@Venom ā¦ā¦ā¦ā¦ā¦ Just put the batteries in, plug the charger in , and it does the rest. When that charger quits charging they are done.
Copy of a CC17 Manual below.
Oh yeah, when they are fully charged they will be above 1.2V
Thank you for purchasing the Panasonic BQ-CC17 Charger
This manual contains important safety and operating instructions for the Panasonic
BQ-CC17 Battery Charger.
Before using, please read all of the instructions and warnings on (1) the battery
charger; (2) the batteries; and (3) the product using the batteries.
To reduce the risk of injury, we recommend that
Panasonic Ni-MH rechargeable batteries are used.
Do not use non rechargeable batteries.
Do not use the charger in humid conditions.
Do not use the charger if it has a damaged plug.
Do not use the charger after it has been dropped or damaged.
Do not open/disassemble the charger.
Unplug the charger before maintenance or cleaning.
Do not use the charger in direct sunlight.
This appliance can be used by children aged from 8
years and above and persons with reduced physical,
sensory or mental capabilities or lack of experience
and knowledge if they have been given supervision
or instruction concerning use of the appliance in a
safe way and understand the hazards involved.
Children should not play with the appliance.
Cleaning and user maintenance should not be made
by children without supervision.
OPERATING INSTRUCTIONS
In this charger 4 AA and/or 4 AAA batteries can be charged in several combinations
(see fig. 4)
Observe polarity by matching (+) and () on the batteries to (+) and () on the
charger.
For AA battery, insert from the (+) terminal and push on the (-) terminal. (fig 2)
For AAA battery, insert from (-) terminal, then place () terminal into () contact
place. (fig 3)
Plug charger into standard 100ā240 V AC outlet;
Charging indicator light will be lit after blinking fast several times, indicating that
charging is being conducted.
If indicator light does not come on:
a) Make sure batteries are inserted, making proper contact with terminals in
each slot;
4 ) b) Make sure charger is plugged into a working AC outlet.
After charging fully the charging indicator light will turn off. The charger should
then be unplugged from the AC outlet and the batteries removed.
The auto-off feature will automatically shut off the charger when the batteries are
completely charged.
Charging times shown in Table 1 are only indicative and can vary depending on
temperature and battery status.
MAINTENANCE, CARE AND CLEANING
āCare and cleaning is essential.
āUnplug charger from AC outlet.
āIf necessary clean with a dry cloth to remove dirt and grime.
āNever immerse the charger in water or in any other liquid.
Table 1
Battery
Size Capacity Charging time
1-4 pcs
AA
2400 ā 2500 mAh 9.0 hour
1900 ā 2000 mAh 7.0 hour
950 ā 1000 mAh 3.5 hour
AAA
900 ā 950 mAh 7.0 hour
750 ā 800 mAh 6.0 hour
550 ā 650 mAh 5.0 hour
SPECIFICATIONS
Model : BQ-CC17
Input : AC 100ā240 V / 50ā60 Hz 0.2 A
Output : DC 1.5 V ā- 300 mA x 4 (AA size)
DC 1.5 V ā- 150 mA x 4 (AAA size)
Operating temperature : 0~35ā (Indoor use only)
Warranty: The warranty starts from the moment of purchase.
PECE will repair or replace with equivalent charger in case of justified
complaint.
The warranty is for the charger only.
The warranty is only related to defects in materials and workmanship.
Details can be obtained at Panasonic Energy Europe N.V. or at www.panasonic-batteries.com
As long as they are Eneloops and made in Japan your good to go as far as I can tell. :+1:
That is the same Pack you had been talking about getting isnāt it??
If you go HERE & RIGHT HERE you can learn all youāll ever want to know about Eneloops.
The first link I found it doing a Google search after I last posted. The second link I think it has some good info on Eneloops and it answer some of the question I had. One answer I couldnāt find if you can charge 2 AA and 2AAA at the same time in the cc17.
I think the next thing Iām going to get is Xtar SV2 first (easier to get) then Lii500 and more Eneloop. Can you test the accuracy of a DMM with the SV2 or do you need the Lii500? Do you know whatās a good battery storage case/container that keep the batteries seperated?
For storage I was looking at ammo boxes but the AAA Eneloop will fit in the slots but when upside down there all over the place. What are some of your idea/opinion on storage box.
I forgot about the US GB Warehouseā¦. they never seem to have it when I want it.
@ Venom ā¦. Click on link in my sig line that says M4D M4X DEALS, get signed up& do as he asksā¦ā¦ keep it private. Get codes for good deals.
The place where I found it was on Amazon and after I read it again itās for EU plug.
I was going to ask about Gearbest in the U.S. if it was the same company. I once order a packagr from outside the U.S. and they said it got delivered and it never did so I got beat on that deal so when it comes to ordering outside the U.S. I sometimes have second thought on it.
Gearbest only has one website, but they have multiple warehouses. If a product is available at their US warehouse, itāll show you that on each product page when you click on the Shipping Cost / shipping options link. They only offer a limited number of some of the most popular items in that warehouse.
This question was asked the other day about the accuracy of the Innova 3320 DMM.
Well I though some of you might find the following interesting.
A BLF friend from the United Kingdom sent me a brand spanking new VC99 DMM and a VRM (Voltage Reference Module). So I decided to test it all out as well as the accuracy of my Innova 3320.
The VRM is programmable to test for 10.0V, 7.5V, 5.0V, & 2.5Vā¦ DC of course.
Now please remember, while the VC99 & VRM were brand new; the INNOVA is at least 5 or 6 years old, probably a lot moreā¦ and has been riding around in my truck or car for most of those years in a plastic container I got at Walmart. Thru heat of summer and cold of winter tooā¦ā¦. in other words it has not had an easy lift.
Iāll just let the pictures speak for themselvesā¦. no adjustments were made to either meter. It was not necessary.
