What did you mod today?
5466 posts / 0 new
CRX
CRX's picture
Last seen: 4 min 51 sec ago
Well since I blew the XHP50.2 in the 47’s Ti AA, I installed an MT-G2 instead LOL
deye223
deye223's picture
ok heres a noob question with the spring bypass is it because of poor contact or an electrical field problem with the coil .
I ask because I am seriously thinking of doing a hi power mod on a c8 just for wow factor I realise that heat will be a problem .
cheers D
LightRider
LightRider's picture
Last seen: 2 months 4 weeks ago
cheers D
Spring steal has resistance in it and will cause heat and voltage sag in high power mods:)
deye223
deye223's picture
thanks it makes sense now so is it worth doing on stock lights like c8s L2 and the like .
khas
Last seen: 6 days 10 hours ago
I was going to change the driver and the emitter in a Thorfire C8S, but ended up with only swapping the emitter to a XP-L HI because they changed the driver to 20mm in the version I got Ughh
EDIT :
I was going to put a BLF X5/X6 in it , but the driver size put an end to that plan.
Here is the new plan : 20 mm boost driver from KD and a XHP50.2 :
Enderman
Enderman's picture
Last seen: 13 min 40 sec ago
Looks way better with the G2 too Smile
djozz
djozz's picture
Last seen: 49 min 59 sec ago
But things happened to the stock OP reflector…
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
CRX
CRX's picture
Yup, I accidentally scratched it up with the burr from drilling out the hole so had to take off the coating with 0000 wool Blushing
pinkpanda3310
pinkpanda3310's picture
Last seen: 4 hours 4 min ago
mrheosuper wrote:
…the driver when open connect has Vbat voltage on the output( which mean i can mod the XM-l2 to XHP50, or even xhp70, whatever you want)
Does this mean you can swap to a 6v emitter without driver modification/swap ?
ToyKeeper
ToyKeeper's picture
Last seen: 32 min 4 sec ago
Today I taught a flashlight how to see. It turns out that LEDs can be used to sense light if you run them in reverse. So, all I had to do was solder on an “optic nerve” between its brain and its eye (MCU pin3 to LED-), tell it how to distinguish bright and dark signals (auto-calibrate), and then teach it something like Morse code.
The upshot of this is that you can configure it by pointing it at a phone or computer screen and playing an animated GIF or something for it to watch. (eventually, haven’t written the app yet)
… and the compiled code for it is shorter than the text of this post.
I’m not really sure yet if it’s actually a useful feature or just a silly gimmick, but it was fun to make.
CRX
CRX's picture
Nice Thumbs Up
MILSPEC
Last seen: 3 hours 50 min ago
BLF should start protecting the IP we are generating here and file patents! Unbelievable amounts of progress we are achieving here, seeing flashlights, apps or screens to program lights, … before you know you can talk to flashlights directly.
So proud to be part of this community.
Enderman
Enderman's picture
Patents for what, a flashlight?
Pretty sure that was patented a loooong time ago, lol.
lumenzilla
lumenzilla's picture
Last seen: 9 hours 45 min ago
Simple triple mod for Novatac 120T
www.lumenzilla.com
MILSPEC
Enderman wrote:
Patents for what, a flashlight? Pretty sure that was patented a loooong time ago, lol.
I am sure many of the technical solutions discussed and developed in various threads on here are 1) new and 2) not patented yet. The amount of innovation and curiosity here is mind-blowing.
i.e. “data exchange for contactless programming of flashlights via a light-emitting diode”
I didn’t do a patent search on these things but I do have access to various content providers at work.
Hunter
Last seen: 2 months 1 hour ago
This is very very cool, I saw this few months back in some youtube video, good chance it was on a shot show, they made software for pc where you set all preferences (modes) etc and then point the flashlight at dedidated part of the screen, it blinks out (black/white) “settings” and thats all you have to do to get custom modes.
I just hope this could be done with so widespread Atmel Tiny13A mcu.
LightRider
Well technically it will be either brighter or more effitient with a spring bypass but the difference probably wouldn’t be noticeable. That said, I bypass springs in all lights that run 2amps or higher.
kiriba-ru
kiriba-ru's picture
Last seen: 19 min 51 sec ago
Need a vlogger for machine accessories reviews
ToyKeeper
ToyKeeper's picture
Patents? Hah. I suspect the patents for this have already expired. It’s not new.
There’s a Lux-RC driver which does it, though IIRC it uses a dedicated light sensor instead of the LED. It’s used in the super-expensive BOSS light. And for some reason, it has a ridiculous limitation of only 4 modes. At that point, why bother? I know someone who has one, and he wishes it was more like his Convoy triple.
What’s actually new or different is:
  • It’s open-source.
  • It can work in any host without changes. Just make sure the driver has an “optic nerve”.
  • It runs on low-end MCUs like the tiny25 (sorry, doesn’t fit on tiny13).
I only have an early prototype so far, a proof of concept. All it does at this point is calibrate itself then read a list of modes to configure a mode group. It’s pretty janky. Don’t expect anything stable for a while.
