Battery ?
Just to follow up on this, it does not seem to want to deliver anywhere close to the advertized 2.4A to my Nexus 5X. More like 1.4A.
Maybe it can do it with some other device…
@teacher I went to the other Walmart,they didn’t have them but there was a spot for them on the display. So I ask someone that work there and she said that they should be in on this or the next shipment.
While I was at Best Buy I pick up the Eneloop Power Pack. I ended up picking it up for about $24 for that kit.
Sounds good on both counts then Venom. :+1: … Real good price on the Eneloop Pack too. :wink:
@ teacher Almost forgot the date on the date on the battery, is that the expiration date or is it manufacture date because it says 4/16?
If you have to set the charging amp on the charger for eneloop, What amp do you set it at?
The dates on the Eneloops are manufactured dates. If it came from the battery it will be in this format [ 16 04 ??? ] = (year… month…… some letters)
What charger are you talking about? If it is the one that came with the Pack, as far as I know it gives no choice. They shouldn’t need charging, they come charged…. but it won’t hurt them if you do.
I usually charge my AA’s at least at 1A (1000ma) every now and again I might do 1.5A (1500ma)
AAA’s I usually do at 0.5A (500ma)
You will get 94 different opinions on this depending on who you ask. Those charge rates are well below the 1C threshold that Eneloope gives as MAX.
So far I have not “killed one” (knock on wood…. :wink: … ) and I have them dating back to 2006. So I must be doing something right. :wink:
@teacher It was in the same format like you mention 16 04 I don’t have the battery with me right now but I’ll double check when I grab them.
I was watching a YouTube video on the Xtar SV2 and the person put the battery in and it started charging at at 1 amp and he said that was to high and put it down to .25 amp AAA and .50 for AA. I was also watching a Lii500 video and got a little confused watching.
Happy late Easter!
@Venom … Roger that Venom, the year comes first, then the month, & then some letters that are some kind or manufacturer code. :+1:
Like I told you, you can get as many answers as you ask people about how they charge their Eneloops… or any other battery for that matter. What the guy on the video should have said to be accurate…… that 1000ma was to high for HIM…… not the batteries. :wink:
Thank you my friend, a belated Happy Easter to you also. :slight_smile:
@teacher Is a year after the manufacture date for a Eneloop someting/nothing?
If you have a 4 bay charger do you set it at 2 amp so you can get .50 in each bay? What does 1000ma mean? In post 116 you said 1C threshold what does that mean? :slight_smile:
Typically, a 4 bay charger will let you set charging current individually for each slot. So if you set it to 2A, it’ll be 2A for that slot.
1000 mA = 1A.
1C is charging current relative to battery capacity. For example, if you have a battery with 2400 mAh capacity, then charging it at 1C means charging it at 2.4A. And charging it at 0.5C would mean 1.2A.
@ Venom …. What Pete said above. :slight_smile:
You been slacking on your homework?? :wink: We covered C-rate back in post #6
:smiley:
Thanks for the reply!
I read it, I just don’t remember it. There is alot of reading in all of those links you posted. My brain was full and started emptying things out. :smiley:
@ Venom … I understand. :wink: … I was just messing with ya’. :smiley:
I know! All fun and games. j/k
With cc17 charger can you charge 2 AA and 2 AAA at the same time or do you have to charge all AAA/ AA at the same time? Can you recharge them anywhere in the house like kitchen or do you have to go somewhere more suited? Do you have to keep putting your hand on them while charging to check for heat? My guess they should stay cooler than my Milwaukee M18 battery pack. When the Eneloop come freshly off the charger are they 1.2v or are they higher? I read online people are taking them off the charger at 1.4/1.5v, not sure what are the max charging volts to be safe.
On the battery it says AA BK-3MCCA 1900 Mah HR6 and AAA BK-4MCCA 750Mah HR03. I can’t read the imprint on the battery. My sister read the date 16 04 but not sure if it right
@Venom …………… Just put the batteries in, plug the charger in , and it does the rest. When that charger quits charging they are done.
Copy of a CC17 Manual below.
Oh yeah, when they are fully charged they will be above 1.2V
Thank you for purchasing the Panasonic BQ-CC17 Charger
This manual contains important safety and operating instructions for the Panasonic
BQ-CC17 Battery Charger.
Before using, please read all of the instructions and warnings on (1) the battery
charger; (2) the batteries; and (3) the product using the batteries.
