You didnāt have to do thatā¦ it was already very good.
My only concern of any substance is whether itāll be able to fit in common 17mm hosts. But Iām guessing it could have ~0.4mm filed off the edges if necessary? Iād love to hear whether it fits into popular 18650 tube lights, since that size of driver gets used so widely.
To be honest I did it for myself. I hadnāt thought about wiring the LED that way, itās pretty neat. I also needed a break from coding, so a bit of mucking about in Eagle was welcome.
I changed the via size down to 1.5, but there is enough clearance for a 2mm hole if one wanted to drill it out. I was thinking about putting a hole instead of via, but that would mean a little extra hassle for my lights where I donāt want a driver spring.
Iāve used this same 17.8mm diameter drivers in my S2, S3, M1 and M2s since a long time. I use that diameter so I can file down for a snug fit, although I havenāt had to file anything off but the fabrication panel tabs for the shelfless S3 and M2. Filing all the way down to 17mm would be no problem, there would still be some ground ring left, you would have just hit the holes in the ground ring vias.
4S. However, my attempts with 7135s on 4S where not successful, so for 4S I have shifted my attention to a 3 amp LDO (LT3083). I havenāt gotten around to testing them out yet though. I have all the parts, I just havenāt taken the time (been more interested in getting the ATtiny841 boards ready.
Do you have any more details on the LDO and design you used to get 7135s running on 4S? Iāve got everything working with 4S except the 7135s.
When I get a chance, I'll dig up one of my lights that I did it in and double check that they do work properly. If it does, I'll report back.
Well, one thing led to anotherā¦ now there is a F-4. Itās the same as the F-2 except with two additional 7135s that are on the back side, which in turn required a slightly smaller spring pad so they could fit. Of coarse the two new ones are on another pin, so any number of one to four 7135s can be turned on in constant current, and for any level between I will PWM the 7135 on PB2.
Iāll still keep the F2 available as it has a larger spring pad, otherwise there is no need for it if Nanjg sized springs are used. If only two 7135s are wanted, donāt populate the ones on the back (spring pad) side. I also put another 0805 cap on the back side since I removed one from the F-2. If the F-4 is made with four 7135s, then itās a double sided board anyway, so two OTSM caps can be used for longer measurable off times if desired.
I also managed to squeeze in another switch via, so if a E-switch is soldered in place there is still an available via for acupuncture style flashing. This is for both the F-2 and F-4.
I want to test that the F-2 v5.2 works before making the v5.3 F-2 and F-4 available. As far as I can tell, no one has ordered the current F-2 so Iāve un-shared it for now because the new v5.3 (that the firmware will be working for) will have a pin change.
Work is getting the way though, Iām being sent of to Israel tomorrow, and then on to New Delhi, so this stuff will be on hold. I donāt want to take small electronics and development stuff will cells, buttons and wires with me because Israeli airport security is a lot tighter than most other countries.
It sounds really nice. I should probably get or make one after itās known to work, for development purposes. It seems avr-gcc didnāt add support for the tiny841 until fairly recently though, which means Iāll have to upgrade some toolsā¦
BTW, before you finalize anything, do you think thereās any chance of getting a trace from an ADC-capable pin to LED- ? This would allow the driver to sense the ambient light level while the LED is off, which means it could be configured by pointing it at a computer screen with binary code blinking in black and white. Or it could maybe sense whether to skip moon mode when the ambient light level is too high for moon.
I will do that on a next version. For testing in the meantime there is a via used for flashing that is otherwise unused. Itās on PA5 which has ADC capabilities.
TK, that really sounds wonderful. I love a true moonlight mode in almost every light and if it were there or not based on existing lightā¦ that would be awesome! The programming idea is interesting, thus having the extra space in the chip might be huge!
We seem to have new drivers showing up every day that have lots of potential right now. It is awesome! Just wish I could wrap my head around building them. I can see I will be ordering parts soon and testing this bad boy out!
Iāve just received the new v6 design for the F-2 and F-4, so Iāll build a few and make sure there arenāt any screw-ups.
The v6 component and pin design is already tested and working nicely though. I made a L4 dedicated version with 14 x 7135s which is the first of my v6 drivers to actually make it into a light: What did you mod today? - #2984 by Mike_C
I used a 22uF X7S rated OTSM cap on the L-14 which consistently gets over 10 measurable seconds at 4V and room temperature. Iāll have to lower the voltage and heat it up to test the margins.
Well, with the ATtiny85 without bending pins I found that the clip would pop off every now and then, and was sometimes difficult to get on right. It was much better when I bent the legs but would still sometimes be annoying to get on correctly and could still pop off easily, at least when it was installed in a light:
The acupuncture style has itās drawbacks too, in particular if the wires used are too thin. It has happened that Iāve had to push on the wires as contact was lost, but it happens so seldom so I much prefer this method. Now I can have the MCU on the inside, keep a spring pad and flash the driver without taking it out. Thatās a real advantage for a firmware developer
I have a dedicated development platform which makes development and testing much easier. Without the clip I find it even easier, but having the right size āneedlesā is key. The paper clips I use are pretty much spot on for the via size I used:
I have had that problem with the ATtiny85 clip popping off, but only pretty rarely. May have more to do with the solder flow on the legs. With bent pins, never a problem - rock solid clipping. Are you using the good blue clips?
The clips are blue, and mostly worked fine, but they might not have been the good ones. Sometimes the clips contacts would get bent and need straightening out. Possibly the stiff wire I ran over the 85s as battery contact had something to do with my issues, or possibly too little clearance to the 7135s:
Anyhow, these issues are now a thing of the past. Iāve fully converted to the 841 on all my drivers.
