Hey wolfdogâŚâŚ what size is the plug that goes into the charger?
I am not home right now to look.
But I am gonna try to pick up a used power supply at the electronics shop in town before I go back to the compound.
But I need to know the âplug to chargerâ sizeâŚâŚâŚ
Thanks in advance for any help given hereâŚâŚâŚâŚ :+1: âŚ
Let me look,not sure if I can decipher while it is charging!
I looked on line for these and they were $15 and up,I do not want to pay half the cost of my charger for a power supply! I am not confident If I ordered one online that it would be the right one,when I can just get another opus,probably w./ the same issue!!
There is no indication of the size of the barrel plug in the manual or written on the charger/plug itself. It will take 10 or 15 minutes to post pictures,that will give info gausse wants but may not help for barrel plug size.
Iâve tried to make my 3400 produce the problemâit wonât do itâcharging (4) 30Qs at 1amp without a hitchâ-my 3100 is at my campâI have also tried my power supply from my hobby charger 12v/ 5a â-works perfectlyâthese are readily available on ebayâ also Iâm curious if anyone has a car adapterâtry it in your car on straight 12v
I just retested my 3400 with my 2a power supplyâ-it reset almost the instant it started chargingâIâm pretty confident itâs a power supply issueâif I remember correctly the 3100 has a more rounded edge PSâwhere as the 3400 I have itâs squareâmost likely updated
Iâve had this 3400 for almost 2yrsâI always charge/test at 1aââ 4 at a timeâ-Iâm talking 100s of cells from pulls to new ânever had the issue youâll are having
EDIT: my 3400 PS is the Asian Power Devices APD WA-36A12U as stated above
I charge 4 cells at a time @ 1A often, and never had that reset happen. My power supply is plugged into a Tripp lite Isobar with line filters though. Wonder if that has anything to do with it.
