Fenix 16340 700mAh ARB-L16-700 (Orange-Black)
Official specifications:
Nominal capacity: 700mAh
Minimum capacity: 670mAh
Nominal voltage: 3,7V
Charge profile: CC-CV
Charge voltage: 4,2V ±0,05
Charge current: 350mA (Max. 700mA).
Discharge termination: 2,75V
Max. discharge current: 2C = 1,4A
Chemistry: LiCoAlO2 (ICR)
Over current protection PCB: above 2A
Diameter: 16,00mm ± 0,2
Height: 34,00mm ± 0,3
Weight: 17,4g ± 1
A RCR123 high capacity battery from Fenix with protection at the plus pole.
The cell can deliver about 2A before it starts to loos capacity, this matches fine with a 1.4A rating.
Conclusion
For high capacity 16340 batteries these looks good and they are very short for protected batteries.
Notes and links
Comparison to other LiIon batteries
