I know it is pretty hard to come by, but I would be interested in seeing these batteries tested:
Powerex Pro 2700 (these are new) and I believe are just Panasonic 2700 (2550mAh min)
I don’t blame you for being suspicious, but there are multiple reports in the other thread I linked of capacity around 1130mAh, and internal resistance as low as the best available 18350 cells.
I have both the AW and the KP 18350. So far they are rated in the Top 3 by mooch.
Top Three Performers
AWT Yellow 10.5A 800mAh
Keeppower 8A 750mAh
AW Red 12A 800mAh (button top)
Most of my lights and My 2 X 18350 lights are modded. High current is more important to me that additional run time.I just pop a fresh cell in when necessary!
I had seen some good feedback on their Ni-MH offerings; maybe they're cooperating with some good chinese battery oem, in which case these could have a well-earned place in the market.
45mΩ? If that instrument is roughly accurate, those cells should at least handle up to 10A continuous.
We'll see if they earn a record low in price/quality, superb value that is.
Hey HKJ how are you! I’m curious about two Imalent protected batteries, primarily the 18650 which should be based on the Samsung 30Q. There are not many high drain protected batteries available, so I wonder whether Imalent is providing the DT35 and the DT70 lights with a good set of protected batteries; it increases the value a lot.
