Testing a Cree XHP50.2 J4 3A led
Thanks for explaining things.
It seems these new lower voltage emitters, including the 70.2 which should be out soon, are not the easy upgrade many were hoping for.
It depends on the light you will be upgrading. Most lights that came with an XHP already installed will be a simple drop in swap to the newer LED as they already use a buck driver.
With the stock L6 driver it would have easily worked as a direct drop in, the only reason you are seeing worse battery life is because you modified the driver to remove the current regulation.
In fact at the stock output level of the driver the xhp50 should be more efficient and give you longer battery life (with less lumens naturally) due to it being a more efficient LED.
The xhp70.2 will give you better battery life for sure with the buck driver at the same current as the lower Vf means it will be pulling less total watts. It will also remain in regulation longer and should give you a bump in output as well along with hopefully eliminating the donut.
All the guys running FET/DD drivers will be sad. I, myself, just ordered a Texas Avenger driver. :person_facepalming: Oh well, I’ll just stick with the regular xhp70 for now.
What are all the hot-rodders gonna do when these new emitters make FET drivers a bad choice? Will they just avoid the new emitters or find new drivers that can push them, but not too far?
Simply use a cell that can’t supply beyond the 10A or so.
I don’t have a problem hooking them up, my triple 50.2 “only” pulls a little over 20A.
The thing is, at 10 to 12A on the 50.2 you’re beyond the max output level and just burning amps for heat. The XHP-70 can still make output levels at the same 12A so it’s got the advantage. The MT-G2 can do 16A, but peaks around 7-9A. I’ve had em doing some 4300 lumens at 16A. And the XHP-70 makes around 7200 lumens at 12A. The 50.2 can’t compete. And the new phosphor aka XP-G3 gives an odd tint to the beam so it actually has losses in comparison to other emitter choices.
Now that there is a reason, there will be new drivers made to take advantage of the lower Vf, just a matter of time.
The easiest fix right now is to simply turn the max PWM down on the TA driver to get the current you want, it will still drop off as the battery drains but at least you will limit current to what you want.
I do this with 219C’s or small lights that I want to limit the heat in. I simply set the max PWM to keep total power where I want.
A firmware upgrade could allow for very crude “regulation” using this setup. While not perfect, it is better then we once assumed. In my testing you only loose about 10% efficiency @ 50% duty PWM. This is a worthwhile tradeoff for the low cost and compactness of a PWM driver over a buck driver.
Although I do have slightly better improvements in mind PWM regulation is the way of the future for cheap and compact drivers. For lights that can use larger drivers buck drivers will become much more popular.
If you PWM a XHP50.2 at 12A, you still get the inefficiency that the die has at 12A, just not the heat sag. The output drop at high currents is not solely caused by heat. Do you know what the individual contributions of those two effects are?
I agree with Dale’s post above. I think these low-Vf emitters can be used advantageously in multi-emitter lights (triples and quads). Direct drive with a single emitter (XPL2 or XHP50.2) usually results in a lot more current but not a huge output increase because the output curve tends to level out at high current. But in a triple or quad the low Vf allows to drive each emitter more optimally. For example a triple XPL with a single cell might draw 12A, or 4A per emitter, but a triple XPL2 might draw 5-6A per emitter which is near the optimal current before the output curve levels off too much.
Of course these low-Vf emitters also tend to not have as good throw, but that’s another story.
I don’t have a function generator to test this as completely as I would like but in my testing I have consistently seen results in the same ballpark as the XHP35 PWM I posted.
In that test it lost about 11% efficiency @ 50% duty tapering to 0% loss at 100% duty. In other tests I have seen similar numbers.
Thus as the battery voltage drops the efficiency loss will taper down to 0%. So it could actually be brightest on a slightly drained cell.
That loss ~11% is really not so bad. However, the loss should depend on the peak pulsed current, so it could be higher with these low-Vf emitters.
Yeah, it does depend on the pulsed current although the xhp35 is a pretty good comparison from my un-publised testing.
I have tested a few other low Vf emitters and they had very similar numbers, some slightly better like the XP-L2 I played with and some slightly worse (like the 144A I played with).
At 50% duty it appears to range between 10-15% loss. Which like you say, is really not that bad, the higher the duty the lower the loss. Using thin wires and low drain batteries improves the numbers as well. As the battery voltage drops the efficiency loss drops to 0 as well.
