Thanks for the review. Interested to see some beam shots. How does it handle the heat when running continuously on high mode?
thank you. I am working on uploading the photos. I used a small fan to cool the light on high mode runtime test. would try to put it in the water to test again.
all tests are ready, except the runtime test on middle low and extreme low mode.
wow
great first post!
thanks for thr nice pictures :beer:
(could you please make them.smaller ;) )
thanks
sure, what size should i make? 500px or 800px? still have a lot of beam photos
Nice! I have one on the way. I do like these Haikelite’s. Good pics. Thanks TBO
Thanks for the nice review so far, :THUMBS-UP: could you take some pictures outside please. I think I go for the CW version.
is it 6V or 12V led, the 12V will make sense because it uses 3*18650
6V xhp50, the 3*18650 are lined in parallel
Will added some more pictures when i have time. I also ordered a cw xhp50.2 , have not received it.
Thanks backpack, I hope you will get the CW version very soon. Maybe you can do some beam shots between the NW and CW version.
Thanks for the review, just ordered it!
Thanks for the review updates so far, and the effort you’ve put into the review. As well as aforementioned heat handling on high, I’m interested to know the beam profile and angle (light vertical against white wall).
here it is
Excellent. Thanks!
Incredible photos! Thank you!
Very nice, thank you
Can you try a driver mod with resistors?
And can you make some more pics from the driver? Is there a R020 Resistor?
Hey how are you doing? Thank you very much for the fine review. The pictures are really beautiful! I also like the beamshots that show hints of Asian flavour.
I was thinking about using protected batteries on this one. Do you think I’ll have a problem with this? Since it doesn’t specify otherwise, like on the MT03, I figured I’d be ok.
I couldn’t find any specs to help me, but I doubt I’d be able to interpret them anyway, since I’m a newbie.
Nice review…how far the max visible/usable throw?
