Difference between Opus BT-C3400 & BT-C3100 v2.1?
No reason to get defensive.
All I said was I was meant to have the Lite-on. I did not want a used SMPS and the Hitachi eliminated itself by not being in stock anymore. :wink:
Here is a breakdown for the credit of my purchase:
Cousin Settimio-50%
Wolfdog-25.1%
G163-24.9%
Thanks everyone! :+1:
I just bought This to be able to use my Opus in the car.
Let us know how it works. I hope it serves you well. :wink:
Thanks for the replies!
I am aware of the voltage fluctuations. Nice to know the Opus is not too specific on input voltage. I will only connect it to the socket after engine start or after shutdown.
I had a car plugtip being fried once when running a 12volt coolbox while driving in the car on holiday. But I think it pulled more than 3amp. Could as well be due to a bad connection with high resistance and thus high temperature.
I’ll give it a shot and hopefully the fuse pops before the opus if things work out bad. In that case I guess I can place a new fuse and lower the Opus charging mAh and be fine.
So — can someone sum up?
Is the power supply currently (heh) provided with the Opus charger inadequate?
Assuming need to buy another power supply, how to identify models that are
— best (level 6) energy efficient and
— “green” (low power draw so not wasteful to leave plugged in)
The Eagle (USPS) is about to land…… :smiley:
Well, I just checked USPS Tracking and my package containing power supply from “speaker_joe” (ebay) is out for delivery to my humble abode. :+1:
I place the order about noon on 19 April & it should be in my mailbox about noon today, 21 April.
That is two (2) days from California to NW Alabama!!!
Talk about fast shipping…. speaker_joe must have had it out the door headed to me a couple of minutes after I placed the order.
Wow……… :slight_smile:
I actually think this may be only the second thing I have ever bought off ebay……… :open_mouth::wink:
But if I can find more guys like him it won’t be the last. :+1:
speaker_joe on ebay gets a 10 star out of a possible 5 star rating from me.
I would highly recommend him to anyone!!!
If you were to read this……. Thank You speaker_joe!!! :+1:
EDIT: This is just such cool, fast shipping I had to post the Tracking as evidence. :smiley:
DATE & TIME………….STATUS OF ITEM……….LOCATION
April 21, 2017, 10:03 am Delivered, In/At Mailbox GADSDEN, AL 35903
April 21, 2017, 8:26 am Out for Delivery GADSDEN, AL 35903
April 21, 2017, 8:16 am Sorting Complete GADSDEN, AL 35903
April 21, 2017, 7:15 am Arrived at Post Office GADSDEN, AL 35903
April 21, 2017, 4:25 am Departed USPS Facility BIRMINGHAM, AL 35222
April 21, 2017, 12:32 am Arrived at USPS Destination Facility BIRMINGHAM, AL 35222
April 19, 2017, 11:23 pm Departed USPS Origin Facility WEST SACRAMENTO, CA 95799
April 19, 2017, 11:23 pm Arrived at USPS Origin Facility WEST SACRAMENTO, CA 95799
April 19, 2017, 6:22 pm Departed Post Office TRACY, CA 95391
April 19, 2017, 2:40 pm Picked Up TRACY, CA 95391
April 19, 2017 12:39:55…………. Order Placed
I think the power supplies have been inconsistent. Mine was inadequate, so was Teachers,maybe others. What was established in this thread about 2 weeks ago is that Opus chose a DIFFERENT manufacturer for the SMPS in version 2.2 . If you go back several pages you will see that.
I can not answer the efficiency/green question. I am sure Gauss163 would have an answer/info. about that!
My set up is maybe a little different. I have a strip w/ 6 outlets and a switch to turn them on/off. I do not leave ALL of them plugged in because if I did, when I hit the switch they would all come on. I plug them in as I use them.
I hope this helped a little.
One suggestion. If you get an Opus just see what happens before you buy another SMPS. Again, in this thread[~2 weeks ago] I gave a detailed acount of when mine failed and what happened. It ALWAYS happen during the CHARGE/TEST just after transition from discharge to charge.
@ teacher
Let me know how it works w/out the adapter. Mine still works fine as long as I do not move it. I am waiting a few more days for the initial adapter!
My Opus BT-C3100 V2.2 works fine during the full Charge / Test cycle with the original 220V power supply. Tested it with 4 NCR18650 3400mAh and 4 30Qs at 1000mAh charge.
Maybe It’s already written, but does this problem only occur with the V2.1’s?
Yeah hank, Wolfdawg pretty much summed that up and about the need for a new power supply. Mine definitely need one.
As far as the other two questions about green & energy efficient, I have now idea…. gausse would probably be your man for that like Wdog said.
I also do not leave mine plugged in most of the time, it is either on a strip or unplugged when not in use.
Hope this helps……… :slight_smile:
@ wolfdog ………… I can’t do that, you never answered my PM!!! :smiley:
I wanted to see if you happened to know the two guys I spoke of…. :smiley:
I’ll check it out when I get home and get it out of the mailbox…… I’ll try to let you know later tonight. :+1:
Yeah I got a tracking number on the adapters but it will be a few days on them at the least.
But the power supply from speaker_joe got here lightening fast!!!
Thanks again for finding that, as well as the link to it. :slight_smile:
What is the brand name on your power supply??
No it is with the v2.2 mostly I think. That is what mine & wolfdog’s are.
Well I’m glad I brought this issue up a couple weeks ago with my unit. Looks like everything is solved now. I may get a new power supply eventually. But it doesn’t happen enough to really ve a problem at this point. Just occasionally.
Sorry for being late to this discussion… I may have missed this, but what is the brand/model number of the problematic power supply?
I have an Opus BT-C2400 (so not the 3100 discussed in this thread) that is v2.2, and came with power supply model KYT120100BV-09. Was just wondering if C3100/3400 v2.2 use the same one or different…
See post #150 and #152
  1. is My 2.2 SMPS POST #152 IS 2.1 SMPS which did not seem to have a problem. Opus CHANGED manufacturers of the SMPS which seems to be what caused the problem.
We would have to find someone who has the 3400 to determine that.
I have a 3400 —It was determined mine had the better PS—- the crazy think is I have a 3100 with the rounded corner crappy PS — when I was at the camp this week I did a charge/ test on some cells —worked perfectly
On another note—I went digging through my treasures (my wife says my junk)—I found two laptop PS —- 1 Liteon 12v 5.5a
and another IBM 14v 3.5a —-both barely heat up at all during testing
Was your charge/test for your crappy 3100 w/ 4 X 18650 3400mAh @1 amp?
Does the Lite-on look like mine?!!! Same specs!
I tested cells I had on hand —not a quad of the same battery—but 4 cells charge /test @ 1amp
The LiteOn I found looks similar to that one—-I would imagine mine is quite a bit older—I think it came from an EMachine laptop I junked several years ago
So, googling, I find there’s an Opus C3400 v3.1 version for sale out there,
https://dc-workshop.com/opencart/index.php?route=product/product&product_id=50
and a couple of suggestions of a v3.2 (Russian language)
Has anyone found a list of the Opus charger products and specifications, to know what the different model and version numbers mean?
I wonder if they all come with the same iffy power supply.
From that “dc-workshop” review page, the spec includes
adatper [sic]
If you look at the two different models—you can see in the pictures the 3400 has a more square PS (Good One)
the 3100 has a more rounded PS (Bad One)
How soon we forget……. :wink:
3.1
