Any recommendations for camp lantern
Not a fan of lanterns
I’d buy a $30 skillhunt h03 instead or a small 18650 light and some dc fix .
I use this ,it has convenient “mount system” for large tents. And really long run time. I can not discharge it even in 2 week expedition.
There is the same model at allexpress/taobao.
Or BW-LT5 with 1*18650 in it.
How would you fix a diffuser to it?
Apply the dc fix to the lens.
I’m surprised that nobody has yet to mention warm white color temps, around 2700-3000K (one mention of neutral white). I find warm white to be an absolute must for a camp lantern, it is so pleasant and soothing. Even neutral white looks cold and glaring at night, especially with a fire nearby giving off that beautiful warm glow.
I know we all like flashlights, but if you expand that to LEDs in general, warm white LED rope string lights are a great way to light a campsite. They have the advantage of being able to light the area with diffuse light, and without the bright point that will glare you when you accidentally look straight at the Lantern eventually.
But this just diffuses the beam and doesn’t turn it into a latern.
the proprietary battery kills all interest on that one.
i run stuff like that on free laptop pulls.
and if goal zero folds you are stuck.or they drop the line and you cant buy a replacement anywhere.
The Fenix CL25R comes with a protected 18650, and you can get 20% off at fenixlighting.com using the code “newmember20” ($48). The Fenix has NW emitters. The clones are cool blue.
I second using a diffuser.
I like these silicone diffusers at banggood. They are 1.99, fit on convoy s2 perfectly, pack down, weigh almost nothing. I string up a ridge line right over camp and hang my convoy right off it. It lights up camp nicely.
Hi, can I know what lumens you run it on? Also would the diffuser fits the BLF A6?
I use a medium mode mostly, maybe 300 lumens. Ive also left it on very low moonlight all night. Once your eyes have adjusted its actually a very usable nightlight.
They will fit the blf a6 great. They are a stretchy silicon, so they can accommodate pretty much any 18650 tube light.
These?
http://www.banggood.com/LED-Flashlight-Silicon-Rubber-Light-Cover-Diffusers-20-24mm-p-86721.html
Yes, those ones. I must have messed up the link. I’ll edit it. Thanks
Thanks! Much appreciated.
Been looking around for a budget camp lantern that’ll last the whole night. Don’t think it’s possible without burning a hole in the wallet.
The A6 might just be the ticket.
I have one similar to this:
https://www.amazon.com/dp/B00XC5T0RE/ref=cm_sw_r_cp_awdb_n7h9ybVX4S9GX
and one of these I bought for my daughter for camping:
https://www.amazon.com/dp/B00YDQJ18E/ref=cm_sw_r_cp_awdb_h.h9ybPQSQ6ZP
Both of them work great.
The Streamlight Siege I posted above is rated at 37 hours on low (50 lm), which stiill gives very usable output.
Hi Pete, thanks for the recommendation, but I’m in the other part of the world. Shipping’s gonna be a killer ordering from Amazon. Also would prefer to run it on 18650 if possible.
Got it.
Fyi, i was using a DQG Tiny 18650 with a diffuser cap as a night light last night. The 3.5lm output is very usable and should last hundreds of hours on a single 18650.
I have several of these Energizer WeatherReady lanterns that I picked up in the clearance rack of Home Depot for less than $5. They come with 3 AA batteries, and by removing a carrier, will accept 3 D cells. I plan on playing with one of them to see if I can mod it to take 18650 cells. A quick look at it just now leads me to believe that there is room in the compartment length wise, so all that is needed is a revised carrier with the proper battery terminals.
It may not be aluminum or fancy, but I’m pretty sure that it will give you the run time you are looking for.
How about the Blitzwolf BW-LT5 PRO lantern?
