So I want to flash a different firmware onto my board. I bought all the things to do it and read through this guide:
https://budgetlightforum.com/t/-/30672
Only issue is that I am trying to flash a atin25 not a atiny13 chip.
The first thing to flash for bistro and similar firmwares is the battery check, run it , then the rest of the configuration stuff, check them etc. Then finally the actual firmware.
I copied the batterycheck-25 hex file out of the repository:
http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/files/head:/ToyKeeper/battcheck/
I don't know how to get things to compile in atmel studio on windows so I was hoping I ould use the existing hex file. I found I can use gitBash for a shell and execute AVRdude on windows. There was a sentence about setting the correct fuse values based on the .c file, but I didn't really see anything for the atiny25 in the c file linked below.
I used 0x75 and 0xFF when executing the command. It started to write to the chip but then error-ed out. Something like 0xFF expected but found something else. I figured I did something wrong so I want to delete the chip. but now I only get an error message, when trying to erase or check status.
Error is below:
https://www.irccloud.com/pastebin/yfvj6RuT/
Does this mean I bricked the driver? What did I do wrong?