The lower ranges can be taken care of with current regulation in most cases without much trouble.
PWM is not ideal but it is cheap, effective, simple and compact. It does have some advantages as well such as little to no tint shift in different modes, seemingly better tint / CRI in my experience ect.
Future drivers will most likely use a combo of constant current and PWM if I had to guess.
What would a change to a 50.2 from a 50 in a standard light like EA81 do? If anything.
One of my build plans was to take a single 26650 light (ultrafire F13) and run a pair of 26350 batteries from Banggood along with a direct drive 22mm driver from Mountain Electronics then put in the xhp50.2 that I tried out in my Convoy L6.
Now I know that will pull way too many amps. I can’t switch to amp limited batteries as they don’t exist. I don’t know of any non direct drive drivers that will work. Do you guys know of any?
I guess I’m gonna have to shelve the 50.2 and buy a new xhp70 to run in it. Does that sound right?
One thing to keep in mind with the 26350 cells is they can’t handle much more than 7A. See discharge curves at the bottom of the banggood listing. Banggood says they are out of stock, by the way.
These 26350 cells with an XHP50 V1 resulted in about 7A on a full charge. Using an emitter with a lower Vf would, in my opinion, probably be asking a bit too much of these cells.
They are in stock at FastTech.
I was thinking they would do way more than 7 amp, but I was thinking wrong. My memory is not always so good. :person_facepalming:
I would like to limit the current to 4 or 5 amps which I think would be great in a small light. I just don’t know how to do it. :weary:
Update, I was looking around at MTN and saw they had a linear driver for 6 volt use. This is a 7135 based driver.
Can someone give a summary of how the new low voltage emitters will respond to different driver types?
I think there is going to be a lot of confusion over this.
Direct drive = We know that they will draw way more amps than the regular xhp50 and xhp70. Not good at all unless you can limit the amps by using certain batteries or some other means.
Boost and Buck = It should draw the same currents. We may get improvements in efficiency, right?
Linear = It should draw the same currents. Anything else I’m not sure.
BTW, I tried my L6 with the 50.2 in it with some fully charged protected KeepPower 5200 26650. They are supposed to have a 10 amp limit. I expected them to trip the circuitry on turbo, but they didnt. Maybe they limit it to 10 amps?
Compared to fully charged Liitokala it’s not quite as bright and it’s not heating up as quick. In fact, the KP are getting a lot less current in all modes. Even slightly less current than the xhp70 with the KP batteries. Pretty interesting.
I can only compare amp draws as I don’t have a clamp meter to get exact numbers. I know where I can borrow one if anyone is interested. Idk, maybe I’m boring you guys. Lol
That 22mm driver will work, you can simply not use the highest mode until the battery voltage drops or have RMM set the max pwm in turbo to say ~200 to limit current. It depends on how much self control you have.
So I was thinking about these new generation LEDs with FET drivers. If the MCU is monitoring cell voltage with an ADC for LVP, would it be possible to reprogram the MCU to use the value it reads to limit the PWM until cell voltage falls?
Ex. If it sees the cell voltage is at 8V, only command a maximum of 75% PWM or something, then when the cells are down at 7V let it get to 90%, etc.
If that does work it should let us take advantage of the efficiency increase of the new emitters as well, which linear does not.
I was able to borrow a clamp meter to measure amps on my L6 with 50.2. I used a 10ga wire (too big?) on the tail end.
With the Liitokalas 8.9 amp.
With the KeepPowers 6.7 amp.
So no giant 12 amp loads, but that is a big difference just between batteries.
Compared to my xhp70 with same driver (rough estimates until I put the xhp70 back in)
Liitokala 8.0 amp
KeepPowers 6.4 amp
Hey Jason,
I am planning on making a very similar build, with a mt-12 body (similar to F-13), a mt-g2, and a pair of 26350 batteries.
I’m planning on using this driver:
http://kaidomain.com/p/S025265.New-FX6-22mm-6V-8_4V-5A-2-Groups-of-3-to-5-Mode-Driver-Circuit-Board-for-Cree-XHP50-XHP70-MT-G2
Well that’s if it ever gets here, kaidoman took 21 days to ship it out.
Supposedly the driver is regulated with a high of 4500ma, I’ll see how it performs if it ever gets here.
In theory it should provide a nice regulated output for the new low vf emitters.
