Can I use this battery on this flashlight?
Yes, the protected Thrunite works well with the E2L.
Dropped a couple of the new AA lights in the shopping cart at Jaxman, added the small C8 design and some cells. The site wants to ship separately, I’ve asked if he can package it all together and ship FedEx so I get it quicker. Waiting on a reply. I don’t really need the cells, might just add an Z1 and run with it.
you know.I just worry for the heat transfer.we used in convoys the copper spacer.now we dont need it…but it helps.si I dont know now…huh
Yes, the heat build-up is different in the E2L: the outside gets hot quicker because there is not a chunk of copper in there that soaks the first heat. But the heat spreading over the shell is faster than in an S2+, that compensates it a bit.
One of my E2L’s has 219C’s (sm405 R9050) and a BLF X5/X6 driver and draws 10A on highest setting. It can be run at that for half a minute with no problem, it just gets so hot after that that you will switch it to a lower setting. And that 2000lm for half a minute is a nice addition to all the lower modes that can be used continuously.
So if used like that, the heat transfer is fine: even at 10 amps I see no problem for the leds in the period before the shell gets so hot that you will automatically switch to a lower mode. Your time at turbo may be a little bit shorter than with a S2+ with copper spacer, what you get back is a flashlight that is a bit shorter and more lightweight.
Good to know. Thanks Tjohn.
Richard needs to correct the brand name as it currently displayed “Convoy”.
It says Jaxman now.
Does the convoy deep carry clip fit on the Jaxman tailcap?
Anyone?
Gunga, which light from Convoy comes with this deep carry clip you’re asking about? I only have a few Convoy tube lights, not sure if I have that specific clip, but will check and see. Everyone’s sleeping at the moment but that should change soon and I’ll go dig stuff out and see if it fits.
Will be back shortly…
Hey Gunga? The Convoy S2+ tailcap interchanges with the E2L tailcap and both lights work fine. The groove that exists between the tail cap and start of knurling is the same width but the grooves in the E2L tail cap are slightly narrower. So if there is a clip that attaches to the tail cap, I doubt it would cross over due to the narrower margin.
I have a blue S2+ but have no clue where the clip for it is. Thought I had more Convoy tube lights but the only other one I can locate is chopped with a short tube and TIR lens, no clip.
Probably have a box of clips somewhere…
Ah. Thanks. I have a Jaxman UV light and the clip doesn’t fit On the tailcap. You just answered my question, I won’t fit the groove on the e2l tailcap. Thanks!
The Jaxman UV light has even slimmer grooves than the E2L. If your clip is close, it might just fit the E2L. Could probably open the groove width slightly to make it fit, fairly easy on a lathe but a bit more work without one, still doable though. Without a lathe you can disassemble the tail cap, use a washer to cover the tail end and a piece of all thread or a bolt to run through the tail cap and a nut on the inside to secure it. Mount the all thread/bolt in a drill and spin it up, cut the groove wider with a rotary tool or a hack saw blade, perhaps a small file.
Perfect! Thanks!
Your welcome
i asked jaxman to produce for a bigger amount of this light with xpl high…with fet driver.they said,the switch is not suitble for so many amps…what to do?:laughing:)
That continues to make me laugh!
That switch, the mini Omten, is handling 23Amps in my DBC-05 Triple XHP-50.2.
(That’s 23Amps at over 7V. )
hi,due to busy working, days off-line to BLF.
23A….is too terrible….
I have confirmed with a switch technical from the fatory of the switch(not Omten), the man told me,the switch can not bear 3A more.
The 1288 type switch titled as 250V 1A. Though we use this switch under 4.2V, while I think 20A 4.2V is also out of my imagination…
I have get a better provider than Omten. But it still make me stop on a 3A+ current controlling with this little switch.
How you think about dear all friends?
