Anybody received their`s yet, I want to know it charges nimh fully before i buy a couple, I am not interested in charging or using li-ion battery`s
Thanks
John.
I will check the resting voltage on an Eneloop charged in the E10R once I have it in. I will be pretty disappointed if it indeed only charges to 50% capacity, the whole point of buying the E10R was because of its inbuilt NiMh charge capability.
Thanks
John.
Well I got 1.38v hot out of the flashlight on my AAA E01R and the guy who reviewed the AA E10R after i asked said he got 1.37v maybe this has been fixed in the latest batches but i don't want to get stuck with a couple of E10R when i am already stuck with an E01R though i am still using it.
This will not be a problem for people who only want to use li-ion cells as it charges them fine to 4.19v according to the review.
I did experience the same problem as well. 14500 charging seem fine. Charging process terminate @4.19V. Whereas, AA (Ni-MH) charging ends @1.38V.
Tinderbox UK wrote:
It looks like the E10R has the same problem charging nimh battery`s according to the review in the link below got 1.39v 50% however he got 4.19v on li-ion which is a full charge.
Does Jetbeam know about this problem, do they have an REP on BLF?
John.
I also 1.38V. I have meassured qith the doctor USB that stop after 725mA in...
Was the battery empty before you charged it?, On my AAA E01R my usb battery meter mah reading was very close to the discharge capacity on my Maha C9000, So your 725ma on an empty AA 2000mah is not even 50% charged.
I received my lights yesterday, I haven't unboxed these yet.
The method is to measure the cell voltage after charging to verify full or not?
I do not have the USB amp meter device, just a Harbor Freight DMM
On my AAA E01R, I dont have the AA E10R
I discharge the nimh to 0.9v in my maha c9000 then charged the battery in the Jetbeam till the red led turns off, Then i take out the battery and measure the voltage, I get 1.37 or 1.38v then i discharge the battery in my Maha C9000 at 100ma to see the actual capacity the Jetbeam put into the empty battery.
I have done 6 charge discharge cycles and 5 were only 50% capacity, 1 was 75% capacity of the battery capacity on my E01R AAA
So you need to do this on your AA E10R to check out the nimh charging.
The battery was empty before it began to fill.
The method is not precise, the ideal is to measure in discharge. But this gives us a rough idea. Normally, I put in my Fujitsu 1900 mA around 2200mA with this method. And now I only get 725mA, around 1/3 …
With 14500, all my brands protected and unprotected runs fine, not size problems.
Aw IMR unprotected is really very short battery, but the E10R runs fine with it (of course I will not charge this IMR unprotected battery inside the light)
Why not? The charging scheme seems fine for 14500 cells?
I received my E10R today. The UI is so-so but I really like the size and elegance. It will have be used as a 14500 light I’m afraid, and I hope to do a led-swap.
link to djozz tests
John.
Maha C9000 – LaCrosse BC-900 – Floureon BT-C3100 V2.2 – Accumanger 10 and 20 -Thunder AC6 LiitoKala Lii-100 – Cozypony 24W Solar Panel – Soshine H4 – Soshine T2 – Soshine E4S
Please PM with purchase info.
There will always be more darkness than I have lights.
I did reply my observation on my other thread.
No visible PWM in all modes for Li-ION and Ni-MH.
Interested.
I also 1.38V. I have meassured with the doctor USB that stop after 725mA in…
I received my lights yesterday, I haven’t unboxed these yet.
Paul-
John.
John.
I will test with charger this weekend.
AW looks quite short in the pic.
Hi. Interested.
Sent.
Interested. Thanks.
link to djozz tests
Sent.
Hi, I would be interested in one of these if you have a code.
I have to request for new one next week.
Well, put me down as interested in a code as well!
Thanks Freeme!
ALL of my links are non-affiliated for your pleasure...
My Reviews
Lithium Ion Battery Safety 101
Winners of E10R GAW are:
1st: Vegas1 (KLARUS mi7 Ti)
2nd: patmurris ($10 Fasttech Gift Certificate)
I’m interested as well please
Wow! Can’t believe I actually won something.
Thank you very much.
Congratulations to the winners!
send code and link. Thx.
Also send code and link for alum lumintop tool. Thx
Congrats patmurris and Vegas1.
link to djozz tests
Just the info I was looking for, thanks for posting this.
