UltraFire SRK - 2017 new generation
Didn't verify this - can't check til tomorrow maybe. Sorry, only quickly checked a partially drained cell.
Ok - this is interesting, and good news! That's cool using the display, but not sure I understand. Probably used just a segment of the digit? Think these simplistic panels work that way? I think we used to call these 7 segment displays, because each of 7 segments could be individually turned ON/OFF, and could make any digit of 0-9, and many letters, for example: C, E, F, H, J. Letters like A, M, or N could not be made because of the 45 degree strokes. Letters like B, D would be confused with the digit 8 or digit 0, so not practical.
If you have any pictures or info on pin definitions, please post. Also can you confirm the one you worked on had no shelf?
Thanks for checking this light out!
Any info on the ledboard? How thick are the traces, especially close to the solder pads, where the most current will be? Will they handle more current? Non-dtp is alright up to 3.5A per led, so 21amps, if the ledboard is backed up with a copper plate and it sits well on its shelf. And you need to drill some clearance for thicker wires into the reflector.
Can't tell bout the traces yet - could check it out this weekend. In one of the pics, appears to be pretty thick on the left side. Think there will be clearance for thicker wires, but would have to verify. The LED alignment pieces give you 1.6 mm of clearance, if I left them as-is.
Does that 3.5A per LED rule still apply to these multi-LED boards? Think'n a lot more heat going around on that LED board, then if it was a single. Though the board is somewhat thick at 1.93 mm, I've seen thicker ones used in these SRK clones. I was planning/hoping to do full LED/copper DTP replacements.
I think I could definitely work out a driver piggyback solution using the switch and a single segment of a digit display. I see they have a 330 ohm resistor on the batt+ lead feeding the 12 pin ribbon, so think'n I can leave that circuitry in tact on the stock driver.
That driver retainer ring is real tough to work with - it's hard to tighten without twisting the driver - gotta figure a better way.
The more I look at this light though, the gray finish and styling is maybe the best I've seen in any SRK. Not a fan though of the blue bezel, though better than red - might strip it down and polish it up. Shame it has the waste of a charger, and the screwed down rubber cover. What's good bout the rubber cover though is you can feel the bump near the bottom so you can position it in your hand for the switch easier. Gotta update the OP.
That may be better after all.
I think that the 3.5A per led does easily apply for 5 out of the six leds if the ledboard is pressed well on the shelf with some thermal paste in between, but the middle one may just die because its heat path is very much worse than the rest.
I received a 7 emitter version with the orange bezel. Your OP is consistent with mine too, even down to the 1 screw on the reflector. Thanks for creating this thread. I think many of us will have some fun with this light and this will be a good place to share ideas.
Currently, I plan on using a 7135+FET type driver and finally trying Narsil. Replacing the tall isolater rings with very thin ones should provide adequate room for a copper plate behind the MCPCB. Hoping that makes the beam floodier as mine is pretty focused the beam pattern is unnatural looking with a distracting overly defined hot spot. I think the tall isolaters are blocking some of the light output. I'll drill and press copper slugs into the thermal pads. Want use one of the leds in the display as an always on location assist. Probably the middle led.
Not this one.
Almost sprayed my drink on my monitor. :smiley: Thanks Tom.
I want to explain it better: The Voltmeter had 3 times 7 segments to show the voltage. I used only 7 segment.
For 4.1V the display shows 1.
For 3.6V it shows 6.
I was searching for datasheets that fits the Display of the Flashlight and the Voltmeter. I tested the displays with very bad NiMh batteries in a 3S carryer or I used my multimeter with resistor test. After finding the correct datasheets I has written down the needed connections.
I do not have the flashlight anymore.
But I have made some pics: http://www.taschenlampen-forum.de/media/albums/fandyfire-r8.1620/
I see, you bought an aftermarket small digital voltmeter that had 3 digits displayed. A cheap one like this for instance.
Each digit was the same 7 segment style as the flashlight display. Then you jumpered the 7 or 8 wires that lit up the 2nd or 3rd digit (the one displaying tenths of a volt) to the flashlights single digit display.
