Difference between Opus BT-C3400 & BT-C3100 v2.1?
That means you power supply is rather sensitive, try a more powerful one. The opus charger do have some nasty spikes in its power draw, a large capacitor in the power supply will handle it (or a slow over current limiter). The problem is not the average current draw, but the peak current draw, the power supply supplied for my test had no problems with the “fixed” version of the Opus, but a power supply with very fast over current protection will have a problem.
A guess would be that Opus has change supplier of power supply, without checking if it can handle the requirements of the charger.
YEP)!!! That is exactly what mine does. :+1:
Which I really would not mind so much….
…BUT for the fact that ALL the Capacity data is lost and resets each time it does it. :person_facepalming:
:slight_smile:
EDIT……….
+1 on this too.
I do not have a more powerful power supply.
The picture will have to wait until tomorrow as I am testing again to see if it gives the same results!
I am getting another Opus on Monday! If that one fails I give up on Opus all together or buy another power supply which I do not want to do.
I love the longevity, simplicity and reliability of my FENIX ARE-C2! :+1:
Jon from Liionwholesale’s guess is that it is overheating and/or may have a failing/bad thermal sensor?
EDIT: The theory about over heating makes no sense to me because the charger NEVER feels hot. The power supply gets warm but not hot like Opus number 1!
I doubt it, in my opinion the most likely cause is the power supply. The Opus will draw more than 3A in peak current, in my test I measured 6A for nearly 0.02 second. Then 0A for 0.03 seconds, bringing the average below 3A
ok,If I go that route I do not want to order online. I have to find a place that sells them where I can bring my charger to make sure it works.
If it is indeed the power supply the new one I get Monday will probably have the same issue!
Hey wolfdog…… what size is the plug that goes into the charger?
I am not home right now to look.
But I am gonna try to pick up a used power supply at the electronics shop in town before I go back to the compound. :wink:
But I need to know the “plug to charger” size………
Thanks in advance for any help given here………… :+1: … :wink:
Let me look,not sure if I can decipher while it is charging!
I looked on line for these and they were $15 and up,I do not want to pay half the cost of my charger for a power supply! I am not confident If I ordered one online that it would be the right one,when I can just get another opus,probably w./ the same issue!!
My bad, don’t worry about it if you can’t. I’ll just try tomorrow when I find out the plug size. :wink:
There is no indication of the size of the barrel plug in the manual or written on the charger/plug itself. It will take 10 or 15 minutes to post pictures,that will give info gausse wants but may not help for barrel plug size.
Thanks gauss163. :+1: I appreciate that info. :slight_smile:
Already got the size from gauss, so the only thing left is the power supply spec pic for gauss. :+1:
THIS IS THE SMPS FOR MY OPUS 2.2 VERSION
Are you sure Gausse?! I may order one next week!
FAVOLCANO FAVOLCANO® AC 100-240V To DC 12V 5A 60W 5.5x2.1mm DC Output Jack Power Supply Converter Adapter for Led Li
$21.13,crazy,more than half of what I paid for the opus!
This OPUS thread is bringing the love back,no more bickering! :slight_smile:
OK,Thanks,I will check that out.
I did find some on Ebay for $7,seems awfully cheap………I wonder what the quality will be?
I’ve tried to make my 3400 produce the problem—it won’t do it—charging (4) 30Qs at 1amp without a hitch—-my 3100 is at my camp—I have also tried my power supply from my hobby charger 12v/ 5a —-works perfectly—these are readily available on ebay— also I’m curious if anyone has a car adapter—try it in your car on straight 12v
http://www.ebay.com/itm/12V-5A-60W-AC-Adapter-Charger-for-CHI-LCD-Monitor-CH-1204-CH-1205-Power-Supply/231042910306?\_trksid=p2385738.c100677.m4598&\_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20160908110712%26meid%3D74420f7d11b8465881499e82f412f71b%26pid%3D100677%26rk%3D3%26rkt%3D12%26sd%3D311727670774
I just retested my 3400 with my 2a power supply—-it reset almost the instant it started charging—I’m pretty confident it’s a power supply issue—if I remember correctly the 3100 has a more rounded edge PS—where as the 3400 I have it’s square—most likely updated
Thanks,according to Gausse the one you posted has the Wrong barrel connector size.
Connecter size: 5.5mm/2.5mm
It should be 5.5mm/2.1mm??
One of you are wrong,I just ordered the 2.1mm,I hope it is the CORRECT one!!!
P.S. Mine never failed while charging 4 x 18650 @1 amp,only when I did the charge /test
Not sure what size barrel I have— it’s plastic insert is yellow—thought it might be color coded
I’ve had this 3400 for almost 2yrs—I always charge/test at 1a—— 4 at a time—-I’m talking 100s of cells from pulls to new —never had the issue you’ll are having
EDIT: my 3400 PS is the Asian Power Devices APD WA-36A12U as stated above
Were you doing it like outlined below chops???
