like a good stepdown.
I plan on putting one in a skilhunt h03 headlight. Would it be possible to operate the indicator led inside the e-switch with this driver?
Lexel
Lexel's picture
I did put a 21mm inside my Skilhunt H03
If the driver is configured to enable indicator LED it works adding a 4.7kOhms resistor to pin 7 like this
I can add that resistor already
If you want that I configure the driver add 1$ and instructions
Tjhosan
Tjhosan's picture
I will take one 30mm LDO 2s with Narsil then Smile
No spring needed
-X3-
-X3-'s picture
Last seen: 21 hours 17 min ago
I’d like one Narsil 20mm with short spring (okay for e-switch, right ? )
I plan to put it in my fried HC30, maybe with a triple 219C.
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
electricjelly
Your right, looks like I’ll need 21mm boards. The second driver is for an older skilhunt H02, looks like 21mm board also.
So I’ll take two 21mm boards and yes, please configure one of them with the resistor and instructions.
Are you using the default mode groups in you headlight? If you have any changes in the mode groups that work better for headlight usage please let me know.
Thank you very much.
Lexel
Lexel's picture
I did modify the modegroups a bit so they fit better to the 7135*5+1 I did put in my skilhunt H03
For a fully equipped 7135*7+1 the standard mode groups will be OK
You can look in the Narsil code and tell me changes if you want
As the light has a DTP star you could also get a higher temperature value when the stepdown kicks in, as it dont get too warm holding in your hands
MrJohnny
Hi Lexel I did requested for 1× 17mm bistro with long spring but i don’t see my name in the list.
Lexel
Lexel's picture
Narsil Triple v1.4 got released some bugs are fixed and temperature management got updated
https://drive.google.com/drive/folders/0B1IxYZuk4DjcUERkZGpmdnBsWFk?usp=...
Tom E wrote:
Ok, v1.4 of the triple is up now. Find the files in my google drive share: drive.google – NarsilTriple v1.4 (link is external)
Let me know if you find it all ok. Can’t recall how familiar you are with it, but a notes.txt was updated. Turns out the “bug” wasn’t really so bad in NarsilTriple, but I did update how temp regulation works now – I think it’s better, dropping amps in lower increments, longer delay between drop adjustments.
The V1.3 manual still applies, accept for section describing temperature regulation – I’ll have to update that part.
Also removed the project folder under NarsilTriple (was a NarsilTriple folder under NarsilTriple), now the project is in the same parent folder as the solution file.
Tom
electricjelly
I will trust your judgment since your familiar with the host and driver. Please change the stepdown temp to what you feel is best. If you can make improvements on the mode groups I’ll trust your judgment on that as well. Otherwise we can keep them stock. Thanks
