In regards to the testing that I have been doing w/ my NEW SMPS.
As I indicated before, ALL of my Six tests[3 Failures/3 successes] were done the same way. That is the batteries were put in around 4.10/4.12v for the Opus to top it off/discharge then charge back up.
I thought I would do the ENTIRE test in the Opus to make sure it could handle that extra session of charging, even though that part had nothing to do with the failure.
So I put 4 X 18650 Samsung 30Q FT in. All @ 3.64v. The test was another SUCCESS!
The only thing that is yet to be determined is the durability and longevity of my $6.99 SMPS! I do have an $8.38 SMPS coming Saturday for back up!
Are you talking about Zeepin? On the posting on Aliexpress, depending on which you choose (color and US or European) it either says Zeepin or Opus on the upper face of the product. Boxes look about the same with what appears to be a slight option in color (gray vs. blue/gray???).
I posted a similar query on slickdeals (where the original deal was posted) and someone mentioned that Opus is already a branding of the product, that Opus buys from OEMs and puts their label on it. I suppose that would make what I ordered a rebranded rebrand, so to speak.
When my unit arrives (which should be sometime in the next couple of weeks) I’ll take a pic and post it. It will be interesting to get feedback on it.
Also, Aliexpress claims full refund if the unit is determined to be a fake (wonder if that would include a fully functional knock-off…hmmmm).
Thanks for the welcome and the offer of help. Seemed like this was a good place for feedback (even tho the forum is about “budget lights” (Big grin :laughing:)
I RARELY buy over seas. There are plenty of GREAT dealers in the USA. One is 1.5 miles from me where I bought my Opus and get my batteries!
He lives across the street from me and is a great guy and his customer service can not be beat. it would take too long[especially since I need to go!] to tell you all the favors/deals he has given me in the last 2+ years!
Link below:
I was just responding to your curiosity/concern of the re branded Opus. I do not know anything about it!
,have a nice day on the LEFT Coast!,Wolfdog1226/Capolini ! :sunglasses:
Just wanted to add a +1 to this. I haven’t specifically checked it out, but if the small fans used in the charger are 5 or 12 VDC, they prob’ly draw much less than 100 mA (0.1 A), maybe less than 50 mA and you most likely would never see a spark from that low level of current. It would have to be up closer to 1 A or greater to see any kind of sparking. Caps are most likely the cause due to near complete discharge, especially if the unit has been left unplugged for a reasonable amount of time. Then the caps would look almost like a short for a very short time (thus, the inrush current) to the supply.
If you want to avoid the sparking (and eventual corrosion of the connector(s)), plug the adapter into the charger 1st, then plug the adapter into the wall. Current drawn from the AC outlet would be much, much less than that drawn by the charger (12V x 3A = 36W max, therefore, 36W/120VAC = 0.3A or 300 mA max, and much less if only 1A is drawn from the adapter at inrush).
Appreciate the link. If my purchase turns out to be valid, I just got a BT-C3100 V2.2 for about half the price (including shipping). Have to wait and see……
Not only not about just flashlights, but “political” commentary, as well.
I will enjoy, thanks…70 degree days, little humidity, beautiful blue skies (except for the bit of rain we’re having over the next few days). And, yes, many of us tend to lean left, but not until we’ve had a few glasses of wonderful California wine.
Cheers to you and all my American brethren. Glad to live in a great country (if one ignores some of the crap that goes on
I am glad I have two SMPS. The second one arrived today. I was planning on having that one as my back up because the SUPERNIGHT works Super!It is definitely my back up now!
This back up is getting its first test now. It just passed the transition from Discharge to Charge. I thought it was going to reset numerous times and it is still demonstrating that behavior even at the 3.40v mark!
After transition I hear a slight power loss and then it is restored. It has been doing that every 30 seconds[I timed it!] for 15 minutes! The SUPERNIGHT never did that.
Imagine someone revving up an engine very slowly and then releasing very slowly and then doing the same thing. That is the only description I can think of.Basically the fan noise weakens because the power is weakening. It is also WARMER now than the SUPERNIGHT was @ 4.1v which was the peak of heat intensity. We are only at 3.48v!
Hopefully the SUPERNIGHT will last! I would not trust this back up for long!
How do I know that these are better quality? How do I know how long they have been used and the duration of use per day? Don’t they sell those kind new?
Thanks,Dr. Capolini,“King of questions and analyzer to perfection”!
When I buy a car[used] i can see the condition it is in and how many miles are on it!
You leave my SUPERNIGHT alone!! It is top of the line primo quality!You recommended it , right??? That is right, you did not know I was going to get it!No justifying Gausse,bottom line you recommended it!!! So PIPE DOWN once and for all!!
I never said you claimed that it was high quality. I am saying that you recommended it and have badgered it several times since! You want me to open it up because it may be shabby. Shortly after you recommended it you posted others for Teacher that are supposedly better!
Supernight is doing fine ,does not get hot and has gotten the job done so far!
….It is way past my bed time,I get up at 5 every day to take the BOSS out!
I emailed the Ebay Hitachi seller to find out what size the barrel connector is. I want it to be 2.1mm NOT 2.5mm even if the latter fits, I am sure it would be losse.
