Any recommendations for camp lantern
Apply the dc fix to the lens.
I’m surprised that nobody has yet to mention warm white color temps, around 2700-3000K (one mention of neutral white). I find warm white to be an absolute must for a camp lantern, it is so pleasant and soothing. Even neutral white looks cold and glaring at night, especially with a fire nearby giving off that beautiful warm glow.
I know we all like flashlights, but if you expand that to LEDs in general, warm white LED rope string lights are a great way to light a campsite. They have the advantage of being able to light the area with diffuse light, and without the bright point that will glare you when you accidentally look straight at the Lantern eventually.
But this just diffuses the beam and doesn’t turn it into a latern.
the proprietary battery kills all interest on that one.
i run stuff like that on free laptop pulls.
and if goal zero folds you are stuck.or they drop the line and you cant buy a replacement anywhere.
The Fenix CL25R comes with a protected 18650, and you can get 20% off at fenixlighting.com using the code “newmember20” ($48). The Fenix has NW emitters. The clones are cool blue.
I second using a diffuser.
I like these silicone diffusers at banggood. They are 1.99, fit on convoy s2 perfectly, pack down, weigh almost nothing. I string up a ridge line right over camp and hang my convoy right off it. It lights up camp nicely.
Hi, can I know what lumens you run it on? Also would the diffuser fits the BLF A6?
I use a medium mode mostly, maybe 300 lumens. Ive also left it on very low moonlight all night. Once your eyes have adjusted its actually a very usable nightlight.
They will fit the blf a6 great. They are a stretchy silicon, so they can accommodate pretty much any 18650 tube light.
These?
http://www.banggood.com/LED-Flashlight-Silicon-Rubber-Light-Cover-Diffusers-20-24mm-p-86721.html
Yes, those ones. I must have messed up the link. I’ll edit it. Thanks
Thanks! Much appreciated.
Been looking around for a budget camp lantern that’ll last the whole night. Don’t think it’s possible without burning a hole in the wallet.
The A6 might just be the ticket.
I have one similar to this:
https://www.amazon.com/dp/B00XC5T0RE/ref=cm_sw_r_cp_awdb_n7h9ybVX4S9GX
and one of these I bought for my daughter for camping:
https://www.amazon.com/dp/B00YDQJ18E/ref=cm_sw_r_cp_awdb_h.h9ybPQSQ6ZP
Both of them work great.
The Streamlight Siege I posted above is rated at 37 hours on low (50 lm), which stiill gives very usable output.
Hi Pete, thanks for the recommendation, but I’m in the other part of the world. Shipping’s gonna be a killer ordering from Amazon. Also would prefer to run it on 18650 if possible.
Got it.
Fyi, i was using a DQG Tiny 18650 with a diffuser cap as a night light last night. The 3.5lm output is very usable and should last hundreds of hours on a single 18650.
I have several of these Energizer WeatherReady lanterns that I picked up in the clearance rack of Home Depot for less than $5. They come with 3 AA batteries, and by removing a carrier, will accept 3 D cells. I plan on playing with one of them to see if I can mod it to take 18650 cells. A quick look at it just now leads me to believe that there is room in the compartment length wise, so all that is needed is a revised carrier with the proper battery terminals.
It may not be aluminum or fancy, but I’m pretty sure that it will give you the run time you are looking for.
How about the Blitzwolf BW-LT5 PRO lantern?
The best camping lantern is Convoy s2+ (or any similar) with diffiser. Compact, durable, universal lamp.
Definitely another 1 on manithree’s suggestion for the diffuser flashlight, ideally in warm white as sac02 prefers. Boaz’s recommendation for the Skilhunt H03, or similar even flood beam (TIR, mule, cob, maybe even a zoomie or one of those USB power bank dimming led things…) kinda what I’m doing now til my package from Simon arrives, but it seems more finicky with setup—depending. Hard to beat the durability, packability, crush resistance, and water resistance of a flashlight milled out of aluminum vs a lantern with plastic shell. The flashlight market is more saturated and competitive than the lantern market too, so that weighs in our favor as well :slight_smile:
Previously for many years I used a AA tube light from Fenix and their diffuser (it will draw comments or at least bewildered looks when displayed in mixed company, no doubt…!), as I knew I already wanted a headlamp for—well everything, a flashlight to spot ahead, and a lantern in camp for cooking and ambiance without blinding others if present (and hey, let’s be real, you got at least one flashlight on you when out, I’m sure :wink: put the weight savings to backup battery or another form of redundancy, luxury, or just save the space and weight which is a luxury in itself!). Definitely more a sedentary arrangement, but shining a light through the cap and into the water bottle for light dispersal works nice. Ugly but utilitarian is puffing out a white or yellow shopping bag, and shining the light into it; bonus for being very lightweight, multipurpose, likely already at hand, and has its own handles to hang from branches/carabiners. I haven’t tried it yet, but another lightweight flexible option I’ve been meaning to test, is semi inflating a white balloon into a rudimentary “bulb” shape, and slapping it over the end of a tube light; think I saw that on BLF or possibly a backpacking forum, but I can’t remember who to credit.
