This flashlight?
That’s it.
Thanks purchased a pair of x5r.
lamper wrote: That's it.
Looks like, but not very:
Nitecore MH20 - $ 79.95 | Nitenumen NE01 - $ 31.59 | Just Flashlight - $ 12.52 | ||
(L x D): 10.50 x 3.18 cm | (L x D): 11.00 x 3.00 cm | (L x D): 12.40 x 3.20 cm |
New coupon codes and flash sale:
Hi, Fin17
What about a code for Brinyte B58U XPL HI V3?
Cheers
Purchased, thank you!!
I’ll try.
You will have a large collection of Brinyte! :sunglasses:
Not yet (only 3 right now) but I am getting there :person_facepalming:
New and restored coupon codes
Can someone please help me understand the difference between the Eagle Eye X5R CREE XPL HI and Eagle Eye X5R Cree XM - L2 in practical terms? I understand that they’re different emitters, but what makes the XPL HI worth a few $ more?
Usually another 100 lumens or so and it’s dedomed so more throw
LiitoKala Lii – 202 USB Battery Charger
no flash sale on it.
Sukoi, check PM!
Thanks for your effort, just bought it
My headlamp broke the other day. Is there a coupon code for the:
Skilhunt H15 CREE XM L2 U3 500LM LED Headlamp - NEUTRAL WHITE LIGHT?
Thank you!
XM-L2
Max Light Output (lm) 1052 lm
Viewing Angle 125
XP-L HI
Max Light Output (lm) 1095 lm
Viewing Angle 115 °
Eagle Eye X5R XPL HI 1A ($24.99) - 2.3 cent per lumen
Eagle Eye X5R XM-L2 1A ($21.99) - 2.1 cent per lumen
mrstealyourgains:Can someone please help me understand the difference between the Eagle Eye X5R CREE XPL HI and Eagle Eye X5R Cree XM - L2 in practical terms? I understand that they’re different emitters, but what makes the XPL HI worth a few $ more?
XM-L2
Viewing Angle 125XP-L HI
Viewing Angle 115 °
Thank you - sounds like they’re pretty close in performance. I doubt I’d be able to tell the difference with my naked eye
Fin17: mrstealyourgains:Can someone please help me understand the difference between the Eagle Eye X5R CREE XPL HI and Eagle Eye X5R Cree XM - L2 in practical terms? I understand that they’re different emitters, but what makes the XPL HI worth a few $ more?
XM-L2
Viewing Angle 115 °
Eagle Eye X5R XM-L2 1A ($21.99) - 2.1 cent per lumenThank you - sounds like they’re pretty close in performance. I doubt I’d be able to tell the difference with my naked eye
Hold on.
The difference between XP-L HI and XM-L2 is predominantly the absence of a dome in the XP-L HI variant. The “HI” stands for “High Intensity”. This means that the lux value (=throw) is much higher than the non HI variant, including the XM-L2. So the total amount of light (lumens) is about the same, but the hotspot is smaller/tighter and brighter. The link is a comparison between the Thrunite TN4A and Thrunite TN4A HI: the first uses XP-L (HD), and the latter XP-L HI. You get a good impression what the difference is (XP-L HD is about the same as XM-L2)
Hope this helps. Cheers.
Edit:
Another video comparing both lights side by side: https://www.youtube.com/watch?v=ZObWq_I6MbM
woolfam:My headlamp broke the other day. Is there a coupon code for the:
Skilhunt H15 CREE XM L2 U3 500LM LED Headlamp - NEUTRAL WHITE LIGHT?Coupon is not available now.
I’ll try to get it tomorrow
Thank you…
Just ordered C8, thank you for fast following up and the first rate service!
