Hi,
yesterday I got my first order S2+ and a X6 spacer. It won’t be the last order!
The package is outstanding. And the quality of the spacer is great.
Thanks!
Hi,
Thanks!
Put me down for one copper spacer for Convoy S2+ triple and one copper spacer for Eagle Eye X6 for Ledil Cute-3 triple. Thanks!
Great inexpensive triple spacers, and some stuff that can’t be found elsewhere! Great packaging. Will definitely be ordering again.
I’m interested in the C8 an M2 setups. Please message me for purchasing details. Thanks
kiriba-ru you have out done yourself again! Shrink wrapped (bullet proof) package arrived today,
Everything in perfect condition!! Thank you!!
I received Kiriba’s aluminum C8 spacers a few days ago and built my first triple (What did you mod today? - #2933 by k-wong). Packing, fit, and everything looks great. Even included copper jumper wires for the mcpcb and very bright glow in the dark o-rings! They were still illuminated after 45 minutes in the dark, really impressive…I guess I’m not use to seeing o-rings glow for so long, usually just a minute or two in my Convoy S2’s.
The aluminum spacer is thick but not too heavy. It’s bright as hell but it doesn’t get too hot in the hands so great form factor overall… I’m definitely enjoying it.
Have few extra VG10 parts left, dont forget to specify your host version if you need one.
Kiraba’s package sent to me on the 7th arrived to the east coast of US yesterday, the 27th. 20 days is better than most Chinese shipments. Packaging was fine for what was sent. I ordered 3 copper spacers for my first 3 builds. I don’t have much experience with these types of parts, so I cannot comment on the quality but I assume these will work well, as others have demonstrated. Prices seem reasonable! Thanks K!
My P60 Drop-in shell plus goodies took 25-days from order to door (east-coast US). A little better than China delivery times to me and definitely MUCH BETTER packaging!
Here’s the finished Triple after a little clean-up of the as-recieved patina. Nice friction/rub fit into my 6P.
The driver board I used had components mounted close to the edge of the PCB, as a result I was unable to seat the board flat onto the driver-side shelf. A narrower shelf rim would have allowed the board to sit flatter but it all still fits.
Thanks Kiriba.
Spacers came in yesterday, everything was packaged well, the spacers look amazing, and only took two week to arrive :+1:
Just got my copper spacers and optics.
Excellent packaging. You have protected everything inside with such great protection.
I am very impressed.
Will definitely buy from you again.
Cheers
Hi,
took some time to finish this one. Manker U11, MTN17DDm, 4x Nichia 219C D320 and the heatsink from kiriba. The light is heavily overpowered because the heatsink has not much contact to the body. This only in my case because i did not use the original insert which makes contact to the Body. I will try to put it inside again to optimize heat transfer. Swapping the driver was a little pain but worked in the end. Start 3200 lumens, 30 Sek. 2027 lumens :sunglasses: Crazy light!
And some GITD foil in the brass liner
Regards
Kenjii
With some additional work i managed to get the insert into the light again. Heat Transfer is way better now. Startup 4111 lumens, 30 Sec. 3470 lumens
Interested in 1 copper pill for the convoy s2+.
PM for details.
Received, thank you! VG-10, X7
Happy with the S2+ triple pills, thank you.
D01 pill came today, fits perfectly good. It gave some nice weight to the light now it feels more balanced.
Also i did make another wire hole so i can route the negative wire a little better. Noctigon XP32 boards have both connections on same side.
My package of goodies from Russia came in today. Kiriba-ru really knows how to pack these little items. I was so impressed I had to take some pictures to share.
1 Copper spacer Eagle Eye X7 triple and 1 Copper spacer for Carclo triple Convoy S3
Got my package before work.Very well packaged and well machined.Cant wait to get this quad convoy m2 built