Got a Convoy C8 in 7A tint with new firmware I’ve been meaning to find a diffuser for, preferably like that one linked above by electricjelly, I imagine silicone would pack better than even the hard plastic. I prefer a multi selection of low modes primarily, but if I ever do bump up the lumens, at least the larger form factor will help disipate heat better. For my current uses the diffuser + flashlight form works well, and now my next point of concern with it are more things like: Multi modes to suit the situation, a comfortable non glaring tint, the runtime to keep up, and LVP shutoff.
I am biased towards flashlights, as the majority I’ve purchased have a more industrial, utilitarian feel, whereas the majority of lanterns I own or used feel more like something made to set on a covered porch or give to a kid for summer camp. That said, there are some nice ones to be sure, I have a Brunton with infinitely variable brightness and a nice tint that packs down nice, Coleman packaway design is ok too if you can spray some glass frosting on it and deal with poor tint; and I’ve been eyeing that Fenix and it’s clones, as well as the Blitzwolf… While I tend to avoid them when packability is prioritized or traveling by foot, I also have a strong nostalgic streak for lanterns that I’ve been trying to curb, but often draws me back now and then ha! Fortunately for me, my mom loves lanterns for “power outages” (they don’t happen often as a flashaholic is prepared for :stuck_out_tongue: hehe), and since she never actually uses them I sort of arrange the lesser ones around the house for her; if misplaced she’ll order another, but you know how it is when you see friends and family buying just any random light :person_facepalming: .
Something of an inbetween flashlight/lantern, that I would like to see more along the same or similar lines of, is the ThorFire KL02. Very cute little keychain lantern thing and for me I can see this as having use in camp. I would have prefered it was 18650 instead of 16340, had a spring instead of foam donut, removable diffuser, and tint options—basically I want an 18650 mule tube light with packaged with duffuser xD. For what it is tho, it’s nice and very inexpensive; would still keep the 16340 and add 18650 to product line, not drop one for other. Not perfect, but I liked them enough to buy a handful as gifts for outdoors buddies.
Wishing you luck, whatever you end up with, and many adventures ahead! :beer:
Sorry about the wall of text, I tend to take something and run with it once started :person_facepalming: Links are usually more satisfying “read” :partying_face:
USB led with touch dimmer, pure flood, fragile when combined with power-bank, but unique and talk about space savings/redundancy!
https://smile.amazon.com/dp/B00PU7NQ2M/ref=wl_it_dp_o_pC_nS_ttl?\_encoding=UTF8&colid=21SFVQOCNL8OH&coliid=I13DZ7J31TDS4D
ThorFire KL02, 16340 keychain sized “lantern”
https://smile.amazon.com/ThorFire-Keychain-Flashlight-Battery-Include/dp/B0185J0958/ref=sr_1_1?ie=UTF8&qid=1492549399&sr=8-1&keywords=thorfire+kl02
18650/3xAAA led bulb: didn’t mention because feels cheaply made but I have to admit I do like it for a gag piece ha
https://smile.amazon.com/dp/B01H4WPA06/ref=wl_it_dp_o_pC_nS_ttl?\_encoding=UTF8&colid=21SFVQOCNL8OH&coliid=I1CUDNM4XTM90B&psc=1
Another take on a universal diffuser
https://smile.amazon.com/dp/B007UTYC8A/ref=wl_it_dp_o_pC_nS_ttl?\_encoding=UTF8&colid=21SFVQOCNL8OH&coliid=I1Z1M5RFH9M442
Coleman Max Packaway lantern, mentioned above, but rather Fenix or clone
https://smile.amazon.com/Coleman-Pack-Away-LED-Lantern-Mini/dp/B00U4FP0GA/ref=sr_1_3?ie=UTF8&qid=1492549556&sr=8-3&keywords=coleman+max+lantern
Black Diamond Apollo, my mistake about the Brunton in above post, got mixed up
https://smile.amazon.com/Black-Diamond-Apollo-Lantern-Process/dp/B00RKUINNY/ref=sr_1_4?ie=UTF8&qid=1492549473&sr=8-4&keywords=black%2Bdiamond%2Blantern&th=1
