mattlward
vinte77
statix57
Kawiboy
Etex
MrJohnny
sent today
mattlward
vinte77
statix57
Kawiboy
Etex
MrJohnny
sent today
reflowed now all boards
tomorrow doing a lot programming and testing
last chance to check if your divers are set up as you wish
when you did not specify any temperature limit it will be set to 60Ā°C
all drivers are now flashed configured and tested
did pack em as well
last chance to check the Excel sheet if everything is right
:+1: Excellent!
Thanks for all your hard work. Iām looking forward to receiving them and building me some awesome lights. :+1:
+1
I posted this in TA's driver thread as well:
So made some progress on merging Narsil 2 channel and 3 channel, so I have one source code base now with a header file called setups.h. In setups.h, you define all the board configuration settings and other compile time user option settings.
It's compiling now for 2 channel and 3 channel, with indicator LED enabled or disabled, and using R1/R2 or internal V1.1 ref for voltage monitoring.
Totally untested, but it compiles.
Next to do is actually try it...
Some Details:
It has the more advanced, simplified version of the configuration settings UI that's in the 2 channel latest version of Narsil, v1.3. One new feature is ability to set the temperature threshold for thermal stepdown. There's probably a couple more tweaks as well in LVP and thermal stepdown, results from more recent testing.
Testing will take some time - may need to actually build up a couple boards, etc.
Thank you Lexel. You have been epic!! :+1:
Thank you Lexel once again, your work is truly appreciated !
Can I add a Locator LED if I want to ? Thanks !
locator LED with resistor can be simply added to the bleeder resistor pads
Just little more Narsil update news -
You will need to add a resistor inline with the LED in this case or it will drain the battery very quickly. A normal through hole resistor could be used easy enough. Something around 30k-50k ohms generally works out ok.
Are you guys talk'n bout a tail bleeder LED (Bistro - clicky) or locator LED w/Narsil? For Narsil I use somewhere between 2K and 15K, depends on the LED(s) and visibility of the LED.
Well, it sounds like he is talking about installing an indicator LED using the tailcap bleeder pads.
So it would remain on 24/7 and drain the battery continually. 50k ohm resistor tends to have the final output be around ~0.050ma from my testing, so a little over 1ma per day of drain.
I want to use the Narsil option to activate/desactivate the locator LED, not simply use a bleeder resistor + LED
This makes more sense and it also means you donāt need a resistor, or at least as big of one. But in this case you canāt use the bleeder resistor pads. I am not sure what pads you need to use but I think the voltage divider pads. Never used an indicator LED with narsil before myself.
Ooops, removed this post. Lexel is using an older version of NarsilTriple, so not sure about the Indicator LED support.
What would you recommend for a broken thorfire s70s driver?
The TA30 was designed for the L6 and S70. I love it in my L6 although it can get really hot if you run it on turbo.
Are you guys talkān bout a tail bleeder LED (Bistro - clicky) or locator LED w/Narsil? For Narsil I use somewhere between 2K and 15K, depends on the LED (s) and visibility of the LED.
Iām not sure what aplication X3 is using.
I was talking about a side switch led for the L6, not tail switch.
I donāt know much about the āindicatorā or ālocatorā led. My plan was simply to have the side switch light up whenever the tail switch was turned on.
When not using the light I will click the tail switch off which cuts all power.
I want LVP, so I got Lexel to install Narsil v1.2.