  1. To reduce the risk of injury, we recommend that
    Panasonic Ni-MH rechargeable batteries are used.
  2. Do not use non rechargeable batteries.
  3. Do not use the charger in humid conditions.
  4. Do not use the charger if it has a damaged plug.
  5. Do not use the charger after it has been dropped or damaged.
  6. Do not open/disassemble the charger.
  7. Unplug the charger before maintenance or cleaning.
  8. Do not use the charger in direct sunlight.
    This appliance can be used by children aged from 8
    years and above and persons with reduced physical,
    sensory or mental capabilities or lack of experience
    and knowledge if they have been given supervision
    or instruction concerning use of the appliance in a
    safe way and understand the hazards involved.
    Children should not play with the appliance.
    Cleaning and user maintenance should not be made
    by children without supervision.
    OPERATING INSTRUCTIONS
    In this charger 4 AA and/or 4 AAA batteries can be charged in several combinations
    (see fig. 4)
  1. Observe polarity by matching (+) and () on the batteries to (+) and () on the
    charger.
    For AA battery, insert from the (+) terminal and push on the (-) terminal. (fig 2)
    For AAA battery, insert from (-) terminal, then place () terminal into () contact
    place. (fig 3)
  2. Plug charger into standard 100–240 V AC outlet;
  3. Charging indicator light will be lit after blinking fast several times, indicating that
    charging is being conducted.
    If indicator light does not come on:
  4. a) Make sure batteries are inserted, making proper contact with terminals in
    each slot;
    4 ) b) Make sure charger is plugged into a working AC outlet.
  5. After charging fully the charging indicator light will turn off. The charger should
    then be unplugged from the AC outlet and the batteries removed.
    The auto-off feature will automatically shut off the charger when the batteries are
    completely charged.
    Charging times shown in Table 1 are only indicative and can vary depending on
    temperature and battery status.
    MAINTENANCE, CARE AND CLEANING
    ●Care and cleaning is essential.
    ●Unplug charger from AC outlet.
    ●If necessary clean with a dry cloth to remove dirt and grime.
    ●Never immerse the charger in water or in any other liquid.
    Table 1
    Battery
    Size Capacity Charging time
    1-4 pcs
    AA
    2400 – 2500 mAh 9.0 hour
    1900 – 2000 mAh 7.0 hour
    950 – 1000 mAh 3.5 hour
    AAA
    900 – 950 mAh 7.0 hour
    750 – 800 mAh 6.0 hour
    550 – 650 mAh 5.0 hour
    SPECIFICATIONS
    Model : BQ-CC17
    Input : AC 100–240 V / 50–60 Hz 0.2 A
    Output : DC 1.5 V —- 300 mA x 4 (AA size)
    DC 1.5 V —- 150 mA x 4 (AAA size)
    Operating temperature : 0~35℃ (Indoor use only)
    Warranty: The warranty starts from the moment of purchase.
    PECE will repair or replace with equivalent charger in case of justified
    complaint.
    The warranty is for the charger only.
    The warranty is only related to defects in materials and workmanship.
    Details can be obtained at Panasonic Energy Europe N.V. or at
    www.panasonic-batteries.com
@ teacher The battery info I posted in post 125, are they the Eneloop you said to purchase?
As long as they are Eneloops and made in Japan your good to go as far as I can tell. :+1:
That is the same Pack you had been talking about getting isn’t it??
If you go HERE & RIGHT HERE you can learn all you’ll ever want to know about Eneloops. :slight_smile:
Yes it’s the same pack I been talking about.
The first link I found it doing a Google search after I last posted. The second link I think it has some good info on Eneloops and it answer some of the question I had. One answer I couldn’t find if you can charge 2 AA and 2AAA at the same time in the cc17.
I think the next thing I’m going to get is Xtar SV2 first (easier to get) then Lii500 and more Eneloop. Can you test the accuracy of a DMM with the SV2 or do you need the Lii500? Do you know what’s a good battery storage case/container that keep the batteries seperated?
  • OK… same pack.
  • Questions about AA & AAA charging are on Page 1 of your instructions. … Fig. 4 …… look it up to remember it. :wink:
  • Not sure about the SV2.
  • All kinds of good storage options. Do a search…. if you can’t find something suitable let us know. :slight_smile:
For storage I was looking at ammo boxes but the AAA Eneloop will fit in the slots but when upside down there all over the place. What are some of your idea/opinion on storage box.
