ok,everything is in order!! Came 10 minutes ago,batteries charged in 2 minutes and went into discharge mode,It should be done ~ 7:45!
I will give a report when itās done! I really hope this is the solution!
I bought 2 Power supplies in case one did not work!!!,the first one did not leave Calif. yet and I ordered that 12 hours before this one that came from Portland, Oregon!
Aww come on now āYou know you want to use your old chargers
PSā if you dont have any extra fans for the Opusāget someāI buy them by the half dozen
I ordered Two different Power Supplies just in case for back up. One Friday night,that will not be here until Saturday!Of course the Supernight which arrived in 2 days!
Durability and longevity is yet to be determined,so far so good on day #2! I expect my Third test result to follow suit. That should be done by early evening b/4 CAPO and I go on our hike.
There is another way to look at getting one NOW. If your doing a lot of capacity tests the worst that can happen is you lose $6.99 if it fails! On the other hand you can let Wolfdog be the Guinea Pig and see how durable and reliable it is. Then again, I may only run One or Two more CHARGE/TESTS in the next few months!
Confused?! YOU MAKE THE CALL! :person_facepalming:
Yep Woldog, so far you have been a good āGuinea Pigā with some good results. ā¦ :+1:
I am glad this appears to have been the problem. Kudos to you & your testing.
But me confused? Not sure what you are getting atā¦. but never in your wildest dreams am I confused about this.
And be most assuredā¦ā¦ I will make the call when I get ready. Whether that be in 5 minutes or 5 years. It is not a though this is life or death yaā knowā¦ā¦.
Itās all good Wolfdogā¦. even if it does fail, you ātook one for the teamā. ā¦ :+1:
Iāll be the first to contribute to the āReimburse Wolfdog Fundāā¦ā¦.
ā¦ā¦ā¦ā¦ā¦hopefully that will go better than the āSend āteacherā to China Campaignā has gone.
I I ever get a better one, It will be brand new! These are not cars we are getting where you know how many miles are on it and how old it is! That is my thinkingā¦ā¦ā¦I would not want a used one,Hopefully these TWO classics I have will last a while!!
I am going to do a CRUDE temp. check when the batteries are around 4.0/4.10v w/ my maintenance thermometer probe!