That’s pretty smart. :+1:
Ahh, ok. Yes, didn't follow that. Look'n at your pics, you got definite non-CREE LED's there - think mine are real XM-L2's based on the look and power/output. I assume you got it here at DX: dx.com/p/fandyfire-r8-8-led-7000lm
Interesting. I have an identical un-branded 9-emitter clone of that light since back in June of 2016, that arrived DOA from DX. ( the one i have the driver arrived dead. I am modding it with a mechanical clickie side switch, Nanjq Q-Lite driver, and nine Nichia 219B or C emitters in place of the 3535 no-name LEDs it came with.
Guessing mine doesn't have Crees, but a at $20.01, I just wanted the bones.
Just wanted to say that I am one of the members who originally bought one of these UF SRK style lights some time ago & rated it highly for the price.
In fact myself & Teacher got a 4 led version each & were very impressed with them.
In the last couple of days Teacher has got a 9 led version & I have a 7 led version on it”s way which should arrive this coming week.
Teacher has confirmed that his new 9 led version is not the same quality as his original 4 led version.
Thinner rougher threads, not the same chunky raised positive contact ring.
He has not stripped it yet but I expect the shelf has gone as well :frowning:
I expect my 7 led version to be the same.
It seems that UF has reduced the quality of the components/build in these lights.
Wut? $20? Where did you get it for that price? That's a great price for this light. at DX, they are close to double that.
Thanks for the info! This is interesting. I thought this light caught on with a small group, just couldn't find the posts/threads. If you have or find any photos of the earlier or later versions, please post in this thread.
So sounds like so far:
  • they downgraded the model/design by removing the shelf, thinned the contact plate, poorer thread design, though I thought my unit has pretty good quality threads, as shown in the OP picture
  • LED's can be anything, whether it bares the UltraFire name or not, but mine bought from UltraFire.com is listed as CREE LED's and does appear to be CREE LED's
Isn’t a big issue that there is “Ultrafire” the brand that makes not too bad flashlights and the name just being slapped on anything thus can be any quality, usually poor?
The use/abuse of the UltraFire name has been going on a long time. Couple years ago UltraFire tried some legal action, maybe a notice sent out to retailers to stop selling UltraFire clones. Banggood did the right thing and pulled all their UltraFire branded items, but many either ignored it or didnt' receive it.
The UltraFire site used to have a posting about the problem, but I can't find it anymore.
http://www.ultrafire.net/index.asp
Dated, maybe last updated 2013. Products seem old, no pricing, descriptions or ordering. They seem to be called: Wha Fat Technological Co., Ltd.
http://www.ultrafire.com/
Much more current, has pricing, descriptions and accepts orders - this is where I ordered my 6X from. Still has broken links, links that don't takes you where you expect, but they do respond to service/ordering messages. Patents are list on "Contact us" page.
The sites list different addresses, different numbers, etc. Seem totally unrelated, but who knows.
I got it at that price during the 3/29 Ali sale. The have several SRK variants and some other lights I haven't seen show up here on BLF yet. Right now the lowest price one of the types you discuss in the OP they have is the 8-emitter version for $21.74 (after $1 for $15 purchase coupon):
https://www.aliexpress.com/store/product/Supwildfire-20000LM-8-x-XM-L-T6-LED-Power-Mode-Digital-Display-Flashlight/2787097_32799143787.html?spm=2114.12010612.0.0.QVBioJ
EDIT: It might be $20.74 because I think they have some auto discounts that show up when you check out ($1 for $15, $7 for $100, etc).
Any idea what size the connection is for that charge port?
It’s nice that the charge port connects directly to BAT+ / BAT-, because then you can use whatever charger you like. It may be odd for a flashlight, but that’s how these things are done in the swordlight industry:
5.5×2.1mm?
I've got a dozen or so different "real" ultrafire lights and they are usually a big step up in quality over the fakes.
Bummer this light didn't come with a real pill. It seems most of them don't anymore. Lately I've been putting in a copper pill for them not threaded or anything just put in place with thermal epoxy. I buy the blanks from metals direct then just polish them with a circular sander until they are nice a smooth for the noctigons. I've got extra blanks around from last time I bought them, they are a little bigger though, and might not work for you. If you think they will work and want one let me know. Just pay shipping and I'll send one out. I've still got a copper threaded pill that Bucket gave me and these work just as well as far as I can tell. Either one will transfer heat to the light so fast that it will burn your hands pretty quick on turbo.
This 9x has a copper pill made from a direct metals' blank, it's got a BLF driver in it. With high amp LG's you can't hold on to if for long on turbo.
