BLF style 18650 1s thrower( poor mans Olight M2X)
489 posts / 0 new
Mitko
Mitko's picture
Last seen: 7 min 28 sec ago
I usualy dont review torches , dont have much time for that.
Most of nowadays offers arent that BLF styled, also arent that BLF priced, yet this one is:
I bought the body several weeks ago from AE, however the seller stopped it for unknow reasons. Yet, my check showed one could find it easy on Ebay : 14-18$ price range
And i am sure it will pop at AE again
By default it aint something specialy, the body is solid, the pill too, the driver is a cheap 17mm EAST 92 DD driver 5 modes( 2.2 amps), yet the reflector is good!
The reflector( 52mm diameter) comes kinda short by default so they used a huge centering emitter bracket, thus resulted in a nasty hotspot with a terrible candela results.
The glass however is nice enough for that rice
The pill can hold 16mm pcbs so i lowered it by 3mm, filled the gap with a thermal paste/ Cu pads and used a 26mm 3535 mcpcb, also a X6 emitter bracket which paired nearly perfectly with the reflector
Since a frend demanded a Hi emitter 6500k+ i used a crappy V2 1A and a fet dd driver( with a modified babka thrower firmware)
The result is 1500 lumens( at 5.4 amps), 170k candelas and quite good heat dissipation: i am quite sure that if i used a dded U4 the candelas will top 200k+ even with the default glass, prolly 220k+ with a V6 emitter…and mayve 280 – 300K with a good S4 emitter
The hotspot:
Same quality as a very well fixed C8 hotspot without any rings ,“mustages” or something fo that ilk.
The tail assebly needs a modest rework too
Its lenght is only 8-9mm longer than Convoy C8, and its weight is 223 grams( without the battery)
I might say this one filled the 50-55mm reflector gap that we have atm, its cheap by default and the mod is a fairly easy one
bikenber73
bikenber73's picture
Last seen: 5 hours 7 min ago
Looks like a HD 2010 – C8 hybrid !
Nice Mod!
EasyB
Last seen: 2 days 36 min ago
Looks good, thanks for the report. Could you get another picture of it in hand or next to a C8?
Edit: there’s a pic in-hand in the AE link above.
Mitko
Mitko's picture
Here you are m8
giorgoskok
giorgoskok's picture
Last seen: 21 hours 31 min ago
I was looking at the same host some days ago , and i wasn’t sure if it has a hollow pill etc (and now you told us Wink , so i’ll probably get one) .
With a dded xp-l v6 i think you would get 240-250kcd easily . The UT02 that has a 50-52mm reflector gives even 250-255kcd with dded xp-l v6 .
Thanks , i always appreciate your mods .
Mitko
Mitko's picture
Yeah its a very good host to mod indeed, especialy considering its price vs quality ratio
And its a pure BLF torch:)
Something that i forgot to add early: its pill it an exact T20/UF1505 match whitch makes it very easy to mod even with a CU pill, yet i dont think thats needed, there is only a slight candela drop after 2min due to the heat, the body takes it very well realy
Also, the tail button is the bulky Otmen, and could be easy FW modded too: very good at default, its just one has to remove the useless tail spring cap( or solder it)
ARsee
ARsee's picture
Last seen: 1 week 6 days ago
Thanks Mitko
I just picked one up off eBay.
Who knows, it may become my first mod candidate
Anthon
Last seen: 27 min 6 sec ago
Bought one too!!
Thanks
gastonpatagonico
Last seen: 2 weeks 4 days ago
Thanks Mitko is a good info. Does an XP-G2 S4 3D dedomed? I have one and a blf a6 driver out there …
blueb8llz
Last seen: 10 hours 18 min ago
how does it perform stock. anyone got stock numbers?
Geuzzz
Geuzzz's picture
Last seen: 5 min 12 sec ago
Mitko
Mitko's picture
Its good that they brought it back- for 12$ its maybe the best DIY BLF thrower atm
It aint good by default yet the default emitter is original and the driver could be tiny 13 modded
djozz
djozz's picture
Last seen: 10 min 56 sec ago
Thanks for the tip Mitko, I just bought one on AE, $13.80 now. Let’s see what I can mod it with Smile
Geuzzz
Geuzzz's picture
Maybe I’ll go real budget and dedome the stock Led, how is the stock star?
Sledgestone
Last seen: 1 hour 22 min ago
Mitko, you have PM.
