Convoy L6... XHP70 Beast!
is the 7-7,5 amps measured from the tail cap?
i added the same r100, but only measured 5amps with 26650 keeppower batteries, need more current :slight_smile:
Same here, I added an R110, stayed under 5A as well. (my L6 was from Gearbest), could it be that several versions of the driver are around?
Welcome to BLF, solRNY !
Yes, they measure at tail cap. Adding a wire to the negative emitter lead and using a clamp meter should give more accurate readings. I haven’t tried this though. No clamp meter. :slight_smile:
All L6 use the FX30 driver. Simon’s version has the uniquely modified UI with wider spaced modes, no stepdown and 2 R082 resistors. So if you have that, then you have Simon’s version.
Folks have said that adding a 3rd very low resistor, like under R100 will basically make the driver go all out and it’s basic design is limited to 9 amps or so. Some folks have said their driver maxed out at less than that. Like 7.5 amps. I don’t know why it varies.
Stock L6 should get 5.25 amps at tail.
Back when I did my first resistor mod to my L6 I added an R082 and a ceiling bounce measurement went from 311 lumen to 344 lumen. It was a noticable bump in brightness.
Exactly , 7-7.5 amps at the tailcap with an R100 . Even with the R110 you should be in the 6.5+ amps range .
Stock is 5-5.5 amps .
Keep in mind it’s difficult to get good readings at the tail cap with a multimeter. You need thick, short leads.
My multimeter with skinny, long leads is not good at all at measuring tail cap loads. It was reading 3.8 stock and 4.1 after the mod. That’s not accurate, but I can still do relative comparisons.
On my second FX30 driver I just added a tiny wire over the sense resistor to make it go full blast. It seems to be holding up fine, but I have not measured to see if the lux improved. I did just now measure the tail cap amps.
Using my original protected KeepPower batteries.
Turbo/high = 4.35 amps
Med = 2.0 amps
Low = 0.5 amps
So using the wire over the sense resistors gave me roughly 0.25 more amps compared to the R082.
Using my new Liitokala batteries.
Turbo/high = 4.9 amps!
Med = 2.07 amps
Low = 0.5 amps
Now these liitokala batteries are giving a bigger jump in amps. Maybe it’s their less internal resistance?
I’ll try and get a clamp meter and remeasure for accurate numbers.
BTW, this new FX30 I’m using has 1.45 milliamps of current draw in standby mode. I don’t know if thats okay or excessive, but I keep the rear switch off when I’m not at work.
Even with a multimeter & 16awg short leads i wasn’t able to get correct readings .
I only use clamp meter now (uni-t ut210e) .
Hey, that’s not very expensive. I think I’ll pick one of these babies up. Thanks. :beer:
There is a coupon from m4dm4x too . :beer:
I can’t find it. I saw one from Freeme. Is that who you were thinking of?
The short tube is listed now. I’ll add the link to the L2/L6 modding thread and the OP here and in the L2 thread later with the additional details.
https://www.aliexpress.com/store/product/L2-L6-short-tube/330416_32803828707.html
Hi Djozz, which batteries do you use? My L6 is from fasttech and with r100 and fresh liitokalas this at 7.1 amps + - greetings.
I will do another measurement, I use the same 5000mAh Liitokala’s.
Well, try sanyo ga, kill two liitokalas doing shortcut, a stupid mistake on my part :person_facepalming: , with fresh sanyo drain very fast, start above 7.3 amps and immediately start to go down so this battery is not enough for Feed the modified L6 but it serves as a sample, greetings !!
I fully charged the Liitokala’s, used a thick magnet between the two batteries because they are so short that they do not really push on the springs very hard, and it is much better: 6.6A using a small copper coil with clamp meter with the tail taken off, and 3800 lumen at 30 seconds with the tail in place.
This is with the added R110 in parallel.
Maybe magnets, produce resistance? R110 less than r100, that may be another difference in performance
Some magnets are coated with a protective layer. Even if it isnt, there may be a little resistance in it. I use solder blobs on my 2 liitokala that I use exclusively in the L6.
The 2 stock R082 resistors create 0.041 ohms.
Adding a R100 drops it to 0.0291
Adding a R110 drops it to 0.0298
So pretty much the same.
then when i use it in L6. can i use 1*26650 ? or use for 3*26650?
I thought the purpose of the short tube was for fitting 2 x 26350 cells. Right? Wrong?
… making for a shorter easier to carry light, though with a reduced run time.
I thought it will have the tactical ring