I’m using an old BLF X5 prototype for testing (bistro tiny25 driver), totally stock except for the firmware and a small wire I added. Hopefully there will eventually be drivers which include this connection by default instead of requiring an extra wire. Otherwise though, it’s a totally normal build. Cheap stock host, normal MCPCB, only two wires going between the driver and LED(s). It likely wouldn’t work with multiple cells in series, and it shouldn’t work on UV or infrared lights, but those are really about the only restrictions.
One other thing to note… While all this complex onboard-programming stuff is fun and fancy, it’s not necessarily an upgrade compared to something simple and straightforward. I think Crescendo (ramping UI for clickies) is probably better overall, precisely because it’s so simple. And Narsil’s ramping UI is better still. Why bother with a dozen buttons and levers when you can do everything with a single knob?
Enderman
Enderman's picture
1) you’d be surprised at how much stuff you think is original and new has actually been patented already
2) I would suggest you do some research into how stuff gets patented. It requires money, lawyers, and a lot of time. It’s not just “I made this, plz patent”. Also a lot of stuff cannot be patented because it does not fit the requirements.
ToyKeeper
ToyKeeper's picture
The only real risk is if a corporation took it and didn’t give anything back… Fortunately, the GPL is pretty good at dealing with that. And publication of open code is good at invalidating bogus patents filed after-the-fact. Sure, there will be people who sell it for profit without contributing, but everyone is free to do that. And if anyone does make improvements, they have to share those improvements with everyone.
Would be nice if playing on BLF allowed us all to pay the rent, but that’s highly unlikely. At least it’s entertaining.
djozz
djozz's picture
That is way cool Toykeeper! Will be following this! Not for me btw, low-med-high no memory does not require much app-programming. But it sounds like a really fun developement!
link to djozz tests
Lexel
Lexel's picture
Last seen: 43 min 5 sec ago
Recycled a dead Imalent Light
Mod thread
http://budgetlightforum.com/node/53657
Tailcap driver removed and replaced with reverse clicky
modded tail cap the hard way
Contact board modded to accept unprotectec cells, sanded down
basically wow factor that they spell their own brand wrong, chineese engeneer who cant speak english?
Tube shortened 0.5mm so unprotected get more spring force, but also fits 70mm long protected
TA Bistro driver connected to contact board
ZozzV6
ZozzV6's picture
Last seen: 17 min 24 sec ago
I finished the Convoy C8 with Texas Avenger driver and XP-L2 led, AR coated lens and OP reflector. It is astonishing. In turbo it draws 9,3A and with OP reflector I really like the beam too. The Kaidomain DTP led base need a little filing because if you tighten the screws to head, it blocks almost the wire holes in shelf. The Bleeder resistor needs a little fine tuning because of short and medium taps timing take too long. Sorry for the beamshots. All pics created with phone.
All pics of building process can be found Here
Control shot
Bam! Smile
fenno
Last seen: 1 month 4 days ago
ZozzV6 wrote:
I finished the Convoy C8 with Texas Avenger driver and XP-L2 led, AR coated lens and OP reflector. It is astonishing. In turbo it draws 9,3A and with OP reflector I really like the beam too. The Kaidomain DTP led base need a little filing because if you tighten the screws to head, it blocks almost the wire holes in shelf. The Bleeder resistor needs a little fine tuning because of short and medium taps timing take too long. Sorry for the beamshots. All pics created with phone. All pics of building process can be found "Here":http://indafoto.hu/Zozz/convoy_c8_xpl2_texas_avenger !{width:70%}http://img2.indafoto.hu/3/9/134029_e227dae7eadb61c0adb17748b381f0a8/2499...! !{width:70%}http://img1.indafoto.hu/3/9/134029_e227dae7eadb61c0adb17748b381f0a8/2499...! !{width:70%}http://img1.indafoto.hu/3/9/134029_e227dae7eadb61c0adb17748b381f0a8/2499...! Control shot !{width:70%}http://img1.indafoto.hu/3/9/134029_e227dae7eadb61c0adb17748b381f0a8/2499...! Bam! Smile !{width:70%}http://img1.indafoto.hu/3/9/134029_e227dae7eadb61c0adb17748b381f0a8/2499...! !{width:70%}http://img2.indafoto.hu/3/9/134029_e227dae7eadb61c0adb17748b381f0a8/2499...
I have built yesterday one too. On a distance from 6 meters I have measured 68.400 Lux with dome on! How many lux you have measured?
greetings
ZozzV6
ZozzV6's picture
I’m at work now. Tonight I will measure it.
fenno
great Smile
ZozzV6
ZozzV6's picture
I measured 58250 Cd.
Did you mean Cd at your measurement instead of lux?
giorgoskok
giorgoskok's picture
Last seen: 5 days 5 hours ago
ZozzV6 wrote:
I measured 58250 Cd. Did you mean Cd at your measurement instead of lux?
Lux at 1 meter = Candela
ZozzV6
ZozzV6's picture
Ok but he sait 68400 lux at 6m
