Keep in mind it’s difficult to get good readings at the tail cap with a multimeter. You need thick, short leads.
My multimeter with skinny, long leads is not good at all at measuring tail cap loads. It was reading 3.8 stock and 4.1 after the mod. That’s not accurate, but I can still do relative comparisons.
On my second FX30 driver I just added a tiny wire over the sense resistor to make it go full blast. It seems to be holding up fine, but I have not measured to see if the lux improved. I did just now measure the tail cap amps.
Using my original protected KeepPower batteries.
Turbo/high = 4.35 amps
Med = 2.0 amps
Low = 0.5 amps
So using the wire over the sense resistors gave me roughly 0.25 more amps compared to the R082.
Using my new Liitokala batteries.
Turbo/high = 4.9 amps!
Med = 2.07 amps
Low = 0.5 amps
Now these liitokala batteries are giving a bigger jump in amps. Maybe it’s their less internal resistance?
I’ll try and get a clamp meter and remeasure for accurate numbers.
BTW, this new FX30 I’m using has 1.45 milliamps of current draw in standby mode. I don’t know if thats okay or excessive, but I keep the rear switch off when I’m not at work.
Well, try sanyo ga, kill two liitokalas doing shortcut, a stupid mistake on my part :person_facepalming: , with fresh sanyo drain very fast, start above 7.3 amps and immediately start to go down so this battery is not enough for Feed the modified L6 but it serves as a sample, greetings !!
I fully charged the Liitokala’s, used a thick magnet between the two batteries because they are so short that they do not really push on the springs very hard, and it is much better: 6.6A using a small copper coil with clamp meter with the tail taken off, and 3800 lumen at 30 seconds with the tail in place.
This is with the added R110 in parallel.
Some magnets are coated with a protective layer. Even if it isnt, there may be a little resistance in it. I use solder blobs on my 2 liitokala that I use exclusively in the L6.
The 2 stock R082 resistors create 0.041 ohms.
Adding a R100 drops it to 0.0291
Adding a R110 drops it to 0.0298
So pretty much the same.
I thought the purpose of the short tube was for fitting 2 x 26350 cells. Right? Wrong?
… making for a shorter easier to carry light, though with a reduced run time.
