Trustfire X7 T8 SST-80
What is the stock lux on the X7/T8? For some reason I haven't seen much about this light, have I been living in a cave somewhere? I can't find any review or figures for throw. In stock configuration, will this out-throw a Solarforce MPP-1? I have been looking for a light that will out-throw my MPP-1 but not cost a ton of money (like less than $75). From what I have read, people measure the MPP-1 as high as 52k lux with the UCL lens (which I have).
This light can be purchased from a US seller on eBay for $69 shipped. If this does much more than 50k (or am I just dreaming on that number??) lux stock then it may be my next purchase.
This comes with the SST-80, but the XML will produce more throw?
http://www.ebay.com/itm/270858655068?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_3408wt_1037
I have never swapped an emitter or a driver before, but I think i could do it easily enough. Is there a driver that would drive this light harder than the one that it comes with?
With orig. LED i measured 43800 Lux, my version(XML) has 86000.
That was with an SST-50 though, I believe the updated (?) version I linked to is an SST-80.
EDIT: Does the SST-80 even exist? Starting to wonder why I had never heard of it, and after some research it seems it does not exit.
It doesn't. This flashlight has either SST-50 or XM-L (wrong description).
SST50 all the way.
It's crying out for the XM-L swap...
Could they mean this?
http://www.luminus.com/products/SSM-80.html
If not, why haven't we seen this LED in flashlights?
Yeah, it's about 42k cd ballpark. There is a SSM-80 and SSM-50. Also SSR-50. Eg http://www.candlepowerforums.com/vb/showthread.php?247683-SOLD-Luminus-SSR-50-1xC-Flashlight-With-Neutral-tint-Top-Bin-(GJ201)
There is also a current production CSM-360. 100W
They have been used, but few here would buy (even last time). Folks are already refraining from purchasing 50-60 bucks light (42 bucks for a triple XM-L, it needs to be low), let alone a LED that costs 50-few hundred bucks? And seriously you'd need a better/bigger host for that to work, way too much heat.
http://feilong.us/goods.php?id=41
My original one is from HERE and it should be a SST-80.
Means: X7 with SST80 = 43800 Lux.
First i try the original light, i had laughed about the output/size.
