Thanks for explaining this. I haven’t really paid attention to how quickly the bar graph updates. I typically check battery voltages with it, where there isn’t much if any rapid fluctuation.
That’s because your DMM is 6,000 count, I presume, which means you get 3 decimal points resolution all the way up to 6V.
In comparison, mine is only 4,000 count. So I only get 3 decimal points resolution up to 4V. Once the measured value is above 4V, mine drops to 2 decimal points, as you can see in the last photo I posted.
OH…. OK…… I understand that. :+1:
That is why mine drops to two decimal places on the 7.50 Volt reading. I had been wondering about that.
Thanks for explaining that Pete.
@ Pete7874 The picture of the meter in post 153. Are the glass tube looking fuse the same one that are used in automotive, if not are they hard to come by?
@ teacher Is there any way to test these voltage boards? For the battery operated voltage boards, when the battery voltage drops will affect the voltage board accuracy?
I know this was for teacher, but I’ll chime in with what I know.
You basically take a measurement with a known calibrated highly accurate DMM, and write down the result. That is the actual voltage being put out, and you can then see how your own DMM compares. That is why the one I posted above has that little sticker with actual measured values from an Agilent DMM written down. Granted, you put your trust in that someone actually did these measurements on your board and not just copied the same sticker and plastered it on hundreds of these boards without actually measuring. These things are cheap, so you never know, unless you have another perfectly calibrated DMM sitting around to verify. That is why I wrote earlier that I don’t trust it 100%, but all my other cheap/free DMMs seem to indicate it’s correct.
As for the battery, most of these voltage boards have some kind of voltage regulation circuitry to keep output voltage the same, just as long as the battery voltage is above a certain level.
I’m sure there is a way to test them, but honestly; that is getting above my “pay grade”. … (In more simple words… beats me how though. . )
I think as long as the battery voltage is above the voltage you are referencing allis well. The one I have is designed for input voltage of 5 - 30V DC. So I just plugged in a 12V power supply I had and powered it that way. Mine takes a 5.5 x 2.5mm barrel plug.
I did that some time ago, and it seems that UT61E is often being recommended. But since you pointed out some flaws with it, I was just wondering if there was something better in that price range.
Not sure which model you looked at Venom, but as a general rule Klein makes quality items… tools & otherwise.
Some seem kinda pricey, but most all are quality.
I am sure they are good meters Venom. But hopefully someone who really knows about meters will have some advice on them.
The ones I have are just mainly used by me in this hobby, ocassional mechanic work, & things like that. Mostly pretty low voltage & current DC. They all seem to work fine for my limited needs.
I have some I would feel comfortable checking AC things around the house ocassionally…… but I would never go above household current or voltage with any I own.
In other words…… I ain’t much help to you on this one besides the ones I have that serve “my uses” just fine.
@Venom …… When I wrote post number #179 above last night I was on my phone trying to look at this stuff. I am on my computer now and am able to find & see pictures much better.
The MM600 seems to be $66.97 at Home Depot
The MM700 seems to be $99.57 at Home Depot
AGAIN…. hopefully some who really knows about DMM’s will chime in here. But here are my “semi-uneducated” observations. Better make that “mostly-uneducated” observations.
They are both Auto Ranging… that is good
They both appear to be well made
They both appear to have ceramic fuses… not glass. Very good
Both are rated…… Safety rating is CAT IV 600-Volt, CAT III 1000-Volt, class 2, double insulation
MM700 is True RMS
……… I don’t even pretend to understand this, it’s significance, or how important it is in a meter…. :person_facepalming:
Heck, I’ll just stop there. I pretty much think these are both good meters.
If you are just going to occasionally check battery voltages and do some tail cap readings they are probably both overkill.
But on the other hand if you want a good all around meter that you could use with confidence and not worry about getting fried if you decided to use it for AC electrical measurements around the house or higher DC voltages……probably a good way to go.
But, don’t take this for the gospel. These are simply my observations.
Ya its over kill for checking batteries and amp readings. For that the free ones from harbor freight are perfect and more then accurate for. And they have that little screw inside if needed. I have a $5 one shipped from gearbest. I wouldn’t go do commercial work with it. But perfect for checking charging voltages and laptop pulls and such
Klein is a reputable brand, but like others mentioned, it may be overkill, depending on your application. For a little over $20 you can get an autoranging Innova 3320 from Amazon.