Mitko
Mitko's picture
Thats the idea m8, i used HI emitter cause i was forced too, dded XML would be ways better for candelas, even for the tint: its kinda cool white by default so it would end u like 4500k or something.
I am sure youll hit 200k cds easy, even if you attiny13 mod the default driver, its EAST92
One thing thats quite important: since the reflector has quite a wide base the emitter MCPCB should be at least 26+ mm
Olight m22 mcpcbc work perfectly in that host btw, and i have like 20 of those laying arround( leftovers form modded m22s Smile
giorgoskok
26mm mcpcb for xm-l2 isn’t that expensive (compared to the xp-l one) : http://www.banggood.com/MAXTOCH-Copper-Star-Board-With-Direct-Thermal-26...
ARsee
ARsee's picture
Geuzzz wrote:
https://www.aliexpress.com/item/High-Quality-SupwildFire-CREE-XM-L2-U3-L... Available again at 11 dollars.
I hate when I buy something and right after I find it cheaper undecided LOL!!!
Geuzzz
Geuzzz's picture
Thanks for the ideas. Ordered that mcpcb. Looking foreward for this oldschool budget build. Beer
cmflippen
cmflippen's picture
Last seen: 3 weeks 4 days ago
Thanks, Mitko! Just ordered one.
Now I need to decide whether to install an XP-E2 or 219c. (Both dedomed, of course)
Mitko
Mitko's picture
XPG m8, e2s are too weak, 219c cant be dedomed properly
For most XML woild look great overall , especialy considering the lumen/candela ratio
MRsDNF
MRsDNF's picture
Last seen: 5 hours 53 min ago
Is the reflector base broad at the led opening like the HD2010 which caused no end of shorts?
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
Mitko
Mitko's picture
Yes, thats why i suggested a mcpcb at least 26mm, otherwise the reflector quality is quite decent, as good as a Convoy C8
P.S
ordered another one and i saw the guy bumped the price
giorgoskok
HD2010 is the 26650 version of this light ? I mean same reflector size and not so pricey in general .
Mitko
Mitko's picture
Yeah m8 but i dont like it, especialy now when L2 came to being…plus Y3 is better.
Actualy, the right thing to say here is that this one is the 18650 version of the HD2010 Big Smile
For the price we can get it, its a great offer, there is nothing else in that price/reflector diamether range: i mean nothign else that good , or even modding worthy
There are others yet they are a total crap unfortunately…or at least i havent tested anything decent
giorgoskok
Can you still buy Y3’s for a decent price ?
MRsDNF
MRsDNF's picture
Thanks Mitko.
Boaz
Boaz's picture
Last seen: 11 hours 30 min ago
I love it ….the price keeps going up .
oh the madness of it all…
US $14.65
zeremefico
zeremefico's picture
Last seen: 1 day 3 hours ago
Ordered one 3 days ago but seller hasn’t shipped it yet.
The demand was higher than stock I believe, Mitko blew sales:-)
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
Tom E
Tom E's picture
Last seen: 3 days 21 hours ago
Just ordered. Nice find Mitko! I still got a few Y3's - don't know where to buy one though. The last batch of Y3's I bought from GearBest was a disaster - beat up, scratched up - worse condition of a light I ever saw, packing was awful. The Y3's finish is clearly true low budget. If heavily used, they come back to me in a pretty scratched and worn off state. When you could get them for a good price, was still worth it but I don't think I'll buy anymore unless the quality can be improved.
FastTech has them here for $33: https://www.fasttech.com/products/1601/10011236/4183401, but a good price on them was $25-$28. GB has them at $23 list, out of stock for a long time now.
Mitko
Mitko's picture
Aaah damn, t seems that FT rised up the price, the last time i ordered Y3 from FT it was like…25$? 33…a bit high i presume
Quote:
Ordered one 3 days ago but seller hasn’t shipped it yet. The demand was higher than stock I believe, Mitko blew sales:-)
Actualy the seller seems to be a bit jealous and kinda strange too Smile
I asked him about a wholesale price of 10 and the answer was( copy/pasted):
“ Hello Dear, i offer 18.81$ per latherna , good for you, good! You pay aditional 80$ US dollars for DHL , okay? Great for you
And ofc he maybe joking, but i have never seen a chinece person joking so far….
If he plans of 20$ for a torch…well, i will pass….14.5 is still a good price for it
