ENEDED
Please PM with purchase info.
I did reply my observation on my other thread.
No visible PWM in all modes for Li-ION and Ni-MH.
I did experience the same problem as well. 14500 charging seem fine. Charging process terminate @4.19V. Whereas, AA (Ni-MH) charging ends @1.38V.
Interested.
I also 1.38V. I have meassured with the doctor USB that stop after 725mA in…
I received my lights yesterday, I haven’t unboxed these yet.
The method is to measure the cell voltage after charging to verify full or not?
I do not have the USB amp meter device, just a Harbor Freight DMM
Was the battery empty before you charged it?, On my AAA E01R my usb battery meter mah reading was very close to the discharge capacity on my Maha C9000, So your 725ma on an empty AA 2000mah is not even 50% charged.
John.
On my AAA E01R, I dont have the AA E10R
I discharge the nimh to 0.9v in my maha c9000 then charged the battery in the Jetbeam till the red led turns off, Then i take out the battery and measure the voltage, I get 1.37 or 1.38v then i discharge the battery in my Maha C9000 at 100ma to see the actual capacity the Jetbeam put into the empty battery.
I have done 6 charge discharge cycles and 5 were only 50% capacity, 1 was 75% capacity of the battery capacity on my E01R AAA
So you need to do this on your AA E10R to check out the nimh charging.
John.
The battery was empty before it began to fill.
The method is not precise, the ideal is to measure in discharge. But this gives us a rough idea. Normally, I put in my Fujitsu 1900 mA around 2200mA with this method. And now I only get 725mA, around 1/3 …
I will test with charger this weekend.
With 14500, all my brands protected and unprotected runs fine, not size problems.
AW looks quite short in the pic.
Aw IMR unprotected is really very short battery, but the E10R runs fine with it (of course I will not charge this IMR unprotected battery inside the light)
Hi. Interested.
Sent.
Interested. Thanks.
Why not? The charging scheme seems fine for 14500 cells?
Sent.
Hi, I would be interested in one of these if you have a code.
I have to request for new one next week.
Well, put me down as interested in a code as well!
Thanks Freeme!
Winners of E10R GAW are:
1st: Vegas1 (KLARUS mi7 Ti)
2nd: patmurris ($10 Fasttech Gift Certificate)
