Battery ?
Those are some nice oneā€™s Barkuti mentioned above. :+1:
If you donā€™t want to wait for shipping from China you can pick up the Xtar HERE or HERE ā€¦. in the USA.
I have several and this Xtar works just fine.
HKJ reviewed it hereā€¦. Test/Review of Xtar USB current/voltage detector
Yeah, you could do that; but you would have to have some adapters to use the USB Tester that way.
:slight_smile:
Out of the USB tester that you have and used are they accurate and staying accurate over time? Which one is your favorite (your opinion) and why? I like to get people opinion, pro and cons, its help me decide.
I have a USB charger for my phone and it say 5v 1.2 or 12 amp canā€™t see and I took a picture on a iphone and blew it up the picture still canā€™t tell. I called the phone manufacturer, they said 5v 2.1a , they must of print it backward on the USB charger.
@Venomā€¦ā€¦ Not a dimes worth of difference in the ones I have of the same class/type. I probably use the Xtar the most because it has a large display that is easy to read & covers the range I need it to. :wink:
Accuracy is good.
I just came back from Walmart in my city in my city and nothing. Iā€™m going to try the Walmart in the the next town over and see what they have over the weekend.
Did they sell out or were they mixed up when they said they had them?? :wink:
If at first you donā€™t succeedā€¦. try - try againā€¦ :slight_smile:
I think when I called the guy didnā€™t bother looking. When I went there today the guy told me they never carried that brand, they just had a off brand and the other guy probably thought that was it. I think I also saw a Anker one to.
Venom, with each trip, your expenses may raise a good deal. You could have bought some inexpensive good looking unit on the first attempt, and could have won the craps shoot for just a little more. ;-)
Honestly, I even take my time looking for a quick online review about that bottle of wine at the supermarket. LoL!
LOLā€¦ Iā€™m guilty of the same.
Just to follow up on this, it does not seem to want to deliver anywhere close to the advertized 2.4A to my Nexus 5X. More like 1.4A.
Maybe it can do it with some other deviceā€¦
@teacher I went to the other Walmart,they didnā€™t have them but there was a spot for them on the display. So I ask someone that work there and she said that they should be in on this or the next shipment.
While I was at Best Buy I pick up the Eneloop Power Pack. I ended up picking it up for about $24 for that kit.
Sounds good on both counts then Venom. :+1: ā€¦ Real good price on the Eneloop Pack too. :wink:
@ teacher Almost forgot the date on the date on the battery, is that the expiration date or is it manufacture date because it says 4/16?
If you have to set the charging amp on the charger for eneloop, What amp do you set it at?
The dates on the Eneloops are manufactured dates. If it came from the battery it will be in this format [ 16 04 ??? ] = (yearā€¦ monthā€¦ā€¦ some letters)
What charger are you talking about? If it is the one that came with the Pack, as far as I know it gives no choice. They shouldnā€™t need charging, they come chargedā€¦. but it wonā€™t hurt them if you do.
I usually charge my AAā€™s at least at 1A (1000ma) every now and again I might do 1.5A (1500ma)
AAAā€™s I usually do at 0.5A (500ma)
You will get 94 different opinions on this depending on who you ask. Those charge rates are well below the 1C threshold that Eneloope gives as MAX.
So far I have not ā€œkilled oneā€ (knock on woodā€¦. :wink: ā€¦ ) and I have them dating back to 2006. So I must be doing something right. :wink:
@teacher It was in the same format like you mention 16 04 I donā€™t have the battery with me right now but Iā€™ll double check when I grab them.
I was watching a YouTube video on the Xtar SV2 and the person put the battery in and it started charging at at 1 amp and he said that was to high and put it down to .25 amp AAA and .50 for AA. I was also watching a Lii500 video and got a little confused watching.
Happy late Easter!
@Venom ā€¦ Roger that Venom, the year comes first, then the month, & then some letters that are some kind or manufacturer code. :+1:
Like I told you, you can get as many answers as you ask people about how they charge their Eneloopsā€¦ or any other battery for that matter. What the guy on the video should have said to be accurateā€¦ā€¦ that 1000ma was to high for HIMā€¦ā€¦ not the batteries. :wink:
Thank you my friend, a belated Happy Easter to you also. :slight_smile:
@teacher Is a year after the manufacture date for a Eneloop someting/nothing?
If you have a 4 bay charger do you set it at 2 amp so you can get .50 in each bay? What does 1000ma mean? In post 116 you said 1C threshold what does that mean? :slight_smile:
Typically, a 4 bay charger will let you set charging current individually for each slot. So if you set it to 2A, itā€™ll be 2A for that slot.
1000 mA = 1A.
1C is charging current relative to battery capacity. For example, if you have a battery with 2400 mAh capacity, then charging it at 1C means charging it at 2.4A. And charging it at 0.5C would mean 1.2A.
@ Venom ā€¦. What Pete said above. :slight_smile:
You been slacking on your homework?? :wink: We covered C-rate back in post #6ā€¦
:smiley:
Thanks for the reply!
I read it, I just donā€™t remember it. There is alot of reading in all of those links you posted. My brain was full and started emptying things out. :smiley:
