5 watt, 365nm flashlight - anybody see this one?
36 posts / 0 new
pirateo40
pirateo40's picture
Last seen: 7 months 4 days ago
A China company (Bell Van) is advertising a 365nm, 5w flashlight based on what appears to be the CUN6GF1A chip from Seoul Viosys. The specs say 1150mw radiant, so it must be driven at 1000ma? A 5 watt would have to be driven at the max of 1400ma, but I have a hard time believing it is driven at 1400ma – I don’t see how the flashlight could handle the heat.
Supplied with a ZWB2 filter, priced around $25 (I’ve been told 3rd hand). I have an email inquiry into them to confirm.
Anybody have experience with this company or the Seoul chip?
http://www.lightingsforyou.com/365nm-375nm (scroll down)
Mark
MinerShop.com
The Miller
The Miller's picture
1400mA is 4 7135 chips, even a small S2+ can handle that heat, where the linked light has a bigger head and finning.
pirateo40
pirateo40's picture
Don’t know about that. The s2+ with the Nichia chip driven at 700ma get pretty warm. Driving the Seoul chip at its max rating of 1400ma is on the edge. Derating at 1400ma starts at 40C with excellent heatsinking, 10C with lousy heatsinking
Mark
MinerShop.com
djozz
djozz's picture
Last seen: 3 min 12 sec ago
$25 is a great price for a 1W radiant output 365nm flashlight with ZWB2 filter. I have not had one of those Seoul leds, but it has the standard 3535 footprint, so if you don’t trust the lifetime of the led, you could change the ledboard with a DTP board and vastly improve the thermal drain of the led. Or maybe a DTP board is already in there and that is how they get away with 1400mA.
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
mortuus
mortuus's picture
Last seen: 4 min 42 sec ago
interesting, too bad the host looks like complete shit.
...where Frugal meets with Flashlight!
pirateo40
pirateo40's picture
Maybe – I’ve sent an email asking for details on the driver and heatsink. Problem is I’ve never heard of this company and have no idea of the reliability
Mark
MinerShop.com
djozz
djozz's picture
I think it a good sign that they provide the specsheet of the used led, that is better than I have ever seen before.
link to djozz tests
sedstar
Last seen: 1 year 3 months ago
be nice if they showed more of THE PILL… thats some of the most important part…
With enough black coffee and cigarettes? all things are possible…
I am currently still shipping… REAL GENUINE CREE xp-g emitters, the classic… brace yourself? as low as 20 cents apiece!! Check out the SALES THREAD, everyone is happy… then PM me
SALES THREAD:
http://budgetlightforum.com/node/52528
if you are into reloading? this is my site… I inherited the remains of what was once arguably the best reloading site on the internet… its the “BLF” of reloading sites…
http://reloadbench.freeforums.net/
if you think night vision would be cool? It IS… this site i am a member of, and its basically the “BLF” of home made scratch-built digital night vision. They are at the leading forefront of advanced DIY for digital night vision, and thats gun mounted or handheld… builds rival and exceed commercial offerings…
http://nightvisionforumuk.com/
pirateo40
pirateo40's picture
OK – just got the quote, very interesting = $25 in low qty. They use the CUN6GF1A Seoul Viosys chip, driven at 1000ma. Driving at 1400ma will overheat he says. Simple on/off driver, with ZWB2 filter. I’m going to order a couple and check them out. Sounds promising…. Will try to update here once I receive them.
Mark
MinerShop.com
mortuus
mortuus's picture
how much more powerful is it then convoys uv light ?
pirateo40
pirateo40's picture
1150mw vs 640mw (stated specs – radiant, not yet tested). Quite a bit more powerful. Of course reflector design will matter quite a bit. I ordered four of them to test/tear apart
Mark
MinerShop.com
DB Custom
DB Custom's picture
Last seen: 1 hour 35 min ago
FWIW, the most powerful UV 365nm emitter Nichia makes is the NVSU333A. It runs at 3800mA and makes a LOT of heat. And it sells for $108 for the emitter itself, if you can get it. I had to sign a waiver of release and submit an order on my company letterhead.
This is to say that it’s not easy, or cheap, to get a true high power UV emitter.
Edit: Here’s what the NVSU333A looks like…
Dale
pirateo40
pirateo40's picture
Yeah – 3640mw radiant. Almost need liquid nitrogen to cool Wink – Luckily in our application (mineral fluorescence) we don’t need pinpoint light sources. We’re not interested in throw but in a wide intense beam (floodlight). Pretty easy to hook up 3 or 4 of the cheaper LEDs and get close to the radiant (4ea Nichia 033 chips would give ~2500mw @$4 each). I built a 4 LED light using the LED Engin LZ1 parts for >6.5W radiant.
Here’s an example of the way we use these LEDs for mineral lights:
Mark
MinerShop.com
DB Custom
DB Custom's picture
I have it mounted in a solid copper X6. Works well, I made a chunky aluminum “reflector” that gives a square hot spot but prefer to use it in mule configuration.
