There was some discussion about it a while back on one of the forums. Not really a wild guess. I’ve owned and been using PCs and various types of smaller electronic equipment for more than 35 years. I sometimes get intrinsic thoughts and feelings for electronic equipment it’s behavior. Many times while troubleshooting and repairing electronics these intrinsic thoughts and feeling have proved to be correct.
However I’m not saying my intrinsic thoughts and feelings can’t be wrong. I’m open to ideas, possibly procedural testing methods that can be performed to eliminate and prove possibilities that are wrong.
I no longer have my electronics lab setup with various types of electronic testing equipment and only perform modest electronic repairs using a DMM when able.
I currently have problems with heart disease and breathing, along with past heart surgery that prevents me from doing things I use to be able to do without any problems.
You know, my v 2.2 has done what sound like the same thing on occasion when doing 4 cells (18650’s) at 1A each. I just figured it had something to do with heat or the load being to much for it…… That would be a “wild guess” too, no hard data or scientific theory to back it up……….
So, I just started using the Lii 500 in those situations.
Simple solution for me, but I would like to find out for sure sometime what causes that.
I spoke too soon. That was yesterday! Did a Discharge/Test @ 1amp. I came in the room right after the 4 X 18650 Orbtronic were discharged and just went into CHARGE cycle. I noticed it was charging @500mAh and the Capacity data was NOT there. I set it back to 1000mAh. Came back in room 5 minutes later and it was @ 500mAh again! Set it back to 1000mah and this time I watched it. Three[3] times in a row the unit reset[shut off] and defaulted to 500mah again!
I am not sure whether it is the power supply , failing thermal sensor[?] or just over heating inside.The charger NEVER feels hot.
I think it is overheating because the power supply should be plenty according to HKJ. I asked HKJ earlier today if 12v/3a is enough for 4 batteries @ 1amp?:
"Easily, 12V 3A is 36 watt, 4 batteries with each 4.2V charged at 1A is 16.8 watt, there is a lot of spare power for display and heat".
I am disappointed because this one had more accurate results w/ capacity tests and gave me a slightly higher charges. I called Jon from LIIONWHOLESALE and am getting another one on Monday! He is a very nice guy. So this will be my third one since March 2,2017!
If the Third one fails I am done with these chargers! He told me he does not get reimbursed for these. I feel bad for him.
People can say what they want about the less technologically advanced FENIX ARE-C2. They have longevity[3 years plus] and are consistent w/ no issues!.Must be the simpler technology!
[quote=wolfdog1226I asked HKJ earlier today if 12v/3a is enough for 4 batteries @ 1amp?: Easily, 12V 3A is 36 watt, 4 batteries with each 4.2V charged at 1A is 16.8 watt, there is a lot of spare power for display and heat.[/quote]
What I did not say was that it requires that the charger know how to handle the power. The first versions of the C3100 charger was very bad on that, in later versions it was improved, but not perfect. This means that a sensitive power supply may give the charger problems.
But you have the problem during discharge and that do not make any sense, the charger is not supposed to be loading the power supply when doing discharges.
That means you power supply is rather sensitive, try a more powerful one. The opus charger do have some nasty spikes in its power draw, a large capacitor in the power supply will handle it (or a slow over current limiter). The problem is not the average current draw, but the peak current draw, the power supply supplied for my test had no problems with the “fixed” version of the Opus, but a power supply with very fast over current protection will have a problem.
A guess would be that Opus has change supplier of power supply, without checking if it can handle the requirements of the charger.
YEP)!!! That is exactly what mine does. :+1:
Which I really would not mind so much….
…BUT for the fact that ALL the Capacity data is lost and resets each time it does it. :person_facepalming:
Jon from Liionwholesale’s guess is that it is overheating and/or may have a failing/bad thermal sensor?
EDIT: The theory about over heating makes no sense to me because the charger NEVER feels hot. The power supply gets warm but not hot like Opus number 1!
I doubt it, in my opinion the most likely cause is the power supply. The Opus will draw more than 3A in peak current, in my test I measured 6A for nearly 0.02 second. Then 0A for 0.03 seconds, bringing the average below 3A
Hey wolfdog…… what size is the plug that goes into the charger?
I am not home right now to look.
But I am gonna try to pick up a used power supply at the electronics shop in town before I go back to the compound.
But I need to know the “plug to charger” size………
Thanks in advance for any help given here………… :+1: …
Let me look,not sure if I can decipher while it is charging!
I looked on line for these and they were $15 and up,I do not want to pay half the cost of my charger for a power supply! I am not confident If I ordered one online that it would be the right one,when I can just get another opus,probably w./ the same issue!!
There is no indication of the size of the barrel plug in the manual or written on the charger/plug itself. It will take 10 or 15 minutes to post pictures,that will give info gausse wants but may not help for barrel plug size.
