Nichia 229AT on Djozz copper mcpcb Emitter output test by Texas_Ace; Lowest Vf LED I have ever seen! Surprisingly good output
21 posts / 0 new
Texas_Ace
Texas_Ace's picture
Last seen: 2 days 17 hours ago
ECHO sent these NWSW229AT LEDs to me to see what they could do and well, I love trying to new things so here are the results.
I am not sure what bin / tint they are other then they are 70CRI. Tint appears to be in the 5k range.
The package has this lot number: G85051-SM505M600L2R70
And this barcode: 912665462
It didn’t come up in any good search and I am don’t know how to read the nichia codes. If anyone knows what they means, let me know.
EDIT: I looked up the datasheet and there appears to be only one option for this model? Looks like it is officially rated at 637 lumens and 5000k @ 1400ma. Which my numbers are pretty close to so that appears to be correct. http://www.nichia.co.jp/specification/products/led_spec/NWSW229AT-E(4085C)R70.pdf
So interesting points for this test are mostly in the ultra low Vf, by far the lowest Vf I have tested so far! So this is a very efficient LED when driven reasonably. For us that also means no FET driver for us, at least without PWM regulation. This thing would pull some serious amps on turbo!
It also worked surprisingly well even at the higher power levels. It beat out the 219C D320 all the way up to 4.5A before the lack of a thermal pad and DTP caught up to it. Way better then I had figured it would do. The Vf difference is amazing.
I tested it all the way up to 11A as you can see in the chart data but only put the first 7A in the graph. It just kept nosediving after that. at 11A the dome started to audibly crack so I called it quits. It is one tough LED.
Overall it is a far better option then I would have guessed at first glance. Makes me curious what the E21A can do with a good mcpcb since it has a thermal resistance of 0.3c/w vs the 229’s 2.3c/w.
Click on any image for larger version.
zeremefico
zeremefico's picture
Last seen: 1 hour 27 min ago
Great results,thanks TA
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
kiriba-ru
kiriba-ru's picture
Last seen: 11 hours 15 min ago
All as expected:
Texas_Ace wrote:
kiriba-ru wrote:
This is wrong way. Dont forget that you can kill led from big current without overheating. Just one day you will have such combination of led and cell that would give too much pick current, neither with or without pwm.
While you can’t PWM 2S voltage and it work with a 3V LED the way things have worked out so far PWM current limiting works fine for all the LED’s currently on the market.
All of the LED’s that would be killed with too high of a current have a high Vf and can not pull enough current from a single cell to damage themselves (they also do not need the PWM limited, it would be simply for lower modes to have some “regulation”).
All of the new LED’s that have low Vf and need the current limited are tough enough to not die even with extreme amounts of power. I have tested the 219C to over 12A and the XP-L2 to 15A, both were still working after the tests. So it is highly unlikely that you will damage the LED’s by PWM them with current LED or cell tech.
Down the road as things improve that might change but for now it is a good option.
Sadly we have no other options for most of the lights we like to build. buck and boost drivers are too large and expensive for what we do in most cases and do not offer enough current for most of us.
Linear drivers can not handle the latest gen emitters without overheating.
The only thing left is PWM an FET driver. It is not ideal but there are no other options.
Texas_Ace
Texas_Ace's picture
kiriba-ru wrote:
All as expected:
I am not sure what that quote means in this case? The LED is still alive right now and PWM was never used in this test. In fact I would guess it would work perfectly fine with PWM, just with a loss in efficiency as expected. Although in my testing even a 50% duty only drops efficiency by less then 13%.
Although none of this has anything to do with this test near as I can tell?
kiriba-ru
kiriba-ru's picture
With Vf=3.43 @10Amp high drawn cell with low res fet will give peak current that will kill this led, neverless is pcb dtp or not and etc.
Texas_Ace
Texas_Ace's picture
Sounds like I need to test it and find out, I think I have a spare driver laying around I could use for this….
kiriba-ru
kiriba-ru's picture
Well, if resistance of all components are known and we have cells discharge curves, expected current can be calculated enough precisely.
kiriba-ru
kiriba-ru's picture
Vf@9Amp is almost same to 219C@3A, this means it will eat same current as 219C parallel triple.
Texas_Ace
Texas_Ace's picture
Ok, I have the test 229AT on the bench right now running off a full 4.20V from my power supply with an A6 driver on mode 4 or 5 for a final output of 1.32A @ 4.20v.
It has been running for the last 5 minutes or so just fine, no issues at all. Although the driver keeps coming loose and making it turn off.
It is using the stock wires from the A6 driver to power it and is basically how it would work in the real world. As long as the total current is kept to a safe level it should work perfectly fine.
I keep wanting to get a function generator and/or a variable duty setup to allow me to properly sweep through the PWM range both in duty and frequency., right now the best I have is using a flashlight driver with a PWM mode.
