I will trust your judgment since your familiar with the host and driver. Please change the stepdown temp to what you feel is best. If you can make improvements on the mode groups Iāll trust your judgment on that as well. Otherwise we can keep them stock. Thanks
The turbo on rear switch is just a few lines different code.
for the illumination of the sideswitch when rear switch is on I can add a 4.7kOhms resistor to the driver
Just keep in mind that a the driver supports as well a indicator LED you could add a green as power LED and a red indicator LED to the sideswitch
the indicator LED can be wired on Pin 7 with an additional resistor
I can add for both LEDs a resistor to the driver for 1$
Yes on this FET-7135 driver, but I donāt run 7135ās only Straight up FETās 2-4S no worries! Never used a LDO for a 1S 3v either and the Zener in 1S screws with the UI. But thanks!
Yes, please add both resistors. That will help me out.
Will I need to change the firmware code myself? Iāve never done this.
I assume that once the new line of code is added, the rear switch turning on will made the light come on in turbo, then I can press the side switch to turn it off to standby. Then it will function like narsil normally does, ramping up and down and turning off back to standby. Power LED stays lit.
Turning off/on the rear switch resets everything and makes turbo activate again.
I will flash your driver set to highest mode instead the 2 low blinks on drivers when you are requesting it.
As well other temperature for stepdown is possible, default will be 55Ā°C depending how the light is build the head gets hotter than this value.
So every time you turn on the light with rear switch you will get a lot of light, so you could morse your SOS on your own,
a short press and the main LED turns off the power LED still on,
long press to ramp down or enter mode selection
I thought about a short video to explain how to operate and enter config mode of Narsil
Basically you can configure Narsil as you wish, ramping or modes, Mode Memory, indicator LED, Monn mode ON/OFF, brightness of moon,
just look in the manual its well written, after done the setup one time you get it, its similar to Bistro but a little different
after configuring 3 drivers for me its quite intuitive UI in the setup mode
This sounds great. Let me know when your ready to order it. If you only have 1 or 2 of this driver instead of 3, I might order one more so your not left with too many unsold drivers. Maybe I will buy another L6 to put it in. Lol
O.P. got updated with some other options for 20mm and bigger sizes its likely to choose a spring with bigger diameter, that has less height when compressed
The extra boards on the 30mm are pretty cheap, the most comes from parts costs
only on 46mm SRK sizes the PCB price gets close as the parts for it costs, so it makes no sense to sell only one of this size and have 2 boards for 11$ left
I am not planning to stock those drivers in different sizes, just produce what is requested here and order some more of the 17 and 30mm,
as I am sure there will be more requests for those sizes as I wait for the parts
Had a short chat with Tom as there were no clear comments about the new startup configure lines
Seems LVP for 2S configuration will be implemented in Narsil triple,
as Narsil for the Q8 is similar to Triple v1.2 where the LVP for 2S works he can port the part with LVP and temp calibration to the triple easier
I forgot to show my old used crappy test bench for drivers
