NEW ThorFire TG06S review
22 posts / 0 new
Jerommel
Jerommel's picture
Last seen: 1 week 6 days ago
ThorFire asked me if i could do a review on their new AA/14500 light, the upgraded TG06: the TG06S
I said yes. Smile
So they sent me the light, and asked me if i could also post this Amazon link:
https://www.amazon.com/gp/product/B06XQ4TY45
Here it is:
Comes in a simple cardboard box with spare O-rings and a user manual.
Pocket clip was already in place, the clip can be reversed too.
Glasses
The output end:
The smooth reflector is as large as possible, and looks like it will throw pretty well for this flashlight size.
The LED is a cool white XP-G2.
The light can tail-stand.
Tube, head and tail:
Brass retaining rings in the head and tail
All seems to be nicely machined and assembled.
Anodized tail treads.
Proper tailcap assembly, with a switch on PCB.
17mm diameter driver PCB
Brass pill with an approximately 1mm thick shelf
Aluminium 16mm diameter LED board.
Glass lens without coating.
Still in the head (forgot to take it out for the picture) is a green glow in the dark O-ring.
Group photo with some competitors:
It’s not really small for a straight tube style design.
This is due to the tailswitch and the relatively large reflector.
But it’s also rugged because of the slightly wider overall diameter.
This is also reflected in the weight of the light (without battery):
ThorFire TG06S weighs 44.5 grams
Utorch UT01 weighs 35.9 grams (without its horrible clip and with TIR optics)
Jetbeam JET-1 MK weighs 26.5 grams
Klarus MI7 weighs 26.4 grams (also no clip, it came without one)
Here are the specs from the manual:
Seems legit, and yes, it’s pretty bright.
Similar output claims as above mentioned competitors.
Four modes, always starts in high mode: HIGHMEDIUMLOWMOON.
Double tap for strobe.
Unfortunately driver uses PWM for medium, low and moon on AA batteries (Alkaline or NiMH)
To my surprise it uses PWM on all modes with a 14500 (Li-Ion).
Unfortunately it is visible too…
The PWM frequency seems to be around 400 Hz
The picture above shows moon mode on a 14500.
Comparing it with the Klarus MI7 on a wall outside:
Lumen output is quite similar in high mode on 14500.
But, due to the larger smooth reflector the hotspot of this ThorFire TG06S is tighter and thus brighter.
Using way too much contrast the difference is obviously much clearer:
Resuming:
The ThorFire T06S is a well built rugged AA / 14500 light with a good amount of throw for its size and form factor.
The driver, although it provides the light with a high output, could have been better, like the Jetbeam driver for example.
2Q19
Edited by: Jerommel on 04/16/2017 - 20:34
power911
power911's picture
Last seen: 18 hours 4 min ago
Now I’m curious on what improvement made compared to previous batch
“Have you forgotten about all those who called you a Bringer of Woe and hunted you like an animal?”
“Normal humans don’t go around killing people and burning towns!”
“Don’t worry. I’ll go with you! So you just follow me and no arguing, okay?”
“Humans m
Jerommel
Jerommel's picture
Improvements are in the driver: increased output plus a moon mode.
2Q19
djozz
djozz's picture
Last seen: 1 hour 4 min ago
I thought that I read somewhere that they increased the pwm frequency, but apparently that was another light.
Thanks for the review Jerommel. They will let me do a review in the TG06S too (light has not arrived yet), I’m going to think about what I can add to your review, perhaps a runtime graph if someone else does not beat me to that (it seems we will get some more reviews on the TG06 soon).
Nicolicous
Nicolicous's picture
Last seen: 4 hours 30 min ago
Utorch 01 is still the king in AA battery configuration Smile
Nico -.-
Dirt
Last seen: 2 weeks 1 day ago
Good straightforward review, J. I’m not sensitive to pwm, so I’ll be lookin for a sale on this light.
kramer5150
kramer5150's picture
Nice review thanks!! If you have a multimeter you can use the AC-Hz setting to get a good measurement of the PWM frequency. It reads the DC PWM pulses like an AC square wave and will display the frequency.
Sorry thorfire, that low frequency PWM is a deal breaker for me.
maukka
maukka's picture
Last seen: 1 hour 36 min ago
If you have a good multimeter and a spare LED (6-12 volt one like an XHP70 or XHP35 recommended) you can measure the PWM optically too. Just shine the light on the emitter. This doesn’t work on all cheap handheld DMMs though, especially the low moonlight modes cause problems.