I also tried the higher modes as well and had no issues until like mode 6 where the current was trying to go above the 7A I had my power supply limited to. The LED was still fine though obviously.
I also tried it hooked up to my charging setup with 4 cells powering it, same result, although the voltage sag caused it to actually be an easier test since it was only getting around 4.1V input vs the 4.2V from the power supply.
I think I can safely say that if the PWM is managed properly and total current kept in check, this LED will indeed work just fine with PWM. Although the efficiency will suffer some obviously.
So yes, I still stand behind the above quote, PWM is not ideal but it is the only viable option for high current, low cost and compact flashlight drivers unless something new come on the market. Remote mounting an FET is a better option but not something we can do just yet and comes with it’s own issues.
Hmm, I should put it on the sphere with the PWM to see how it compares, although I don’t know what the duty cycle is on the A6 driver.
doubleone44
doubleone44's picture
Last seen: 1 year 1 week ago
This might be really good for use with AA/AAA boost drivers, the lower forward voltage will greatly benefit the driver efficiency.
What is the die size on this? I would guess XML size?
kiriba-ru
kiriba-ru's picture
You dont have any 25R/HE4/HG2 cells?
Texas_Ace
Texas_Ace's picture
doubleone44 wrote:
This might be really good for use with AA/AAA boost drivers, the lower forward voltage will greatly benefit the driver efficiency. What is the die size on this? I would guess XML size?
Yes, it would work great for these lights. They don’t produce nearly enough heat to cause issues and the low Vf would help them a lot. Same goes for lights with buck drivers, it would stay in regulation longer.
Texas_Ace
Texas_Ace's picture
I was using 4× 30Q cells for this test but like I said, the power supply at 4.2V is harder on the LED then the batteries at 4.1V. I tried both to make sure though.
Plus it is easier to monitor things on the power supply, which is why I use it for most things.
The point is that while it is not ideal it survives PWM just fine.
kiriba-ru
kiriba-ru's picture
We dont know led electric properties (such as Xl and Xc) so Im not 100% sure about same current peaks in pwm and in full throttle.
Anyway, mine idea was that full throttle current can burn led internals (thin wires, diode and etc). I expect 11-12Amps from good build. Your 4×18650 carrier seems to have bad springs and thin wires.
Texas_Ace
Texas_Ace's picture
kiriba-ru wrote:
We dont know led electric properties (such as Xl and Xc) so Im not 100% sure about same current peaks in pwm and in full throttle. Anyway, mine idea was that full throttle current can burn led internals (thin wires, diode and etc). I expect 11-12Amps from good build. Your 4×18650 carrier seems to have bad springs and thin wires.
If I ran it at 100% duty it would have easily gone WELL over 12A, this is why I stopped going up in modes after mode 5, I went to mode 6 briefly and current spiked to over 8A. The LED survived just fine but I knew that was too high.
If you run it at 100% duty then it is not being PWM controlled and thus any discussion of PWM is moot.
When PWM is controlling the current then things work fine, just not as efficient as it would with constant current.
By staying in mode 5 the PWM duty was around 20% and this limited the current to around 1.3A. Which ran without an issue for over 5 minutes.
As far as the carrier, it was perfectly good but doesn’t matter. The power supply was outputting a full 4.2V, more then any battery will output as they will all sag at least some. So the power supply is the hardest possible situation that the LED could see for an input voltage.
The output side was using the stock wires on the A6 driver as I said before, they are 22AWG? not super thick but plenty thick enough, it would be silly to use super thick wires with this LED, personally I would use long 26 or 28awg wires if I built a light with this LED (unless it had a buck or boost driver).
kiriba-ru
kiriba-ru's picture
Average. Youve forgot word average. Average current.
In my first suppose, peak current can be close to the 100% duty. Need tests with high-freq. oscilloscope to know how far is this from real.
Texas_Ace
Texas_Ace's picture
Correct, average current is what I am using. I don’t have a scope good enough to see the peak current but I am sure it is indeed over 10A. That is fine though, the LED doesn’t die at that point, I simply stopped going higher.
djozz
djozz's picture
Last seen: 8 hours 27 min ago
I second that (third that?). It would be a great led-swap for 1xAA flashlights (and quite a beast on an average 14500 cell).
Thanks for the test, TA!
MRsDNF
MRsDNF's picture
Last seen: 9 hours 33 min ago
Thanks for the effort TA. Nice work. Thumbs Up
LightRider
LightRider's picture
Last seen: 2 years 2 months ago
Yes and yes and with a buck driver it could be regulated at a constant 1000 lumens til almost the end:)
Jerommel
Jerommel's picture
Wow, that’s a low Vf there.
3x NiMH, LiFePo or a buck driver..