Edit: My primary point though was that if a company is declaring a “high output” UV emitter at a $25 price point something is probably amiss…
Dale
pirateo40
pirateo40's picture
I guess it depends on what you consider high output. A 9watt CFL (fluorescent) bulb outputs ~1.5w of UV (UVC or UVA). An LED which outputs radiant 1.5w UVA is considered pretty high output for us. Even the little Nichia 276 at 600 to 700mw but in a very tight beam, all radiated from a single point far exceeds the perceived power of a CFL bulb. So my focus is on replacing fluorescent bulbs where I can with these very directional LEDs. If only a reasonable UVC LED were in my future – sadly afraid not. 10mw/20mw just won’t cut it…
From a UV watts to dollar ratio I find the LZ1 part to be quite effective. But would drool to have what you describe – and mule config exactly what FL mineral collectors want. Did you also install a UV bandpass filter? With the $$$ you have invested in that light I would consider using Hoya 325c – the best filter you can get…
Mark
MinerShop.com
DB Custom
DB Custom's picture
I had researched and located the Hoya lens but never bought it. Kinda like seeing the emitter in this copper light. (off, of course!)
Edit: From datasheets, the Hoya 360 would give a much sharper cut off for this Nichia, but where to find one in 35mm?
Edit II: I also have the LZ1 and a couple of the smaller Nichia’s, the LZ1 does perform well as does the little Jaxman offering in the U1 with it’s black bandpass filter lens.
Dale
pirateo40
pirateo40's picture
I cut all my Hoya glass. I have squares which I trim down to hexagons with a diamond saw, and then round it off using a lapidary wheel. The advantage of being a rock collector Smile
Mark
MinerShop.com
DB Custom
DB Custom's picture
I too have the required diamond tools, just have to find the glass…
Dale
mortuus
mortuus's picture
so put an NVSU333A emitter insisde a c8 host would be a bad idea then?
djozz
djozz's picture
Financially pretty bad, yes.
link to djozz tests
wle
wle's picture
Last seen: 9 hours 46 min ago
the chinese specs are pretty loose with their “W” ratings
i have seen a 1xAAA light called “5W”
so it may not mean what you think
or it might just be a lie
wle
Scientist
Scientist's picture
Last seen: 1 day 18 hours ago
I realize this thread is a little old but I have to ask…so Mark, what happened? How did those lights work out? I have been avidly following your web pages since recently discovering them and that led me here looking for the latest developments in UV lights. I got the Convoy S2 on your recommendation and find it fantastic for UV rockhounding. Looking for the latest developments.
DB Custom
DB Custom's picture
The C8 also wouldn’t handle the heat of an 333A and the ultra expensive emitter would die. I have one in a solid copper X6, have to watch the heat still.
Dale
Scientist
Scientist's picture
OK, so how could one make a mobile light containing one or more Nichia 333A emitters?
mrheosuper
Last seen: 8 hours 32 min ago
I think active cooling is the answer for portability
Forgot my pen
Lexel
Lexel's picture
Last seen: 3 hours 22 min ago
yeah I have planned to put the 333A in a Convoy C8 with a Bistro driver with relative low temperature stepdown at 45°C
I am not planning to go for FET DD on this one and play it save with 7135*12
DB Custom
DB Custom's picture
I had to sign a letter of release on my company letterhead then pay Nichia $108 for the emitter itself.
If I remember correctly it’s running 3.8A on a PZL driver in a solid copper X6 (a mistake, was supposed to be the first copper X5)
Because of a very high Vf, I run a 4.35V Lg cell.
Edit: just got 3.18A at the tail on a freshly charged 4.35V LG that’s getting old.
Dale
Lexel
Lexel's picture
Received the NVSU233B-D4 365nm LED today
maybe they do a 333B with better efficiency that would be great
5.5W electrically, should be a bit less than 2W 365nm if its like the Datasheet normal flux bin
this has about 40% better efficiency than the 233A
on a fresh 18650-30Q it draws 1350mA
compared to a LiteOn 365nm @1050mA 50% overdriven on DTP star
that is already dedomed I can live with as its going into a reflector light
easiest to dedome LED ever its just held by 4 little glue spots
compared to the 276A you can see that the new ones have one electrode under the emitter
DB Custom
DB Custom's picture
Sorry Scientist, for portability and max outputs with multiple 333A’s you would need to mount them on a sufficient heatsink with a linked fan for active cooling, or maybe utilize a PC liquid cooling system. So a box, with a multi cell power supply, would need to be constructed.
Dale
Scientist
Scientist's picture
Thanks DB. I am a real newb at this. I have been reading though and understand the problem better now. Your light looks really nice. Tell us how you like it. Must light the place up. I’ll have to read a lot more to translate what you are using for your light.
Lexel
Lexel's picture
The 333A run in a host like the Convoy L6 would be enough cooling, maybe the buck driver can be modified and is fine with a 4.2V LED
if you are going for a multi LED light source there are cheaper ones like LiteOn with 3535 footprint fitting on Cree DTP MCPCBs
Those LEDs can deliver about 1W UV at the price of about 7$
the only drawback is you need a ZWB2 filter if you dont want the white wastelight this LED produces as well
http://www.mouser.com/ds/2/239/LTPL-C034UVH365%20DataSheet_Ver4_20150916...
here you can see multi LED DTP MCPCB
https://www.aliexpress.com/item/20mm-Cooper-PCB-Cree-XPG-XPG2-XPE-XPE2-X...
