thank you. I am working on uploading the photos. I used a small fan to cool the light on high mode runtime test. would try to put it in the water to test again.
all tests are ready, except the runtime test on middle low and extreme low mode.
Thanks for the review updates so far, and the effort you’ve put into the review. As well as aforementioned heat handling on high, I’m interested to know the beam profile and angle (light vertical against white wall).
Hey how are you doing? Thank you very much for the fine review. The pictures are really beautiful! I also like the beamshots that show hints of Asian flavour.
I was thinking about using protected batteries on this one. Do you think I’ll have a problem with this? Since it doesn’t specify otherwise, like on the MT03, I figured I’d be ok.
I couldn’t find any specs to help me, but I doubt I’d be able to interpret them anyway, since I’m a newbie.
