I’m gonna be running indicator lights onto the switch so I might have 3 or 4 wires from it. I can’t remember where all the wires go! Lol. I’m also trying out a lot of different drivers in it lately.
I was thinking of using a jigsaw or maybe a Dremel with small diameter wheel. I think I’ll get me a small file as well and add slots to the hole. Takes longer, but less metal shavings everywhere.
Well, I somehow must have messed up my L6 driver trying to do a resistor mod. It has some flickering and can’t decide whether it wants to run in high or turbo. I never did get the resistor in. So before I order a stock replacement driver, should I consider other drivers? Not sure these shaky 63 yr old hands are cut out for teeny tiny part soldering. Or maybe get one and have someone else do the mod for me.
Use a magnifying glass and make sure the solder didn’t get on nearby components.
There is not too many choices for other drivers. There’s the Convoy version of FX30, there is the direct drive one that MTN sells, there’s the Texas Ace direct drive one that Lexel is making and then the stock FX30 that Kaidomain is selling. It’s a bit of an odd one, with 3 levels, standby and the same output as the Convoy version.
So if you want to turn it on/off from the rear switch you’d need the Convoy one or the TA one with it programmed to turn on at the rear switch.
If you want the rear switch to serve as lockout only and on/off from the side switch, them the Kaidomain, MTN or TA versions will work.
L2 + H1-A single cell boost driver from Kaidomain and XHP50.2
This is the result, no ringy at all and a very focussed beam, haven’t measured lumens or CD but it throws!!
I think it is around 2500lm, tailcap measurements shows 7A discharge on turbo from a liitokala 5000mah cell.
I put a 50.2 in my L6 with SMO reflector with modded FX30 driver, about 8.9 amps, and wasn’t really impressed. The hotspot was about the same size as my sliced dome xhp70. Output was almost the same as well, but it sucked up the power. My xhp70 only drew about 8 amps. It did have less donut shape to it, but that yellow corona is not to my liking. I went back to the xhp70.
Now a shaved dome xhp50.2 might give a tighter hotspot for more throw, but I haven’t seen anyone do that yet.
Ewww. That’s like my F13’s beam when I tried taking out the spacer to get the emitter deeper in the reflector for a little tighter focus. Lemon-yellow in the middle, Angry Blue™ around the outside.
Pulling it back out (with the spacer) at least seems to blend the colors together better, or at least does something to get rid of that.
Focus is still pretty good, but I wanted to tighten it up some.
Is it the dome that splits the colors like that? Wondering if a dedomed/shaved/HI emitter has the same issues.
Speaking of dedoming… Quick question, anyone know offhand if an XP-G3 or -G2 is better for dedoming, or put another way, if there are any particular issues with any particular models.
You can’t really dedome a XP-G3 (well, and be left with anything usable) because of how the phosphor is applied. You can slice it, but I haven’t tried that personally. A XP-G2 takes well to dedoming.
Just put a XHP35 HI in my L2 host driven with a resistor modded H2-C driver.
Pulls around 8,8A from a liitokala 26650 resulting in just above 2A to the led.
Had to pot the driver in a mix of silicone and silicon carbide because it gets burning hot in a hurry.
Unfortunately i have no pictures of the driver grinded to fit the L2 or potted, just the completed light. I get abit carried away in the moment when im tinkering with my lights.
I will get some pictures when i open it up next time hehe.
Cant get any good beamshots because i only have my phone to take pictures with, trying to find a good spacer height atm i am using one that is 0,7mm and i am pretty ok with the hotspot but i feel like it could be better.
While getting ready to replace my driver in my black L6 I happen to notice the wires reversed.
EDIT: IOW, the stock light from the factory had the leads reversed, red on (-) black on (+).
I checked the wires on the stock driver and they seemed properly placed. JasonWW suggested it was probably the “factory” LED being put on backwards. So I installed a new TA Driver I received from Lexel and just matched the backward wiring on the mcpcb, and it works.
Just making a note here for others to double check before you desolder and not notice wire placement.
True Jason, but if the light was working before the mod, simply adhering to the placement of pos/neg wires would have done the trick without worrying about it. I have put one on the star backwards before and wired it accordingly to save time, then later, re-modding it, the wiring was confusing. The simple logic that it worked that way made it clear what I’d done before.
My L2 should be here tomorrow, left Austin earlier this evening, so I’ll be ready to put the XHP-35 in it and have some fun.