I just got the Thorfire TK4A for review. It has PWM too but at 20.9 kHz, it’s not visible to the naked eye.
Jerommel
Jerommel's picture
Yes Maukka, i was thinkig to hook up a small solar cell on my computer audio input and have a look at the wave, but i didn’t get to it.
Kramer, i have 2 DMMs, but neither of them have a frequency counter..
And yes, the low frequency PWM would be a deal breaker for me too…
I.m.h.o. ThorFire should have ‘a good analytical look’ at the Jetbeam driver for ‘inspiration’. (didn’t want to say “copy” Silly )
2Q19
Jerommel
Jerommel's picture
Wow:
https://www.aliexpress.com/store/product/ThorFire-TG06S-Aluminum-alloy-T...LED-Flashlight-14500-AA-Torch-Light-for-camping/1925442_32792406601.html
That’s cheap!
2Q19
kramer5150
You mention this…
“Unfortunately driver uses PWM for medium, low and moon on AA batteries (Alkaline or NiMH)
To my surprise it uses PWM on all modes with a 14500 (Li-Ion).”
By that you mean ALL modes show PWM with a 14500?… including the highest/brightest one?
thanks
Jensen567
Last seen: 1 week 3 days ago
The PWM is what kept me away from this light. I really wanted an AA/14500 clicky light for EDC so that I can have the brightness of Lithium but the ability to use standard AA cells in a pinch. Unfortunately I work around a lot of moving equipment so low frequency PWM is a big no for me.
SoCalTiger
SoCalTiger's picture
kramer5150 wrote:
You mention this…
thanks
Yes, PWM in ALL modes with a 14500.
With NiMH, only PWM in Med & Low.
SoCalTiger
Jerommel wrote:
Wow: https://www.aliexpress.com/store/product/ThorFire-TG06S-Aluminum-alloy-T...LED-Flashlight-14500-AA-Torch-Light-for-camping/1925442_32792406601.html That’s cheap!
Nice find. This light is a steal for sure at that price IMO.
korpzgrinda
korpzgrinda's picture
Last seen: 2 hours 45 min ago
Location: Eastern Woodlands in the Wilderness of North America
Yes, thank you for posting this. I made an order on AE. TG06 is a solid AA/14500 flashlight, so the “S” version is a must-try. It’s a shame about the PWM.
kramer5150
SoCalTiger wrote:
kramer5150 wrote:
You mention this…
thanks
OK big time deal breaker for me then. Its not like this is the only AA 14500 light out there. There are many that do not use visible PWM.
Nice review!! thanks
digitaltc
Last seen: 1 year 2 weeks ago
Not sure if anyone cares but it’s on sale at Amazon for $11 and some changes (35% off normal price $16.99). I just got one.
Sigster
Last seen: 2 weeks 4 days ago
d_t_a
Last seen: 4 min 15 sec ago
Pardon my question, how do I use the AC-Hz setting of the DMM to measure PWM frequency of the flashlight?
Is it the same procedure as measuring the tailcap current (set to DC ampere setting), but instead set to the AC current/Hz setting?
I tried doing it (ie. like I was measuring the tailcap current, except with DMM set to “AC current/Hz” setting), but it displays 0.00 Hz only — maybe I’m doing something wrong here?
buck91
buck91's picture
Last seen: 1 day 14 hours ago
Picked this up last month and taking it camping over the next week or so. Love this review. Plus it looks very easy to mod and at this price point is a fine host. Might have to find one to swap for a 219c or xpl hi 90cri along with a better driver. I don’t find the pwm noticible durong biking or dog walking but I don’t care for the mode layout. Would prefer l-h or m-l-h layout. Especially with the reverse clicks.
ask
Last seen: 1 month 1 week ago
Could you tell diameter of front glass and green o-ring? I guess black o-ring is better (green o-ring spoils colors of light).
ask
I’d got 219B 5700K, and it’s very pleasant color, but I guess green ring gives bad color tint. Now I wait another driver (Convoy 1400mA) for replace. Bad for AA NiMH Sad but no PWM.
I bought cheapest version here: http://ali.pub/3cbiah – there is aluminuim pill, spacer between switch and tailcap made of aliminium, and different nuts (in head and in tail), no thermopaste. It’s little unconvenient for dissamble. I was planning to upgrade this flashlight, so I think it’s good option.
