It sounds really nice. I should probably get or make one after itās known to work, for development purposes. It seems avr-gcc didnāt add support for the tiny841 until fairly recently though, which means Iāll have to upgrade some toolsā¦
BTW, before you finalize anything, do you think thereās any chance of getting a trace from an ADC-capable pin to LED- ? This would allow the driver to sense the ambient light level while the LED is off, which means it could be configured by pointing it at a computer screen with binary code blinking in black and white. Or it could maybe sense whether to skip moon mode when the ambient light level is too high for moon.
I will do that on a next version. For testing in the meantime there is a via used for flashing that is otherwise unused. Itās on PA5 which has ADC capabilities.
TK, that really sounds wonderful. I love a true moonlight mode in almost every light and if it were there or not based on existing lightā¦ that would be awesome! The programming idea is interesting, thus having the extra space in the chip might be huge!
We seem to have new drivers showing up every day that have lots of potential right now. It is awesome! Just wish I could wrap my head around building them. I can see I will be ordering parts soon and testing this bad boy out!
Iāve just received the new v6 design for the F-2 and F-4, so Iāll build a few and make sure there arenāt any screw-ups.
The v6 component and pin design is already tested and working nicely though. I made a L4 dedicated version with 14 x 7135s which is the first of my v6 drivers to actually make it into a light: What did you mod today? - #2984 by Mike_C
I used a 22uF X7S rated OTSM cap on the L-14 which consistently gets over 10 measurable seconds at 4V and room temperature. Iāll have to lower the voltage and heat it up to test the margins.
Well, with the ATtiny85 without bending pins I found that the clip would pop off every now and then, and was sometimes difficult to get on right. It was much better when I bent the legs but would still sometimes be annoying to get on correctly and could still pop off easily, at least when it was installed in a light:
The acupuncture style has itās drawbacks too, in particular if the wires used are too thin. It has happened that Iāve had to push on the wires as contact was lost, but it happens so seldom so I much prefer this method. Now I can have the MCU on the inside, keep a spring pad and flash the driver without taking it out. Thatās a real advantage for a firmware developer
I have a dedicated development platform which makes development and testing much easier. Without the clip I find it even easier, but having the right size āneedlesā is key. The paper clips I use are pretty much spot on for the via size I used:
I have had that problem with the ATtiny85 clip popping off, but only pretty rarely. May have more to do with the solder flow on the legs. With bent pins, never a problem - rock solid clipping. Are you using the good blue clips?
The clips are blue, and mostly worked fine, but they might not have been the good ones. Sometimes the clips contacts would get bent and need straightening out. Possibly the stiff wire I ran over the 85s as battery contact had something to do with my issues, or possibly too little clearance to the 7135s:
Anyhow, these issues are now a thing of the past. Iāve fully converted to the 841 on all my drivers.
Small update for those interestedā¦ Iāve been testing and developing firmware for these v6 boards and so far so good. Iāve also made v7 series with some pin changes but it turned out that those changes werenāt really needed. I did make some other small adjustments so Iāll be using the v7 series anyway.
Iāve got off-switch and dual-switch functionality working fine, and Iām now working on E-switch only. Itās all the in same firmware but switch configuration is set by #defines. I did have a version where I could set switch type within the lightās config menu which worked well and was useful for debugging all three switch types in a single light, but that ate up too much memory.
On a single cell E-switch light I have got the parasitic drain down too low for both my DMMs to measure very well (Metex M-3650 and a Fluke 77). The lowest reading I can get from them is 0.1uA and thatās what I am seeing. When I pull the power to the driver it goes to 0 so the DMM is seeing something. Anyone know how accurate I can expect these DMMs to be at so low currents?
In any case I canāt get any lower as Iāve configured all pins and shut everything down for lowest power consumption while waiting for the switch pin interrupt to wake it up again. The datasheet specifies 1.3uA in power down mode but thatās with the WDT enabled. In power down mode I have it disabled. Anyway, Iām fairly satisfied the drain is low enough.
I havenāt built a multi cell LDO version yet but I expect the LDO to draw more than a powered down ATtiny841 in sleep mode. Iāll be building one of these shortly to try out if the AMC A705s can replace 7135s on 2S lights, so Iāll find out soon enough.
Thank you for the update. I feel like this is potentially groundbreaking and ānext levelā driver design. I really like it. just need to source the MCUs in small quantities somewhere.
Well, if we can get enough people wanting them, we might be able to talk Richard into carrying them at Mountain Electronics. That at least helps USA folks.
