The Jaxman UV light has even slimmer grooves than the E2L. If your clip is close, it might just fit the E2L. Could probably open the groove width slightly to make it fit, fairly easy on a lathe but a bit more work without one, still doable though. Without a lathe you can disassemble the tail cap, use a washer to cover the tail end and a piece of all thread or a bolt to run through the tail cap and a nut on the inside to secure it. Mount the all thread/bolt in a drill and spin it up, cut the groove wider with a rotary tool or a hack saw blade, perhaps a small file.
Perfect! Thanks!
Your welcome
i asked jaxman to produce for a bigger amount of this light with xpl high…with fet driver.they said,the switch is not suitble for so many amps…what to do?:laughing:)
That continues to make me laugh!
That switch, the mini Omten, is handling 23Amps in my DBC-05 Triple XHP-50.2.
(That’s 23Amps at over 7V. )
hi,due to busy working, days off-line to BLF.
23A….is too terrible….
I have confirmed with a switch technical from the fatory of the switch(not Omten), the man told me,the switch can not bear 3A more.
The 1288 type switch titled as 250V 1A. Though we use this switch under 4.2V, while I think 20A 4.2V is also out of my imagination…
I have get a better provider than Omten. But it still make me stop on a 3A+ current controlling with this little switch.
How you think about dear all friends?
I can totally understand that you do not want to go too far over the factory specifications.
But here at BLF we are a bit funny, we do read the specifications but then we test what it can really handle, and we found that the little Omten 1288 is quite happy at more than 15A, I found that it just keeps working at 16A for hours without failing.
But personally, I think that for the factory built E2L the most sensible current is 3A, the light gets hot enough already, and the light output is great. Anyone who wants more current can buy a host and components and build their own hotrod. Or wait for a BLF initiative for a custom triple flashlight.
18350 and 18500 tubes are available, though I find it unfair that Jaxman refuses to sold it alone.
You have to buy the E2L flashlight at the same time or they won’t sell it yo you…
Bad move IMHO Jaxman
My Jaxman M2 is pulling 4.75A at the tail, 2S 14500 for 8.4V and 3014 lumens from the XHP-50.2. Spring is wire bypassed but the switch is the stock one.
Totally agree! I have two E2L hosts and I need to buy a light to buy tube? I saw gearbest selling stock E2L-s. I hope they will sell the tubes also.
My Jaxman M2 with a XHP50.2 can pull up to 5.88A at the tail completely standard tail switch no by pass, I normally turn the LD-3 driver down to 4A.
Crappy video recorded with my cellphone :
Jaxman - when will the next batch of triple hosts be available?
Thanks!
Khas, I used a 7135 chipped driver to control the output.
I think the LD-3 driver is great in a build like the Jaxman M2 very easy to adjust the current and the UI is great. Besides I can’t build my own drivers soldering wires is right around my skill-set
Agreed.
And i think the Vf of those XP-G2s @ 1 Amperes each is not too low either and probably quite efficient too at that low current.
Yeah, i’m looking forward to that, just hoping they will re-stock the light grey hosts…
I just bought two of these from mtnelectronics.com. They seem like an interesting light. Seems much better than my modified SK98 XM-L2 U41C Qlight 3.04 amp lights. More effecient light output and runtime. The quality looks pretty good too. Hopefully this will not disappoint.
I see warm white 4000K option available on Jaxman Aliexpress store, will natural white 5700K be available soon?
I just bought two of these in the XP-G2 neutral white variant, (3C) and I find the tint is too yellow. I’m torn as to weather I should send it back and swap them for cool white 1C versions. I tried comparing the 3C tint (5500k) to my MT-GT Q0 (5000K) and well the MT-G2 looked better and allot less yellow vs the XP-G2 3C @5500K. I mean if anything the XP-G2 should have been more white then yellow… Now comparing my modded SK98 with a XM-L2 U4 1C, I’m liking the cooler look of the 1C.
Sure it’s not just mislabelled/misbinned?
I’ve got a 4300K-4500K XP-E2 in a C8 that’s quite a nice color, warmish but not overly so. In fact, its hotspot is about my favorite CT/tint just short of a 219B.
My S2+ with a 4C (should be the same exact CT, more or less) XM-L is decidedly yellower, more like in the 5s than 4s.
The spill of the S2+ is way more blue, though. So if you do a ceiling-bounce, the S2+ has a beautiful color overall (after all the color-mixing), but the hotspot is definitely an egg-yolk color.
I think that’s one thing that’s often overlooked. We tend to look at only the hotspot to judge the CT/tint, when the whole integrated spread from the LED is what’s being binned.
