It is part of the safety inside the can, i.e. you cannot get to it without destroying the cell.
The fuse is there to prevent the cell from doing something nasty (like explode).
Excellent review. Like the fuse for safety (of which the cut off point is way higher than general flashlight use). Just a shame that the cell is so wide, almost a 27650.
Average internal resistance looks slightly below 25mΩ, just a gnat's ass higher than that of a LiitoKala 26650-50A. Definitively an improvement in energy density, with an actual power delivery rating. Verrry good!
About the fuse, a bit sensitive I'd say. Temperature monitoring definitively recommended/advisable.
Cheers ^:)
Originally posted on Mon, 04/24/2017 - 01:33; IR estimation fixed, content added and make upped.
The shockli would perform better over time because of its higher capacity, not because of a lower IR. At a given resting voltage, like fully charged at 4.2V for example, the cell with the lower IR will provide more current in a direct drive situation, but a cell with a lower capacity will drop its resting voltage quicker over time.
It seems like a compromise between IR and capacity oftentimes. The VTC5A would give more amps at start than this shockli, but obviously the capacity is in a different ballpark and would not be as suitable in a high power light.
Here's the 5A comparison below. So accept for the first 0.25 discharge, the Shockli performs better - the blue line is clearly well above the red line. I though it should produce higher amps in a DD/FET mod, accept for the first 250 mAh. Am I reading this right? Does that first small advantage for the LK mean it will have a lower internal resistance?
The internal resistance is measure at 15A (if the cell can deliver that), but higher voltage at the desired current is always a better metric to look at.
If we are to substract the 20A from the 1A curves, we attain a dV/Ah one which reveals the average internal cell voltage drop for that 19A rate. This reveals close effective average internal resistance. Both first and last parts of the curve shouldn't be used, as there usually steep slope shifts happen because of dramatic changes in the cell's available energy and internal resistance.
The shockli maintains a higher voltage at a given point in the discharge, but that doesn’t mean its IR is lower. The IR determines how much the battery will drop its voltage (the resting voltage minus the voltage under load) at a given current. At a given point in the discharge curve the shockli will have a higher resting voltage than the LK because its capacity is larger, so even if the shockli drops a bit more voltage than the LK the voltage under load will still be higher than the LK because the shockli started at a higher resting voltage.
Essentially the vertical spacing between the discharge curves at different currents is proportional to the IR. In this case the shockli and LK cells have very similar IRs so the shockli’s extra capacity gives it the advantage in pretty much all applications. Comparing the Sanyo 20700A and B cells is more illustrative. At the 5A rate the higher capacity B cell maintains a higher voltage for most of the discharge, but at the 20A rate the lower IR A cell pulls away and is the more suitable cell.
