Yeah, same here. I still have 2 more coming my way which I ordered before knowing about the NMM. I’m hoping that someone comes up with a fix for it as I don’t have the expertise to do so.
Some NMM drivers in the past could be fixed to no memory with a pencil stripe over a capacitor. Who knows.
I change the xm-l2 in ec4 to xhp50.2
But, too bad, it doesnt work properly, sometime it can go high mode, or doesnt work, or very low output
With 2 cell and constant current drivr, i hope it works, but disappointed, now i have to order xm-l2 led
XHP50.2 is a 6/12V LED
XM-L2 is a 3V LED
the old XML2 should be fine
I know, but i measure the Voltage when open circuit, it’s almost same as Vcc(about 7. Volt), so i guess it will adjust the volt so that current is stable
But, too bad, it doesnt work properly, sometime it can go high mode, or doesnt work, or very low outputWith 2 cell and constant current drivr, i hope it works, but disappointed, now i have to order xm-l2 led
I have EC4 with XHP70 and stock driver and it works well. You need to use thermal resistor.
I lost the thermal res when reflow the led(damm, that little thing), i dont know the value, so i just solder 10k resistor
So, i reflow the xpl-hi led, change mcpcb to cooper, now it works, so i guess my driver wont work with xhp50 led
I’m sad:(
This is bad news, I want to swap to XHP50.2 too in my EC4…
I dont know will it work, because kiriba said that he modded ec4 with xhp70, and it works, so… i dont know
Maybe difference in Vf
This is maybe my last pic of xhp50.2, before i lost it in my drawer
God, i always love seeing led under UV light
Yes, I got the driver from Kaidomain. Whenever you turn on the light, it’ll go to the next mode that you last turned off the light on. The driver has ll-l-m-h and then double click for strobe. So if you turned off the light on medium, it’ll start on high when you turn the light back on.
I have the same driver in a Eagle Eye X7 with a XHP50.2, even if it’s on time memory it will start on the same mode if the flashlight is turned on for more than 3 seconds, less than that and it will go to the next mode. Does your driver also have a pre-flash in the low mode ?
Yes, there is a pre-flash on the lowest mode.
Quick Mod on 1508 75mm:
- XHP35HI on16mm copper from Kaidomain
- 1 Mode Buck Driver from DX: http://www.dx.com/de/p/18v-5w-cree-circuit-board-for-flashlights-16-8mm-5-5mm-26110#.WO56sqKJI-U
- Modded with R100 instead of R200 for 2,5A, like wrote on Aqualab: LED Driver List - LED Drivers and Regulator Boards (database driven) (search for “TR-0021b”)
- At tailcap 2,33A
- with 4x 18350er Batteries
- Driver heat with https://www.fasttech.com/products/1…al-conduction-silicone-rubber-cubes-1105cm10- to the pill
At 5m I have measured 372kcd, thats aproximately 1220m distance.
Propably next steps:
- soldering MCPCB to the pill
- using thicker wires and bridging springs.
See although: Ultimate aspherical flashlight set / Uniquefire 1508 - #87 by Wieselflinkpro
I repaired a S2 triple’s LEDs (purchased a prepopulated noctigon and one LED was dim from the getgo).
Replaced them with Nichia 219b-V1 5000k emitters and a BLF a6 driver. Pulling close to 12 amps from an LG D1 at 4.33V. Beautiful smooth beam.
Voltage Meters
I added a removable voltage meter to the magnetic TP4056 Charger unit and potted the components side
Also some refinements to the charger tin
And a voltage meter on one of my battery drill packs
Just finished a Night Piercer mod of an Astrolux SC for a customer. LED swap, driver reprogram, bypassed springs, refocused reflector, upgraded wires, potted driver. Had to re-machine the LED shelf since it was bulged pretty badly in the middle but she’s nice and flat now. Came out at a cool 83Kcd (~575m).
You should post more details of that Eye of Sekhmet light if you haven’t already?
Looks really nice, interesting.
Wow…very nice…it’ll hurt my wallet though :person_facepalming:
I would like to know what led you used … Not the first time i ask , but it seems i may have to ask more times
