Let me rephrase:
There is current through the battery tube from tail to head.
But since the battery tube has very very low electrical resistance, there’s hardly any voltage between tail and head, so i expect electrolyses is negligible or just not happening.
The picture shows problems on the edges.
Probably damaged anodization, and so the seawater just has a go with the aluminium.
The result is porous salts which absorb seawater so that the process continues on dry land.
Those pics are from a 2012 thread. The damage you see is from galvanic corrosion and electrolysis when this light is submerged in salt water. Basically it forms a cathode / anode and the salt water is the electrolytic solution. It only happens when this light is turned OFF (IIRC) though because the electrical circuit when turned on becomes the current path of least resistance. The condition is worsened for spots where the anodize is scratched off or etched off. Thread here… skip ahead to page 5-7. IIRC a couple different members were complaining about the same thing.
Good read, and answers some questions I had about all this.
Specifically, even with a decent tailcap switch, if it’s tightly connected to the body, the only breakpoint is between the internal switch and the (-) end of the cell. The whoooooole head+body+tailcap should be one long electrically-conductive piece, all at 0 potential. So like a shielded cable, the entire length would be one long 0.
And unless you turn your flashlight into an electron-gun, it’s only 1 electrode in a salt-bath, and no fizzing should occur.
That’s why, a design like this one, no switch in the tailcap, screwed on tightly, no reason to twist/untwist anything, and a magnetic slider, nothing should make a 2nd connection/electrode. (Think of way bigger version of an Astrolux A01 1-piece body, only no twist-head, but one solid piece, internals (incl. battery) accessible only through the front bezel and lens, and an internal magnetic switch.)
That’s why, in the shown pix, what’s fizzing off of what. If it’s a 2-electrode system bathed in saltwater, 1 set of bubbles should be H2 and the other set should be O2.
By figuring out which is which, you can narrow down where’s the break in continuity, and see what can be done to fix it.
Point being, in a good solid conductor, there should be no fizzing of any kind no matter how much current is going through it, not unless the voltage drop is more than 1.23V.
There’s also the Ultrafire UF-S11 which looks like it might be a slightly more distant relative as it has similar proportions and a magnetic switch. Although it seems to consistently claim 3 modes instead of being infinitely variable: http://www.gearbest.com/led-flashlights/pp_576215.html
Back to the DV-S9. Does it take protected batteries and what is the beam spread like? Similar to the Starry Light DXM? How hot does it get if left along on maximum brightness?
Yeah, I got a protected 26650 that fits just fine. Big honkin’ springs on each end, so could probably take a ¼” spacer, too, and still fit.
Beam’s nice, pretty well-defined hotspot, decent spill, maybe the size of an XM-L in a C8. Wider than an XP-L HI C8, narrower than my (stock) VG10.
Bulb above my washing machine went out, had the DV-S9 tailstanding on full, using ceiling-bounce for light. Had it going about 10min straight, comfortably warm, nowhere near hot. It’s got a good amount of bulk to it.
Aha, it has a tailcap that acts as a twisty switch. I didn’t know that.
So, when it’s turned ‘OFF’ there’s the battery voltage between tailcap and body, and then electrolyses will happen.
I see i forgot to ask how the PWM is.
I assume they use PWM, and i know the big XHP70 diving lights with stepless slider is quite noisy (but not visible).
So how’s this one doing?
I like the concept.
Just received one of these. Looks decent to visual inspection and has survived a simple dunk+burn test. It has a low voltage cut-off and the light goes out suddenly and entirely with the battery showing ~3.2v after. It will not restart, even on low.
Light is a diffused focus similar in intensity and spread to my regular canister (4 LED, 2S2P 18650) dive light. Light intensity seems to stay decent down to cut-off.
I LIKE that the switch mechanism seems to be internal with just an external slider. First slider light I’ve had. I like it so far.
A bunch of the cheap dive lights with Hall sensors have external magnetic mechanisms with springs/magnets/occasionally ball bearings that are cheap steel and rust to garbage with saltwater use. They would be OK for shore use but are completely unsuitable for actual diving. Saltwater is death on them after awhile.
The 3xO-rings are good and seem to seal well. Hopefully the lens sealing mechanism is decent. It appears to be a single silicone O-ring which is typical of this price point.
I will be taking it for an empty test dive. If it survives I’ll put a battery in it and do a dive test. Then we’ll see if it can pass as a dive light.
Single O-ring is completely sufficient to seal……IF the design and execution are good. I carry a $800 camera+lens on dives that has a dozen small single O-rings sealing controls, one large one for the lens port, and a huge one for the camera housing back. They all work just fine if clean and in good shape.
The problem with cheap lights is often poor design, shoddy assembly, and/or lousy parts. That’s what I’m checking out here.
Then there is the operator factor…… :person_facepalming:
Took it for a single dive, saltwater, 56 feet max depth, about an hour exposure. No flooding, no sign of electrolysis. Day dive with decent ambient light so not optimal for evaluating the beam. It’s not as bright as my canister light, but it’s not bad. Would seem suitable for tropical use and as a backup light to a primary, even a primary for an occasional diver. Lasts over 3 hours with a 5000mA, 26650 in it (bench test). I got tired of watching it and it quit sometime after that, 3.24v remaining in the battery.
Seems to be almost the same light, minus 1 sealing O-ring, + a better end cap for a lanyard, which means it won’t end stand but for a “real” dive light this is not important.
Starry light DXM seems to be no longer available on GB.
Received the U’King light. In black it’s a bit more traditional looking. I did a quick run test in a glass of water and it came out dry. Then did a long run test using a Lii 5000mA > 4+ hours before it shut down.
One less sealing O-ring but I thinks that’s because the assemblers of the DV-S9 (mine anyway) put an ’extra one in the grooves behind the grooves machined for that. There is an adequate space and it doesn’t hurt anything. I may add one myself. Can’t get too much sealing for real diving.
Slider is a bit stickier even after greasing. Did not realize the ring behind the slider unscrews and the slider can come out.
Light intensity and spot seem identical to DV-S9.
Dive test pending, probably after the holidays.
I’m finding the green tint seriously ugly, otherwise it’s a great light. Mine doesn’t come on until I’ve screwed the tail cap on REALLY tight.
It seems that it would really benefit from an emitter swap, but from what has been posted it sounds as if it might be difficult to get at the interiors.
Not got the necessary skills to reflow an LED yet, but if there’s a way to get behind the lens without compromising the sealing, it would be something I’d be interested in at some point in the future.
Chances are the front ring unscrews. No idea if it’s glued. That will press down on the glass lens and there will be an O-ring, probably silicone, under that. After that it should be fair normal but the pill will have a Hall sensor on it. Getting it back together dive level water tight is another issue. Splash tight should be a snap.
I don’t have any issue with the tint. No green to me on either light. Maybe you got a poor bin. But color goes away fast underwater anyway, with reds going within about 15-20 feet, and working it’s way through the rainbow spectrum with depth. In the NW we have so much plankton in the water everything is pretty green all the time anyway no matter the depth. We just need lots of light.
I was referring to the DV-9. Compared with my other lights the beam definitely has a rather sickly greenish tint - will try to take some photos and post a vomparison.
Yes, I guess when it is actually used for diving, the tint won’t really matter too much. Not been scuba diving for nearly 30 years, but I do remember how red colours fade very quickly after a few meters.
