And that was using the 20mm XP DTP MCPCB with the largest thermal pad. Sinkpad XP has much smaller thermal pad. I guess your E17A will fit better in XP MCPCB
The gap looks to be at least as large as in the XHP70, though it will probably be less noticeable because of the phosphor covering, sort of like the XHP50.2. But whether or not you see a donut hole in the beam, gaps reduce the peak beam lux in a reflector light.
Looks way smaller then an XHP70 to my eye, got to remember that this is a 3535 footprint they are sitting on, the xhp70 sits on a 7070 footprint, twice the size.
To me it looks lighter packed then an xhp50. In fact it would not be hard to figure out, if clemence can measure the total size of the dies we can compare that to the total size of the xhp50 dies.
The E21A package width is 2.1mm, so similar to the XHP70 individual die size. Estimating from measuring images:
The width of the gap between the dies in the XHP70 is about 7% of one die width. For the E21A quad pictured above, it is about 13%, even taking into account the small gap between the packages. So there is comparatively more dim/unlit area in the E21A quad.
FYI, those picture taken with ultra low current from my multimeter. And I haven’t use silicone to bridge the air gaps in between tiles to reduce photon crossing losses.
What I had not hoped for with the 17A and 21A: the actual die under the phosfor is clearly smaller than the full dimension of the led, thus the fading edges. That will not be solved by filling the gaps with silicone. A quad led set-up will face the same challenges that the first gen. XHP leds (and the old MC-E and MK-R) have: no smooth reflector for this quad!
Silicone will reduce phosphor surface temperature by reducing the photons bounced back and accumulates heat on the phosphor surface. Each time the photons hit air gap, they will bounced back unless in straight line. I didn’t mention it to cure the cross mark.
FYI, they survived 8A (for a minute or two). Still editing the pictures
Well that looks a bit more promising. The picture really shows which parts need better heat sinking. Do you know if noctigon XP16/20 MCPCBs use 2oz copper thickness? It seems like the area/layout of the copper on the MCPCB could make a big difference, too. On noctigon stars the trace from the pos and neg contact is the width of the footprint (3.5mm). On the other hand, on this 20mm TPAD I have in front of me the trace is thinner and there is a bottle neck of 1mm right at the footprint; not as good for heat transfer. Ideally the trace would spread out and cover as much area as possible to increase the heat transfer across the insulating layer to the metal below, just like the Nichia 119 MCPCB that djozz designed.
Based on my thoughts above, I think I came up with a good MCPCB design for good heat transfer from the non-DTP LED contact. Start with a copper disk or sand off all the insulating stuff on a copper MCPCB. Then put down some Kapton tape covering all the area except for the DTP area where the LED cathode will connect. Cover all the Kapton tape area with copper tape; this will be the other LED contact. I have some copper tape that is 2-3 thousandths of an inch thick, which is about 2oz thickness. I made a mock-up of this design on a TPAD MCPCB; see picture.
The copper tape is electrically isolated from the bulk copper below. The Kapton tape doesn’t have very high thermal conductivity, but is very thin, about 1-2 thousandths, which is about 3-4x thinner than the dielectric layer on MCPCBs, by the look of it. When the Kapton tape is spread out over a 20mm MCPCB the extra thermal resistance is only about (40microns)/[(300mm^2)(0.12W/mK)]=1.1 K/W. This should make for good thermal transfer away from both LED contacts. I tried soldering on the copper tape, and the copper tape adhesive got a little soft when everything was at soldering temperature, but once it cooled down it stuck well again.
The Sinkpad has a way better heat transfer from the outer solder pads than Noctigon
if you look right the positive and negative side go all the way over the star like a bar between the 2 wire pads
it looks pretty much like your self made star cut to half width
maybe someone makes a board with insulated base and 3 DTP pads insulated by a dielectric
That would work well, but I doubt someone makes it.
I estimate that, in my design above, the bottleneck is the thinness of the copper tape. Heat will have trouble traveling laterally. Using ~1mm copper shim instead of the tape should greatly improve the lateral heat transfer.
It’s done already. 144A and E21A are exactly what the new VirEnce board all about. Only one problem left: $$$$
Until then, Djozz board is your best option. It has very large copper pour for its size and thick copper base. One problem for extreme BLF application is the dielectric used is only 3 W/MK.
A single E21A can be driven really hard > 3A on Djozz board. His last test showed that 144A with 4 times the heat performed OK.
