Ill take one 30mm configured for 2S with narsil firmware. No springs needed.
Google Drive: Sign-in
Access Google Drive with a Google account (for personal use) or Google Workspace account (for business use).
Hi I will take 1x 17mm Bistro long spring.
Forgive my ignoranceā¦ Iām not sure what the pros/cons are of the various options. Basically I would like minimal parasitic drain, most efficient low and mid modes, Narsil ramping, and of course FET turbo.
What is your recommendation?
Also, can the tail switch be used for lockout?
Thank you for providing this service.
Iāll be in for two 17mm (short spring) with latest Narsil Triple, looks like Tom E just uploaded v1.4 tonight.
I think the standard mode groups should be fine and 55C sound like a good stepdown.
I plan on putting one in a skilhunt h03 headlight. Would it be possible to operate the indicator led inside the e-switch with this driver?
I did put a 21mm inside my Skilhunt H03
If the driver is configured to enable indicator LED it works adding a 4.7kOhms resistor to pin 7 like this
I can add that resistor already
If you want that I configure the driver add 1$ and instructions
I will take one 30mm LDO 2s with Narsil then
No spring needed
Iād like one Narsil 20mm with short spring (okay for e-switch, right ? )
I plan to put it in my fried HC30, maybe with a triple 219C.
Your right, looks like Iāll need 21mm boards. The second driver is for an older skilhunt H02, looks like 21mm board also.
So Iāll take two 21mm boards and yes, please configure one of them with the resistor and instructions.
Are you using the default mode groups in you headlight? If you have any changes in the mode groups that work better for headlight usage please let me know.
Thank you very much.
I did modify the modegroups a bit so they fit better to the 7135*5+1 I did put in my skilhunt H03
For a fully equipped 7135*7+1 the standard mode groups will be OK
You can look in the Narsil code and tell me changes if you want
As the light has a DTP star you could also get a higher temperature value when the stepdown kicks in, as it dont get too warm holding in your hands
Hi Lexel I did requested for 1x 17mm bistro with long spring but i donāt see my name in the list.
Narsil Triple v1.4 got released some bugs are fixed and temperature management got updated
Ok, v1.4 of the triple is up now. Find the files in my google drive share: drive.google - NarsilTriple v1.4 (link is external)
Let me know if you find it all ok. Canāt recall how familiar you are with it, but a notes.txt was updated. Turns out the ābugā wasnāt really so bad in NarsilTriple, but I did update how temp regulation works now - I think itās better, dropping amps in lower increments, longer delay between drop adjustments.
The V1.3 manual still applies, accept for section describing temperature regulation - Iāll have to update that part.
Also removed the project folder under NarsilTriple (was a NarsilTriple folder under NarsilTriple), now the project is in the same parent folder as the solution file.
Tom
You can look in the Narsil code and tell me changes if you wantAs the light has a DTP star you could also get a higher temperature value when the stepdown kicks in, as it dont get too warm holding in your hands
I will trust your judgment since your familiar with the host and driver. Please change the stepdown temp to what you feel is best. If you can make improvements on the mode groups Iāll trust your judgment on that as well. Otherwise we can keep them stock. Thanks
Iām a noob with drivers, but I would like to get one driver for my Convoy L6:
30mm, 2S, LDO, Narsil, short spring.
I plan to add a clear side switch with an led to indicate when the rear switch is on.
I would also like the option to have it turn on in turbo with the rear switch.
Are both of those easily done with the normal Narsil or does it require special work?
Thanks
Please add the indicator led option on my driver aswell
Interested in an attiny 85 narsil in the size closest to fitting a courui d01.
Thanks
The turbo on rear switch is just a few lines different code.
for the illumination of the sideswitch when rear switch is on I can add a 4.7kOhms resistor to the driver
Just keep in mind that a the driver supports as well a indicator LED you could add a green as power LED and a red indicator LED to the sideswitch
the indicator LED can be wired on Pin 7 with an additional resistor
I can add for both LEDs a resistor to the driver for 1$
Which size has the driver and how much space is in the lights body so parts dont collide with it
It is possible just to piggiback a small driver on the original board
there is a 38.5mm TA driver design that could fit
giorgoskok: Sukoi: KawiBoy1428:What about a 30mm size like these in a 1S with Narsil?
Could that it be used in utorch ut2?
Made one , 30mm LDO is the right driver .
Ok, great thanks.
Have you measured the result and of course, was it worth it?
Of course , now itās an awesome light . First , itās running Narsil and second , itās making 292kcd with a dedomed xp-g2 .
giorgoskok:Made one , 30mm LDO is the right driver .
You donāt need LDO for 1Sā¦ā¦ 2-3-4S e-switch of course Zener for mechanical button switch.
Made the driver with LDO for low parasitic drain
More than 2S will burn the 7135 to hell
KawiBoy1428: giorgoskok:Made one , 30mm LDO is the right driver .
Yes on this FET-7135 driver, but I donāt run 7135ās only Straight up FETās 2-4S no worries! Never used a LDO for a 1S 3v either and the Zener in 1S screws with the UI. But thanks!
