I would use the threaded reflector to adjust height for focus, I’d glue the mcpcb with Arctic Alumina Thermal Adhesive and adjust the placement of the emitter in the 5-10 minutes it takes for the Adhesive to cure. Put on the bezel and enjoy my light.
If the placement is so critical due to the small emitter size, then exacting precision on tolerances is the key. Starting with a $12 host is the nightmare. Choose the right host to begin with, or make it, and the problems solve themselves.
Some outdoor beams shot I am using iPad mini 4 camera so don’t expect good photos. SupwildFire dd xml2 u4 od about 5000k I guess A6 fet+1 VS Jaxman X1 XHP35 HI 6500K, H2-C driver. That is 160M according to Google maps.
The first three Night photos SupwildFire the last three Jaxman x1. Don’t know how far on this! First two night photo is supwildfire last two jaxman x1 and indoor photo @9M indoor photo are supwildfire.
The next one came , this time it`s a S4 1A based( from the old ones, 4.7amps capable) and tests shows it 280-300cds , the hotspot is nearly perfect, i just need to sand the pill this days, ordered some Ar glasses from KD and i am thinking about a new pill, the default one isnt that good.
The pill and the defautl driver are kinda different from the first one that i got
Can you give us some measurements ? (Pill’s) Threads OD , height etc
If not , no problem at all
Edit : Just measured my UT02 with dedomed S4 1A i made 3 days ago , i think the emitter is one of these djozz described as old-dot-pattern/new-phosfor-type and it’s making 300,4kcd with a rested Liitokala battery . It would be interesting to check this flashlight with this led too
Very encouraging results guys. Now I know I can expect around 330 from my mod.
But inconsistent production? LOL that should be really crazy adventure. But if it accepts UF T20 pill than there should not be any problem. Problem would be with inconsistent reflectors.
Perseverence! Got the Black Flat working in this nightmare! I made no pictures, here’s some words:
-replaced the blown switch with the same KAN28
-Sanded the base of the reflector as thin as I dared, less than half a mm
-I already had cut away the sides of the reflector base to make room for the wires (see somewhere above in this thread)
-as also mentioned above I used a Black Flat on a 20mm Kaidomain DTP board (sanded down to 19mm), no driver and original driver board used as contact board, both springs bypassed with the cap over the tailspring removed, 30Q battery
-I had to bevel the inner edge of the pill quite a lot to allow the reflector to come close enough to the led, this was essential!!
-I still used a centering piece, reamed the hole a bit because the Black Flat is slightly bigger than 3535-size, and with the base of the centering piece sanded paper-thin, the reflector is now less than half a mm above the ledboard
-I cleaned the reflector after all that filing and sanding by soaking with water and soap, last rinse with distilled water. The reflector still looks quite abused though.
-sticked Kapton tape over the cut-outs on the reflector, and also over the ledwire solder blobs
-I silicon greased the thick o-ring on the inside of the bezel so that upon closing the bezel it would glide easier over the glass.
I positioned the reflector as well as I could over the led+centerpiece, glass on top and while pushing the glass down firmly with a rubber pad I could screw the bezel almost down to maximum tightness, but not the very last bit, so I fixed it by tightly wrapping the groove where bezel and head meet with two layers of cellotape (sounds ugly but it is hardly noticable, and very effective)
The led is in perfect focus but ever so slightly off-center: the hotspot looks fine but the corona is slightly assymmetrical. On an almost full (4.06V after all measurements) 30Q battery I measure 694 lumen (which is very close to max for this led), 5.0 amps and 343kcd (measured at 7 meter after 30 seconds). The output is pretty stable so heatsinking is good and the Black Flat seems happy sofar. If the led had been perfectly centered and I had not abused the reflector so much (and by using AR-coated glass) it could have been a bit better even.
Are there any numbers on an old-style dedomed XP-G2 S4 2B in a HD2010 btw? Could be over 400kcd I guess?
Here’s the hotspot on a white wall with the flashlight at 7 meters distance:
I’d end up forgetting all the work it took and open it, screwing everything up. lol
Nice job!
I fixed my old Olight SR-90 Intimidator to take two 32650’s. I put a clicky switch in the tail cap for lockout and used an 18 ga lead through two pcb’s to contact the tail end of the cells. This all went together very intricately, the inside pcb had to be able to spin in order for the tail cap to screw on. Not long ago, forgetting all this, I cranked the tail cap off and broke the 18ga lead from the negative (and the additional 18ga lead to the battery positive. UGH! I only just fixed it again, need to get some glue in the threads on the tail cap so I don’t do it again. (Or engrave Do Not Open on the tailcap… so forgetful)
Actualy T20 pill fits better yet we do need a CU pill in there, what do you think about that matter?
If so, i could give you some thoughts about it, it should be actualy something like the t20 pill yet with a flat emitter plate in order for it to be capable of 26+mm pcbs carrying
I got 320cds out of that body folks, nearly the same as a very well modded M2X: with everything needed for a good mod but the ar glass
For the money, one of the best thrower budget deals atm: its the reflector equivalent of B158
Im short-sighted so Im not into this throwers
If you need some copper pills, I can do them, but I dont want to have one more useless host on my table. If you can send head with stock pill to me, I will return it with upgrated pill
