If a charger can run “muggle” simple and you have the option of getting more out of it for a smallish investment of time and $$$ why not get the lii 500 and grow into it?
Both Lii-100/Lii-202 and Colaier clones are so cheap you just can't go wrong purchasing them, even if you get something better. It's like driving an easy to handle sub-compact car for commuting into the city, to later switch to your sedan/SUV for other purposes. ;-)
And with regards to the ≈⅔ SoC to maximize life cycle, I prefer to remove a partially charged battery from a laptop because of the irksome inability to tune the maximum battery charging voltage. Full and hot cells in an always plugged laptop means early death for the battery, and those aren't cheap. Overhauling them can be done, but requires a lot of effort, tools and knowledge most can't/won't afford.
In my phone, I do the aforementioned up to ⅔ SoC on the battery thanks to a nifty app which plays me a tune when it reaches specific triggers (example: connected and battery >= 60%): 3C Battery Monitor Widget. The added benefit is that I actually spend less time plugged at the charger/PSU because my device's battery seldom enters the CV charging phase, which can be looong for these high internal resistance battery equipped devices.
@ teacher If you don’t mind me asking which DMM do you have?
I read on the forum that some people like running fans while charging to help with heat. In your opinion is it a good idea and if the battery is venting does the fan push anything around in the room from venting? Also I read people bring solar panel with them camping for the charger. My question is can you charge in direct sunlight because of heat?
It seems like more and more manufacturer are going with usb chargeable light. Do you think that they will replace a charger like Lii500 or they are targeting the people that don’t want to buy a separate charger & battery? Something like the Nitecore Tip, do you have to take it apart to check the voltage or to inspect the battery or use it until the battery won’t take a charge no more?
When you said the Lii500 is idiot proof if you put the battery in and don’t touch nothing the charger will determine what battery it is, what to charge it at and so on?
I don’t know where the batteries are located in the plastic case, so when I try to crack it open with a screwdriver and/or a hammer I might hit or go through a battery causing more harm than good.
Start with finesse. I wriggle something sharpish into the seam at each corner then open the seam a little at a time until there is room for my fingers to pry it open. I never insert anything metal into the case, gotta respect the power of the cells.
1.] DMM’s
………a.] 2 or 3 cheapos
………b.] Equus Innova 3320 & 3300
………c.] Vici VC99
……………x.] These have been collected over many years
……………xx.] IF you are just going to measure battery voltage, a cheapo will most always work as well as an expensive one.
2.] Fans
………a.] I don’t / haven’t, but it sure can’t hurt.
………b.] It probably would
3.] Solar Panels
………a.] Hmm, never thought about it. Put panel in sun & charger in shade.
4.] USB Charging
………a.] No, I don’t think so
………b.] Not really, they are just handy at times…IMO
………c.] Nitecore TIP…. Just use it & charge it
5.] Lii 500
………a.] Yep, that is what I have been telling you. It will do it all for you OR you have the option to set it to do what you want it to. That consists of a few simple modes…. discharge capacity. charge capacity, etc., etc.
IF all you think you will ever want to do is charge…. just get a charger. BUT, if you think you will want to learn to do more, you will have that option with the Lii 500 because it is an analyzing charger. Simple as that.
@ teacher I was at at a local store and they had Eneloop 8AA & 4AAA 2C&2D & spacer with case & charger (cc17) for $32.99. Batteries was made in japan charger made in china. Do you think it’s worth it? I price it individually and it almost like getting the charger for free.
The only reason I ask about the Nitecore Tip, I was going to get one for somebody as a gift that know nothing about lights.
I made a little typo I meant to write 8AA & 4AAA (fixed it). It’s called Eneloop Power Pack. Walmart has it and Target has it. You can go online to see if your local store has any.
Thanks for the info Venom.Wal-Mart here doesn’t carry Eneloops anymore & the closest Target is about 40 miles away. But that does sound like a fair price for what you get. :+1:
Ha, I had not even noticed the “typo”…. I read it like you meant lt.
By the way, some of us use the advanced editor since it's way more powerful. If you see garbled text when doing a quote, it's more than likely because it is in the advanced editor format, so you may switch to it for the stuff to be seen correctly.
I didn’t think about WM.COM…… Seems like a pretty decent deal with all the extra’s in it. I use those C & D adapters from time to time…. and you’ll have one of those chargers to so you can get going.
@ teacher, Is the Innova 3320 accurate? Do you have to calibrate it? How do you calibrate a any DMM?
Is the Eneloop kit worth it for the batteries?
I’m going to pick up another charger. A general question on the CC17 charger, Does it detect half drain battery and top them off or is it time charge for certain time period and for half drain battery there is a potential for over charging because of the
Does the C&D adapters take up the space in the flashlight so you can use a smaller battery instead of a larger battery?
Go HERE and it will give you the basics on calibration. You will need a known voltage source to calibrate it. You can get something like THIS , THIS , or THIS if you require absolute accuracy.
4. As I have said before, the Eneloop kit sounds like a pretty decent deal/price.
5. No the CC17 will not overcharge the batteries. No matter if they are almost full or almost empty when you charge them… it will stop when they are full.
6. Yep, you just slide a AA in the adapter and use it like a C or D size battery
When I get Lii 500, can I do a DMM accurancy test with it and using the Eneloop? Walmart has the Innova 3320 for $18.80, does that sound like a fair price?
The more I read for answer on this forum the more question I have.
Pretty soon you will have double the post count. j/k
